  4. Automatic placement of POI's in Route
4 Posts 4 Posters 1.2k Views 2 Watching
  • Paul Phillips 3
    Paul Phillips 3
    Paul Phillips 3
    It would be great to have POI's such as cafe's, fuel, etc. to auto add to a route at a set interval with a radius (distance or time), would be easier to remove them than search along a route when planning longer routes.
    Guzzist 1 Reply Last reply
    • Paul Phillips 3 Paul Phillips 3
      @Paul-Phillips-3 hmmm - not sure if I understand your need exactly.
      But if you are planning a route, you can activate dedicated POI in a POI-list at left side menu panel. The selected POI types will be shown in the map if you are zooming in enough.
      You will see, which ones are nearby your route. If you click on such a POI, you will be asked, if this POI should be visible for you furthermore, or if you like to get it as a route point.
      In my understanding, that's it, what you want to get...
      • RainerT
        RainerT
        RainerT
        That's correct.
        I can add a POI from the official POI list, either as a POI alone or as a POI and shaping point. (1)
        These two POIs are then also included in the 'Manage' list under POIs.
        However, it is not possible to transfer a POI from the 'Manage' list as a shaping point.
        The only option is to manually set a waypoint at this location.
        (1)
        (2)
        RT
        • Marinus van Deudekom
          I can understand your wish, but….. if you would place those POI’s automaticly you have realy not a clue if lets say a lunchroom is open.
          RainerT
          RainerT
          Paul Phillips 3
          Paul Phillips 3
          • test Myroute APP
            1.9k
            Hubert Thori
            Hubert Thori
          • Hello from Thailand
            Glenn.B
            Glenn.B
