  2. Routes & Tracks
  3. Sharing downloaded GPX - shows incomplete
12 Posts 6 Posters 2.7k Views 3 Watching
  • Rakesh Raoundefined Offline
    Rakesh Rao
    After creating a route on MRA, i download it (.gpx 1.2) and share it with a friend. When he opens then file, it shows as 'incomplete' - per the screenshot attached. Why does this happen. Sharing the same route via link from MRA opens up correctly on MRA used by another friend.
    MyRouteApp + Navigator (always latest version, Lifetime Gold)
    Garmin Zumo XT
    Riding 2024 Triumph Tiger 1200 RallyExplorer
    • Rakesh Raoundefined Rakesh Rao
      @Rakesh-Rao share the route here and we’ll have a look at it. Make sure it’s set to public
      Rakesh Raoundefined 1 Reply Last reply
        Share the gpx 1.1 file
        • RainerTundefined Offline
          RainerT
          .gpx 1.2 is an proprietary format from MRA.
          So better use a compatible format. See post above.
          RT
            Rakesh Rao
            @Marinus-van-Deudekom
            https://www.myrouteapp.com/en/social/route/11615172?mode=share
            Garmin Zumo XT
              Rakesh Rao
              @Hans-van-de-Ven-MR.MRA
              Does 1.1 behave differently than 1.2?
              Garmin Zumo XT
                Yes, gpx 1.2 is a route-track with via points, so it does needs via points in the file.
                Gpx 1.1 is a route, track and poi’s
                • Guzzistundefined Offline
                  I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing!
                  So, there must me another reason, why the file isn't created correctly.
                    When i save the route as gpx 1.2 the gpx file look normal and complete
                      I’ve looked at your route and saw a few things
                      There’s a lot of shapingpoints that are not ON the route this giving Garmin devices the possibilty to mess up your route.
                      You say that you’re trying to export a 1.2 gpx. That Will only work on a Garmin device. Does your friend have a Garmin. If yes for the 1.2 format the advise is to add a couple of viapoints extra
                      The export of the 1.2 didn’t show up wrong on my end
                      Last
                      I’ve noticed that you set the route to motorcycle a profile that has not a lot Off d’avantages in it so that’s why I only use the car profile.
                        Last
                        @Marinus-van-Deudekom, your observations are probably correct, but neither of them are relevant for the question.
                        @Guzzist said in Sharing downloaded GPX - shows incomplete:
                        I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing! So, there must me another reason, why the file isn't created correctly.
                        I agree
                          Rakesh Rao
                          Bottom line is that I need to share 1.1 if sharing gpx file
                          Thank you all for your help.
                          Garmin Zumo XT
                          RainerTundefined
                          RainerT
                          Rakesh Raoundefined
                          Rakesh Rao
                          • MyRouteApp - Carpuride W712D - Silverfox Bluetooth Controller
                          • Radar alert
                            benet_73undefined
                            benet_73
                          • Voice instructions low
                            Aiello antoninoundefined
                          • Gpx naar mra-route gaat fout
                            Peter Zehentreiterundefined
                            15.5k
                          • Shaping points and Via points
                            RetiredWingManundefined
                            1.9k
                          • Add screen lock to free drive
                            Nick Carthewundefined
                            Herman Veldhuizenundefined
