  2. Routes & Tracks
  3. Sharing downloaded GPX - shows incomplete
12 Posts 6 Posters 3.5k Views 3 Watching
  • Rakesh Rao Offline
    Rakesh Rao Offline
    Rakesh Rao
    After creating a route on MRA, i download it (.gpx 1.2) and share it with a friend. When he opens then file, it shows as 'incomplete' - per the screenshot attached. Why does this happen. Sharing the same route via link from MRA opens up correctly on MRA used by another friend.
    MyRouteApp + Navigator (always latest version, Lifetime Gold)
    Garmin Zumo XT
    Riding 2024 Triumph Tiger 1200 RallyExplorer
    • Rakesh Rao Rakesh Rao
      Marinus van Deudekom Offline
      @Rakesh-Rao share the route here and we’ll have a look at it. Make sure it’s set to public
      Rakesh Rao 1 Reply Last reply
        Share the gpx 1.1 file
        • RainerT Offline
          RainerT Offline
          RainerT
          .gpx 1.2 is an proprietary format from MRA.
          So better use a compatible format. See post above.
          RT
            Rakesh Rao Offline
            Rakesh Rao Offline
            Rakesh Rao
            @Marinus-van-Deudekom
            https://www.myrouteapp.com/en/social/route/11615172?mode=share
            Garmin Zumo XT
              Rakesh Rao Offline
              Rakesh Rao Offline
              Rakesh Rao
              @Hans-van-de-Ven-MR.MRA
              Does 1.1 behave differently than 1.2?
              Garmin Zumo XT
                Yes, gpx 1.2 is a route-track with via points, so it does needs via points in the file.
                Gpx 1.1 is a route, track and poi’s
                • Guzzist Offline
                  Guzzist Offline
                  I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing!
                  So, there must me another reason, why the file isn't created correctly.
                    When i save the route as gpx 1.2 the gpx file look normal and complete
                      I’ve looked at your route and saw a few things
                      There’s a lot of shapingpoints that are not ON the route this giving Garmin devices the possibilty to mess up your route.
                      You say that you’re trying to export a 1.2 gpx. That Will only work on a Garmin device. Does your friend have a Garmin. If yes for the 1.2 format the advise is to add a couple of viapoints extra
                      The export of the 1.2 didn’t show up wrong on my end
                      Last
                      I’ve noticed that you set the route to motorcycle a profile that has not a lot Off d’avantages in it so that’s why I only use the car profile.
                        Last
                        @Marinus-van-Deudekom, your observations are probably correct, but neither of them are relevant for the question.
                        @Guzzist said in Sharing downloaded GPX - shows incomplete:
                        I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing! So, there must me another reason, why the file isn't created correctly.
                        I agree
                          Rakesh Rao Offline
                          Rakesh Rao
                          Bottom line is that I need to share 1.1 if sharing gpx file
                          Thank you all for your help.
                          Garmin Zumo XT
                          RainerT
                          RainerT
                          Rakesh Rao
                          Rakesh Rao
                            303
                            Sytze van der Laan
                            Sytze van der Laan
                            Bruno 7
                            Bruno 7
                            787
                          • Hi again...Please help
                          • Adding a third device to my subscriptions
