  4. Route differences since new update!
23 Posts 7 Posters 8.3k Views 4 Watching
    @stuart-marritt, my belief is that whenever you choose a direct route (straight line and not any of the curvy options) the route should load right away indeed, without the new suggestions. Usually though one of the suggestions (there may be up to three) will be quite similar, which is indeed not in your case. The origin of that is because the first one is calculated on the OSM map, the next one is calculated within the navigation module on the HERE map. This is a hard to understand situation that will be mitigated somewhere in the future.
    BTW: Obviously navigating with recalculation enabled is perfectly fine. I can understand it that some individuals rather want to have it disabled, but it is a bit pity that it gets advised all over the place.
    @Con-Hennekens said in Route differences since new update!:
    Nopes! Fastest route is always calculated by HERE. The route options displayed before starting the navigation (where you see 2 options) should always show the generated route as first option.
    This can be explained by two scenarios: either a mismatch between some HERE services due to traffic or something like that. You having enabled offline navigation.
    @Nomko-Nomden I respect your choice to disable recalculations but that is not relevant at all. We generally recommend it being turned on. I would appreciate you not pushing this setting on other users especially when unrelated 🙂
    • stuart marritt
      stuart marritt
      stuart marritt
      I have have offline maps downloaded but try not to use them if at all possible
      If I have a signal I am always using online maps
        @Corjan-Meijerink said in Route differences since new update!:
        Okay! So calculated by HERE, presented on a OSM map?
        I stand corrected 😉
          @stuart-marritt said in Route differences since new update!:
          If you have offline maps, they will be used whether you have signal or not.
          It is only the calculation of routes that is done online, if you did not enable offline routing explicitly.
          Why would you not want to use offline maps If you have them?
            I was out at the weekend and had no plan
            We popped for breakfast up the road then picked a place to go to and viewed the route before hitting navigate and thought thats not a bad route I will go for that.
            Here is the route
            Upon selecting the route it now gives me two options for two different routes that are nowhere near the same as the one that I had decided to go for?
            See screenshots
            How come routes are so different? and why am I getting options instead of the route that I had already chose to ride?
            Is this a new bug since the update to the scenic route?
            Thanks
            Stu
            @stuart-marritt trying to simulate/re-create your route/situation I get the following
            so I am seeing all 3 of your options
            with the choice to choose routes of 55minutes (your prefered route) & 2 others of 1 hour each
            to me appears for some reason you dont get to see or select all the options, yur choice is presented in a different manner/format
            what device are you using to navigate & what version of mra do you have?
            stuart marritt 1 Reply Last reply
            • Brian McG Brian McG
              stuart marritt
              stuart marritt
              stuart marritt
              @Brian-McG
              That's what I would expect but as per the screen shot it's not what I got!
              I am using a Samsung s20 fe and I always have the latest version installed
              I always check the night before for any updates
              Brian McG 1 Reply Last reply
                @Brian-McG
                Hi @stuart-marritt
                if you now just choose an arbitary destination 30-40 miles from your current location & start navigating the route, what do your options look like, can you screenshot the choices given?
                • stuart marritt
                  stuart marritt
                  stuart marritt
                  I have just picked the same end point as I had the issue on but I am at my home so is a different start location but it now gives me 3 routes
                  • Brian McG
                    in original screenshots it looked like your phone was in landscape mode
                    latest is in portrait mode
                    it is a longshot but somehow somwhere it looks like the original graphic choice screen had a glitch/error & only showed the 2 choices & not your optimal first choice
                      stuart marritt
                      stuart marritt
                      stuart marritt
                      @Brian-McG for reference here is the same in landscape
                      Although I took the original in landscape it was doing the same in portrait too.
                      • Brian McG
                        #17
                        sorry I have no idea how the choice screen can glitch to show only 2 options instead of 3
                        I will leave that question/answer to someone with a bit more knowledge
                        best of luck
                          Works as expected so to see.
                          My reasoning before would be correct then it being a one time thing due to a mistiming at HERE calculations.
                          The orientation has no effect, reloading does as it will recalculate yielding 1, 2 or 3 routes again based on the moment. Usually quite consistent.
                            stuart marritt
                            stuart marritt
                            stuart marritt
                            @Corjan-Meijerink Yes looks as though it was a one time thing!
                            I will keep an eye on it and report back if it happens again
                            • stuart marritt
                              stuart marritt
                              stuart marritt
                              Just want to bring this back up again!
                              Last night I was now no longer get the 3 route options and clicking on the different levels of windyness was showing me almost the same routes!
                              Also it was trying to keep me on the fast straight roads which is the ones I was trying to avoid no matter what settings I used
                              Is there some issues with the planner/scenic route when trying to do point A to Point B?
                              • RainerT
                                RainerT
                                RainerT
                                When planning my routes on the computer, it often happens that Here® simply refuses to take a certain road.
                                This has often irritated or annoyed me.
                                The reason is almost always that part of the route is marked as closed or similar in Here. Unfortunately, this can only be seen when zooming in significantly and when the traffic layer is active.
                                Therefore, turning off traffic-aware routing would be an option when driving. However, this is not possible when planning, as the route is simply not feasible.
                                RT
                                Translated with DeepL.com (free version)
                                • RainerT RainerT
                                  RT
                                  @Rainer-Treichel Hi Rainer. This has nothing to do with the update. Its simply how planning works. You're right with the conclusion that turning on the traffic layer gives you insite. Of you're shure that the obstruction is not a problem you can solve that with the Offroad Jeep sign so that piece will be ignored
                                  • RainerT
                                    RainerT
                                    RainerT
                                    Yo are right, nothing to do with the update.
                                    RT
                                    RainerT
                                    RainerT
                                    stuart marritt
                                    stuart marritt
                                    • F014 WP Numbering illogical
                                    • Map colours and side roads
                                    • OSM Routing with MRA
                                    • F013 Facilities/POIs – A search function covering the entire map is unfortunately missing here.
                                    • GPX POI Editor
                                    • Route MRA importeren in Google Maps
                                      Eric Bovelander
                                      Eric Bovelander
