  4. iOS crashing with Silverfox B8J and panning not working
14 Posts 4 Posters 3.1k Views 3 Watching
  • Thomas Neumeyer
    Thomas Neumeyer
    Thomas Neumeyer
    Hello, my iPhone 11 on iOS 18.5 is not working with native MyRoute app. First panning has not been working with previous iOS but zooming was working. Now the app crashes after the update to 18.5 when trying to connect to controller. Installed app version is 4.3.9-395. Cant use the app with this phone. Android tablet works without any issue. Any special settings required on the phone? Bluetooth found the controller. Regards Thomas
    Corjan Meijerink Nick Carthew 2 Replies Last reply
    • Thomas Neumeyer Thomas Neumeyer
      @Thomas-Neumeyer definitely not anything special required as long as you have “SilverFox” selected as input device in the settings.
      But the app crashes when connecting the controller? No idea what that is.
      I’ve connected tons of controllers to iOS and never experienced this (along with many users).
      I do recall someone on the forum reporting something like this long ago but perhaps other users here can find those details 🙂
      • Thomas Neumeyer
        Thomas Neumeyer
        Thomas Neumeyer
        Hello Corjan, I will try my regular iPhone. And the setting was on Silverfox. Thomas
          @Thomas-Neumeyer I have exactly the same set up as you iPhone 11 and B8J controller. I have no issues at all, everything works perfectly.
          • Thomas Neumeyer
            Thomas Neumeyer
            Thomas Neumeyer
            Thats good to hear. I will remove all unnecessary bluetooth connections and check if something is interfering the system. Will report later.
            • Thomas Neumeyer
              Thomas Neumeyer
              Thomas Neumeyer
              Hello, I compared the settings of the two phones. On the first phone with the strange behavior there was the external keyboard enabled because I was playing some time ago with different controller and Osmand. After changing this setting MyRoute is working fine. No issues anymore. Thomas
                Could you elaborate a bit more (perhaps with a screenshot) what exactly was causing the issue? This for future reference 🙂
                Glad it all works again!
                • Thomas Neumeyer
                  Thomas Neumeyer
                  Thomas Neumeyer
                  wrote on last edited by Thomas Neumeyer
                  Hope this works.
                  • Thomas Neumeyer
                    Thomas Neumeyer
                    Thomas Neumeyer
                      Merci! 🙂
                        Merci! 🙂
                        @Thomas-Neumeyer
                        Hey you,
                        Yes, that's exactly my experience for a long time, I drive with the Remotek One as Corjan may still know, and after longer attempts this is my solution.
                        iPhone Xr : Settings / Conditional Aids / Keyboards & Text Input /
                        Solution = Keyboard control OFF
                        • MyRouteApp without problems !!
                        • Remote click on radio does not work
                        • I can't control the Kurviger app
                        • I can't control GuRuMaps then
                        Note = with keyboard control ON
                        • MyRouteApp crashes ?
                        • Curvy goes !!
                        • GuRuMaps goes !!
                        • Remote switch to player goes !!
                        Actually, it should be the case that you set the keyboard control to ON, that would actually make more sense, at least from the point of view of the extended Remotek One possibilities .... And the other apps.
                        VG 👋
                        Hey ihr,
                        ja genau das ist auch schon länger meine Erfahrung, ich fahre mit der Remotek One so wie Corjan ja vielleicht noch weiß, und nach längeren Versuchen ist das meine Lösung.
                        iPhone Xr : Einstellungen / Bedingungshilfen / Tastaturen & Texteingaben /
                        Lösung = Tastatursteuerung AUS
                        • MyRouteApp ohne Probleme !!
                        • Remotek Klick auf Radio geht nicht
                        • Kurviger App kann ich dann nicht steuern
                        • GuRuMaps kann ich dann nicht steuern
                        Hinweis = bei Tastatursteuerung EIN
                        • MyRouteApp stürzt ab ?
                        • Kurviger geht !!
                        • GuRuMaps geht !!
                        • Remotek Umschaltung auf Player geht !!
                        Eigentlich sollte es doch so sein das man die Tastatursteuerung auf EIN einstellt, das würde eigentlich mehr Sinn machen, zumindest aus Sicht der Remotek One erweiterten Möglichkeiten …. Und der anderen Apps.
                        VG 👋
                        • Hubert Thoring
                          Question: why does the keyboard control have to be set to "OFF" on an iPhone (iOS) so that the MRA does not crash, there is an explanation from the point of view of MRA programming.
                          It would help, should it stay that way, it should be included in the MRA user description.
                          VG
                          Frage : warum muss bei einem iPhone (iOS) die Tastatursteuerung überhaupt auf „AUS“ stehen, damit die MRA nicht abstürzt, gibt es eine Erklärung dazu aus Sicht der MRA Programmierung.
                          Es würde helfen, sollte es so bleiben sollte es in der MRA Anwenderbeschreibung mit aufgenommen werden.
                          VG
                            VG
                            VG
                            @Hubert-Thoring No clue 😛
                              @Corjan-Meijerink 😂 Like .. I don't think
                              Thomas Neumeyer
                              Thomas Neumeyer
                              • Beta Navigation V.6
                                44
                              • Carplay vehicle location/arrow in wrong place
                              • Route overlay
                              • Save locations/positions
                              • How do you navigate off-road routes with Next?
                              • Versie 6 van Navigation Next app
                              • Group ride
                              • Opgeslagen routes met TOMTOM kaart laden niet meer.
