  3. [App] Announcements
  4. New update! (4.3.7) - Track navigation improvements and CP / AA zooming
42 Posts 14 Posters 27.8k Views 6 Watching
  • Léon Hassing
    Léon Hassing
    Léon Hassing
    wrote on last edited by Léon Hassing
    @Corjan-Meijerink said in New update! (4.3.7) - Track navigation improvements and CP / AA zooming:
    Fullscreen mode is now a preference (Navigation settings > screen layout)
    What is the difference between enabling and disabling this setting? The i-text says "Fullscreen mode: Hides notifications and the bottom app bar" 😕
    JP d 1 Reply Last reply
    • Jörgen
      A friend has problem on his Android Phone.
      Black screen and this.
      • Léon Hassing Léon Hassing
        JP d
        JP d
        JP d
        @Léon-Hassing if this setting is on I can't see the top (Status bar) on my phone this is where you see how much charge you left, 4g, the time and any notification icons.
        On my Android you can use gestures to navigate swiping or you can use buttons (back, home and recent apps).
        If full screen is on I can't see the top status bar nor the navigation buttons.
        Léon Hassing 1 Reply Last reply
        • JP d JP d
          Léon Hassing
          Léon Hassing
          Léon Hassing
          @JP-d Thank you for your response. That may be the reason why I didn't see any differences. I always use Android Auto and not my phone.
          • Jörgen
            More Information to my post from yesterday.
            App Version: 4.3.7 385
            Phone Samsung A51 4G
            Android Version: 13 One U.I 5.1
            No maps seen and tracking does not work.
            • Henk Oskam
              Henk Oskam
              Henk Oskam
              Hi, I have testend it on a different tablet.
              Samsung Tap A running on Android 14, UI 6 and then it is working.
              So the problem is I think Android 13 or UI 5.
              Hope it wil be fixed because the Tablet active 3 is integrated in my bike!
              Henk Oskam
              Www.hposkam.nl
              • CHRISTOPHER TOOP
                CHRISTOPHER TOOP
                CHRISTOPHER TOOP
                Can I add to this, since updating to this version on my Android Samsung phone yesterday, I no longer have a map display at all. All menus are there, as far as I can see, but no maps and hence no live tracking.
                What has gone wrong, all was fine until I did the update.
                My Samsung is an older S9 'Edge' running Android version 10.
                  Today a ride with the 4.3.7 version.
                  This version looks more and stable and smooth when riding.
                  But i don't see much diference in the autozoom functioniality. It stays more or less on the same zoom level regardless the driving speed.
                  Is this correct?
                  • Gaetano 9
                    Gaetano 9
                    Gaetano 9
                    I confirm... The zoom only works manually, not in relation to speed or intersections. Yet it is active in the options. It should be fixed to avoid zooming manually on a motorcycle. I would add that there is not always a warning of major slowdowns on the highways. It even recommends detours, for major slowdowns, where there are none. Still needs to be fixed a bit.
                    Google traslate.. 😊
                    • Nick Carthew
                      @M-Schrijver @Gaetano-9 What camera view are you using? Automatic zoom does not work with top down view. Adjust the camera view by tapping the compass.
                      Gaetano 9 1 Reply Last reply
                        What camera should i use?
                        I do not think i use top down
                          @M-Schrijver North up and dynamic both have automatic zoom.
                            Than it does not work in Android Auto.
                            In the settings are 4 options:
                            • Off
                            • Speed related
                            • Direction related
                            • Both
                            I use "Both" with dynamic zoom.
                              • Off
                              • Speed related
                              • Direction related
                              • Both
                              @M-Schrijver Camera view has 3 options. Top down, north up and dynamic. You adjust the camera view by tapping the compass, it is not in the settings. Your camera view choice is stored and will be used next time until you change it.
                              You see a notification each time you tap the compass that tell you which camera view is active and what zoom is available. My example shows top down is chosen and it is fixed zoom level.
                                #26
                                Yes, i know.
                                The "compass" is set so dynamic.
                                But in the settings are some settings which tells how the autozoom should behave. That one i've set to "Both"
                                  Yes, i know.
                                  @M-Schrijver Have you tried adjusting your default zoom correction? I have mine set to +0.0 which works for me.
                                    #28
                                    I did but i see very little changes. The global zoomlevel changes. But the range of zoom level does not change. The range of zoom level is very limited.
                                    I don't have real figures about the zoom level. So i will use examples.
                                    What it looks like to me at the moment
                                    Maximum zoomed out (at 100 km/u) is 1 cm on screen is 200 meters in real. Maximium zoomed in (at slow driving or stop) is 1 cm on screen is 150 meter in real.
                                    What I expect?
                                    At 100 km/u. 1 cm on screen is 200 meters in real.
                                    At 30 km/u/stop. 1 cm on screen is 30 meters in real.
                                      Gaetano 9
                                      Gaetano 9
                                      Gaetano 9
                                      @Nick-Carthew ....
                                      Today I checked and used all the possible settings. The automatic zoom does not work on AA but on the cell phone yes. Even with Google maps. On a motorcycle the automatics are important, if it is not possible I will switch to a Tablet or a dedicated cell phone.
                                      • Gaetano 9 Gaetano 9
                                        @Nick-Carthew ....
                                        Léon Hassing
                                        Léon Hassing
                                        Léon Hassing
                                        I can confirm that the automatic zoom does not work in the new version on AA. With the same camera modus as I used in older versions and were it zoomed, it does not do now.
                                        Also I experience that when I have used the new zoom buttons they remain on the screen. Because of this also the stop button overlays the maximum velocity sign.
                                        LR 1 Reply Last reply
                                          LR
                                          LR
                                          LR
                                          wrote on last edited by LR
                                          #31
                                          Also bei mir funktioniert es jetzt endlich! Ich hatte bei den vorherigen Versionen das gleiche Problem.
                                          Es ist aber ein bisschen tricki! Man braucht die richtigen Einstellung.
                                          Den Standard Zoomfaktor in den Einstellungen habe ich auf -2. Zoomanpassungen auf Aktiviert.
                                          Der Kompass steht auf Dynamisch.
                                          Jetzt kommt es, mit der neuen Schaltfläche kann man zwischen manuellen und automatischen Zoomen umstellen. Wenn man die + und - Tasten sieht ist man im manuellen Modus! Hier wird nicht mehr auf die Kreuzung gezoomt.
                                          Wenn man wieder die ganz unten rechte Taste drückt ist man wieder im automatischen Modus und es wird rein und raus gezoomt. Hat mich auch eine Weile fummeln gekostet!
                                          @Admins
                                          Bei der Version wird der Akku bei Android Auto extrem warm. Bitte unbedingt korrigieren!
                                          Danke Lutz
                                          MartinW
                                          MartinW
                                          JP d
                                          JP d
                                          Léon Hassing
                                          Léon Hassing
                                          OGRIII
                                          OGRIII
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Gaetano 9
                                          Gaetano 9
                                          Henk Oskam
                                          Henk Oskam
                                          LR
                                          LR
                                          CHRISTOPHER TOOP
                                          CHRISTOPHER TOOP
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
                                            162
