  4. Remotek-One Exchange of experiences
105 Posts 11 Posters 88.5k Views 8 Watching
  • Lynchy67 Lynchy67
    @Hubert-Thoring
    Wow! are your issues still not resolved.
    If I remember correctly you had an issue with the Remotek One not working using the Remotek One Input within MRA.
    I believe that you had to use the Standard Import Setting instead!
    That right there seems like a defect to me.
    You should insist they send you another Unit.
    @Lynchy67 : Ich bin dran, Dag hat Urlaub, wollte mir zuvor aber noch ein Update schicken ... also abwarten.
    Lynchy67 1 Reply Last reply
      Lynchy67
      Lynchy67
      Lynchy67
      @Hubert-Thoring
        @Hubert-Thoring I am sorry, my experiences remain the same.
        No crashes ever 🙂
        @Corjan-Meijerink : Hello Corjan, Sorry, that's what Dag is writing now, it's a shame that he probably won't be able to contact you by email.
        Is that possible?
        Here is the email copy from today:
        Hi Hubert
        Sorry for the delayed feedback, but I have been a lot off grid for a long time and at the same time had a lot of work to do.
        Anyway, my feedback is this:
        The crash. This is and will always be a MRA issue. Nothing I can do about it. It crashes in iOS here too with the latest release. If MRA can´t handle an external controller which every other app with external control handles well (not a single crash in Guru Maps, Osmand and others), then they must do something about it. However, they don´t respond to my emails, and very few users use MRA. I bet they will solve it one day though.
        So I recommend for now to switch to for example Guru Maps, an excellent map software with all functions on the remote available.
        Kind regards
        Dag
        Dag Jenssen - Remotek AS
        dag@remotek.no
        Tlf +47 995 47 284
        www.remotek.no
        Wireless controllers for iOs and Android
          @Corjan-Meijerink Hey Corjan, das habe ich heute zufällig beim weiteren testen festgestellt,..
          MRA mit iOS und mit meiner Remotek One (286)
          • Schalte ich unter iOS unter Bedienungshilfen die Tastaturhilfen „Aus“ dann gibt es keinen MRA Absturz mehr. 😎
          Es scheint eine Kollision zu entstehen unter iOS wenn man im allgemeinen MRA Menü ist, und die Tastaturhilfen „Ein“ geschaltet ist.
          • mit Tastaturhilfe „Aus“ geht es jetzt mit der Remotek One so wie ich es brauche, da ohne Absturz. Im Eingabemodus Remotek One oder Standart, fehlt mir zur Zeit noch das Zentrieren aber das macht die MRA ja nach kurzer Zeit auch selbst, wenn man keine Eingabe mehr macht.
          @Corjan-Meijerink :
          • wie war das bei deinem Test mit deiner Tastatur, war die Tastaturhilfe eingeschaltet ?
          • Könnte der Absturz vielleicht doch auch noch ein Thema bei iOS und der MRA in diesem aufgezeigten Fall sein ?
          Hinweis:
          Da Dag im Urlaub ist werde ich im das auch noch einmal per Mail mitteilen.
          @Hubert-Thoring said in Remotek-One Exchange of experiences:
          @Corjan-Meijerink :
          Hinweis:
          @Corjan-Meijerink : Gibt es hier zu dem was Dag schreibt einen möglichen Zusammenhang, denn meine Remotek One geht mit allen anderen Apps auch bei mir ohne Absturz, auch wenn die Bedienungshilfe, hier dann die Tastatursteuerung "EIN" geschaltet ist. Es ist irgendwo der Fehler aber ? Bitte sprecht doch mal mit Dag darüber. VG
            Nice how nobody wants it to be their issue.
            Fun fact, I've never received an email from him or a support ticket.
            Not sure how (or even if) he contacts us 😉
            I have the Remotek device, use iOS and have no crashes.
            Other bluetooth controllers do not crash the app 🙂
            There is something wrong but he doesn't seem to collaborative about it.
            Might be us, might be the device.
            I suspect the latter, he the first 😉
            Hubert Thoring Lynchy67 2 Replies Last reply
              @Corjan-Meijerink : ich sitze da wohl zwischen zwei Stühlen 😥
              • Hubert Thoring Hubert Thoring referenced this topic on
                Lynchy67
                Lynchy67
                Lynchy67
                And just for further clarification I have no issues with the Remotek One on Android.
                Hubert Thoring 2 Replies Last reply
                • Lynchy67 Lynchy67
                  @Lynchy67 : Which No. Xxx does your Android BT Remotek One xxx have.
                  When pairing, the number is displayed.
                  • Lynchy67 Lynchy67
                    #20
                    @Lynchy67
                    Hiermit s. Bild, geht es jetzt bei mir aktuelle ohne MRA Absturz, mehr brauche ich nicht, dann in der sauberen iOS gesamten MRA Anwendung.
                    BT Kopplung:
                    • Remotek One und MRA
                    • In der MRA Einstellung Eingabe Standart
                    • iOS Remotek One Tastatur.
                    Dabei ist es zwingend notwendig die iOS Bedienungshilfe / Tastatursteuerung auf „AUS“ zu stellen.
                    Dann geht es in MRA fehlerfrei bei der Navigation oder auf bei den normalen Karten sehr gut.
                    Funktion:
                    • Karte rechts, links, oben, unten
                    • „-/+ Zoomen
                    Schalte ich im iOS am Handy die Tastatursteuerung EIN, dann geht einiges mehr, aber nur innerhalb der MRA Navigation, aber außerhalb der MRA Navigation stürzt die MRA ab.
                    Andere Apps lassen sich dann auch ohne Absturz damit gut bedienen, dazu muss diese Tastatursteuerung EIN sein.
                      @Lynchy67
                      BT Kopplung:
                      Funktion:
                      • „-/+ Zoomen
                      #21
                      Hallo zusammen,
                      ich hab ja schon länger das Remotek One mit einem iPhone Xr im Einsatz, dieses immer noch mit der Version 1.x.x.
                      Mit der neuen MRA Version ab V4.3.6 geht es jetzt sehr gut, auch das WP überspringen geht jetzt mit meiner Lösung.
                      Wichtig: Unter Einstellungen am iPhone !!
                      • Unter : Bedienhilfen \ Tastaturen & Texteingabe \ die Tastatursteuerung auf "Aus" zu stellen. Ich habe sonst das Problem das die MRA außerhalb der Navigation abstürzt. Mit der aber hier gewählten Einstellung auf "Aus" geht es immer sehr gut.
                      Bei der MRA Eingabeeinstellung, dann als Remotek One geht folgendes sehr gut, dabei ist aber darauf zu achten das die BT Remotek One Tastatur auf iOS steht heißt, die zwei Pfeiltaste oben unten zusammen drücken und warten ob es kurz rot, grün für iOS blinkt, bei grün, grün muss man es noch einmal wiederholen dann kommt das kurz rot, grün blinken. "rot, grün steht für BT Taste als iOS" denn "grün, grün steht für BT Taste als Android.
                      Ergebnis bei meiner Anwendung in der MRA Navigation unter iOS:
                      • Pfeile "links, rechts, oben, unter," über die Karte schwenken.
                      • Pfeil "+" / "-" entspricht dem Zoomen
                      • Pfeil DC rechts, zwei mal kurz klick dann loslassen, = WP überspringen.
                      • und weitere Funktionen die beschreibe ich aber separat....
                      Wichtig sind die richtig gewählten Grundeinstellungen, wenn das oben beschriebene nicht gehen sollte muss die BT Tastatur einmal resettet werden indem man "Pfeil oben, und + und - " gleichzeitig für mehr als 5sek. drückt, bis es rot blinkt. Danach auch die Kopplung unter BT im iPhone löschen und neu am iPhone koppeln. Danach dann wie oben beschrieben für iOS einstellen usw.
                      Viel Erfolg, ich bin für meine iOS Lösung damit sehr zufrieden.
                      VG aus Münster
                        Hallo zusammen,
                        VG aus Münster
                        @Corjan-Meijerink : Diese Funktionen s. Datei im Anhang, kann ich seit der MRA V 4.3.6 nutzen. So bin ich mehr als begeistert.
                          Glad it all works well now!
                          • Hubert Thoring
                            #24
                            Hey,
                            da gibt es ein Angebot .. mit 15% Rabatt.
                            Ich würde es mir immer wieder kaufen, ich bin damit mehr als zufrieden, gerade mit der MyRouteApp optimal.!!!!!!
                            Link zur Remotek Web Seite
                            Hey,
                            There is an offer .. with a 15% discount.
                            I would buy it again and again, I am more than satisfied with it, especially with the MyRouteApp optimal.!!!!!!
                            CD130 1 Reply Last reply
                            • silberfuchs67
                              silberfuchs67
                              silberfuchs67
                              Danke für den Hinweis! Kurze Frage zur Montage des Controllers an meiner R1300 GS. Wo kann denn der Controller mit der mitgelieferten Standardhalterung montiert werden oder bedarf es einem Eigenbau oder der zusätzlich angebotenen Halterung?
                                Hey,
                                Hey,
                                @Hubert-Thoring Thank you for sharing the discount. Just ordered a remote👍
                                • silberfuchs67 silberfuchs67
                                  #27
                                  @silberfuchs67
                                  Ich würde sagen bau dir ein passendes Blech s. Bilder, die Spiegel sind ähnlich wie bei der R1250GS montiert da wird das vielleicht passen was ich mir mal gebaut habe.
                                  Original:
                                  Es sind zwei Halterungen für den Lenker dabei, das im Web sind die gleichen, aber für z.B. ein zweites Bike damit man die Remotek One einfach ans andere Bike machen kann.
                                  Montage :
                                  Am Anfang hatte ich es einfach am Spiegelarm aber war nicht so optimal,
                                  Prototyp: Position usw. danach dann optimiert und lackiert
                                  Info zum Cradel:
                                  Habe mein Cradel mal senkrecht montiert, mit einer kleinen einfachen Lösung, dazu fehlt noch das Montage Foto 😉
                                  • Hubert Thoring
                                    #28
                                    MyRouteApp und Remotek One, Navi Lösung senkrecht installiert.
                                    Video zur Ansicht und Bedienung 👋
                                    • silberfuchs67
                                      silberfuchs67
                                      silberfuchs67
                                      So, bestellt mit dem derzeitigen Nachlass. Bin gespannt …
                                      • Hubert Thoring
                                        Bei Fragen melden, welches Bike fährst du noch mal ?
                                        • silberfuchs67
                                          silberfuchs67
                                          silberfuchs67
                                          Danke, fahre die R1300 GS.
                                          • 4
                                          • 5
                                          • 6
                                          MartinW
                                          MartinW
                                          ConiKost
                                          ConiKost
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          Westerwald_Rider
                                          Westerwald_Rider
                                          Lynchy67
                                          Lynchy67
                                          • How can I change colours in the route overview?
                                            Kudee
                                            Kudee
                                          • Sharing live location with friends on Android Auto problem
                                          • Next: Ich brauche Hilfe zu POI und Favoriten!
                                          • Newsletter optimisation
                                          • Skip feature in the MRA Classic
                                            TomOnTour
                                            TomOnTour
                                          • Planner: Convert batches of shaping points into via points and vice versa
                                          • Ability to hide all waypoints at once after planning?
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Weather: rain colors
