  4. Adding waypoints along route (in app)
waypointsappplanning
5 Posts 4 Posters 2.4k Views 2 Watching
  • HeadJ Offline
    HeadJ Offline
    HeadJ
    Unless I’m mistaken, it is only possible to add waypoints to a route within the app at the end of a route? Unlike on the web planner, I can click on the route line to add a waypoint between other waypoints.
    100% planning on the web planner is easiest and best experience, but sometimes you want to adjust a route from the phone!
    • HeadJ HeadJ
      Corjan Meijerink Offline
      @HeadJ in the app you can tap on the line where you want to add the intermediate waypoint.
      That is, assuming you are using the in-app routeplanner.
      Otherwise add a screenshot of what you are doing šŸ™‚
      HeadJ 1 Reply Last reply
        HeadJ Offline
        HeadJ Offline
        HeadJ
        @Corjan-Meijerink Hi Corjan, Perhaps what I mean to say is, adding a waypoint, such as a newly found hotel, which is not exactly on the route itself as a waypoint.
        adding a waypoint by clicking on the map just adds that waypoint to the END of the route, even though it may be wanted between waypoint/shaping point 4&5, if it is added to the end on a long route, and is now point 80 - it is a lot to move it up the order.
        This is easier on the webplanner - I click on the route then drag, but admittedly I find that also a little annoying but not bad at all - I can see the benefits of it being arranged that way.
        • HeadJ HeadJ
          Nick Carthew Online
          Nick Carthew Online
          @HeadJ said in Adding waypoints along route (in app):
          Tap the route line close to the hotel to add a new sequential route point and once added move the new route point to the hotel.
          • Next Stop Offline
            Next Stop Offline
            Next Stop
            For me it seems to add the waypoint at the end if the new point is further away then the original destination and before it if it is closer.
            I see the logic behind this but it would be handy to be able to choose.
            If you click on the list of waypoints when travelling it would be good to be able to re-arrange the list.
            In the example, I set my destination as home but added the Academy, as the Academy is further away it was added to the end. But I'd like to go their first, then go home. So to be able to re-arrange the order would be a good addition.
            Next Stop
            Next Stop
            HeadJ
            HeadJ
            • Update 5.2.2 - Quick fix
              Emanuele 5
              Emanuele 5
              1.5k
              Michele Skipper
              Michele Skipper
              522
            • Suggestion: Fully lossless export/import format
            • brug bij Nijkerk in de A1
              10.4k
