  4. Expert Review of route
26 Posts 7 Posters 13.4k Views 3 Watching
  • richtea999 richtea999
    [not an expert, but like to give an opinion... 🤔 ]
    What happened to lunch?! 😋
    Points look nice and accurate, and not positioned too close to junctions, etc. Good work there.
    If you set a realistic start time like 9:00 that always helps gauge progress, and when you might want to stop for a rest/petrol, etc.
    If you're riding with others then check around point 40 for TomTom users - they may get sent a different way (west towards Afton and then north to McCormick Gap Overlook Calf Mountain Overlook - which could be a nicer alternative route, but I don't know the area).
    Greenham
    Greenham
    Greenham
    @richtea999
    Thanks for looking at what I had.
    This is just day 1 of the trip. Day 2 I stay and do some sightseeing , and day 3 I haven't posted yet. I wanted to use the advice on this segment.
    I thought about the route you highlighted. But this goes through some of the hard hit areas from last years Hurricane. Thats why I avoided getting onto the BRP sooner.
    I'm traveling solo and basically any fuel stations after 100 miles is getting a visit
      @Greenham
      Use maximum 28 via points in a route otherwise the XT will split the route
      Why all green points?
      Greenham
      Greenham
      Greenham
      @Hans-van-de-Ven-MR-MRA
      This brings me back to the GARMIN ZUMO XT and how it reacts to these routes.
      When you import the route and then start the route it "calculates" the route based on its own Garmin algorithms.
      As I understand Via vs Shaping points. Garmin IGNORS Shaping points and ONLY cares about VIA points during its calculations when importing the route. That why so many VIA points.
      I'm trying to stay on a fairly specific set of roads. If I reduce VIA points won't/can't Garmin then pick the roads that will most quickly get me to the next VIA point.?
      Maybe I have it wrong
      • Greenham Greenham
        @Greenham
        Shaping points (soft points) can be skipped without the Garmin sending you back to a skipped shaping point.
        You must visit via points (hard points) or skip them manually.
        Only start a route if you:
        Have a connection with at least 3 satellites,
        Are on the route or are close to the route.
        Never start a route in the garage or at the kitchen table, because then the Zumo has to calculate to your starting point.
        Again, use a maximum of 28 via points and place them at critical points or where you want to stop. For the rest, just use shaping points. I myself use a maximum of 7 via points in my route and form the route with sufficient shaping points.
        Greenham 1 Reply Last reply
          @Greenham
          Greenham
          Greenham
          Greenham
          Thank you,
          I can reduce the hard points and use more soft points.
          But
          QUESTION .... Does the Zumo XT use the soft points when its calculating the route using the route I want to take.
          HABVEN aka MrMRA Marinus van Deudekom 2 Replies Last reply
          • Greenham Greenham
            Thank you,
            But
            @Greenham
            Yes
            • Greenham Greenham
              Thank you,
              But
              @Greenham The XT has a nasty habbit of thinking it can make a better route then the one you planned. To force the XT to do what YOU want add extra shapingpoints. Use the compare function in the planning mode to see what TomTom and OSM do whit your route. It gives you a small inside of what might happen to your route if you didn't put in enough shapingpoints
              • Guzt
                Guzt
                Guzt
                wrote on last edited by Guzt
                • only use shaping points (hands) where relevant (fuel stop, coffee stop, lunch stop etc...) and use different colours accordingly.
                • once your route finished with the car activity profile using the HERE map set, optimise it by changing route calculation from fastest (standard) to shortest and adjust to original. Switch back to fastest and adjust again if necessary.
                • if wanted, now you may switch to the TT map set and do the same.
                • use the gpx 1.1 (route, track poi) for your XT.
                • you can leave the recalculation mode on your Garmin device to automatic without any problem.
                Nick Carthew Marinus van Deudekom Greenham 3 Replies Last reply
                • Guzt Guzt
                  @Guzt
                  Just for clarity, Via points are hand shaped not shaping points.
                  • Guzt Guzt
                    @Guzt If you use recalculate on on the XT you're in for trouble. sooner or later the thing will for shure mess up your carefully planned route. The XT has a will of its own. So my advise is leave it of.
                    when using the 1.2 export using the Drive app. The route, witch must have some viapoints in it, will be shown on your XT. I alway project the track witch comes automaticly with the 1.2 export under the route so if you deviate dfrom the route you can still come back to the route using your eyes. If you have recalculate on, that would bee the chance for the XT to mess up your route and believe me it will for shure.
                    have fun
                    Guzt 1 Reply Last reply
                    • Guzt Guzt
                      Greenham
                      Greenham
                      Greenham
                      @Guzt said in Expert Review of route:
                      #1 Shaping vs Via points. Got that. Only use VIA points where you actually want to stop.
                      #2 Heres where I get confused by your comment, I started with the motorcycle profile and the (Here) default. How do I optimize changing from fastest to shortest
                      I don't understand the back and forth of fastest and shortest
                      I have compared the route with TT in the past
                      #3 I just learned from you guys recently to use GPX 1.1
                      #4 I understand the Leave recalculation on the Zumo to automatic
                      Guzt 2 Replies Last reply
                      • Greenham Greenham
                        Guzt
                        Guzt
                        Guzt
                        @Greenham download this document from my google drive for full explanation
                        [link text]https://drive.google.com/file/d/1Zwt-5yrJSFWJCLw-997z3XFbFyAUY6en/view?usp=drive_link(link url)
                          have fun
                          Guzt
                          Guzt
                          Guzt
                          @Marinus-van-Deudekom Did I mentioned to use 1.2? Don't think so.
                          Greenham Marinus van Deudekom 2 Replies Last reply
                          • Greenham Greenham
                            Many have helped me understand the Garmin Zumo XT and GPX 1.1 vs 1.2 which has been very helpful.
                            A few helped me through a "seasonal closures" routing issue.
                            I have completed the Day 1 of what will be a 3 day trip in June. Would anyone be willing to review it and offer any suggestions? Good, Bad or indifferent?
                            https://www.myrouteapp.com/route/open/10473886
                            Greenham
                            Greenham
                            Greenham
                            @Greenham
                            This is great. I won't pretend to understand why you have to save as a track, then load it and compare with the Route, but I will do it.
                            In the Motorcycle profile it does allow me to route optimize. Or is it doing nothing.
                            I used Chat GPT to create an English version if you want it.
                            THANK YOU AGAIN
                            • Guzt Guzt
                              Greenham
                              Greenham
                              Greenham
                              @Guzt
                              You say in the doc when downloading to Garmin to do it in. 1.1 format
                              • Greenham Greenham
                                Guzt
                                Guzt
                                Guzt
                                @Greenham In the toolkit under optimize you have the possibility to change the route calculation. That option is only available in the HERE map set when you make your route using the car/auto mobile profile.
                                You can either add a copy of the route (hamburger menu - routes - add) or make the track underlying (which I prefer) visible as reference (I already have an uploaded track of the route as I make all my routes mostly in Basecamp).
                                When one recalculates with shorter distance e.g. the route will differ from the original. By dragging the recalculated route to the track or reference route, you force the route to follow the original as intended. Hence the reason that one can leave auto-calculation to on on the gps when using gpx 1.1
                                Greenham 2 Replies Last reply
                                • Guzt Guzt
                                  Greenham
                                  Greenham
                                  Greenham
                                  @Guzt
                                  Thank you again. I finally did it. I used your steps and saw 1 or 2 places that the track and the rote did not align. Fixed that, changed to shortest, no issues, exported to my Garmin in 1.1 Route.Track.POI
                                  I've learned a much from you. Thank you
                                  Mike
                                  Here is the English version of your instructions
                                  https://drive.google.com/drive/folders/1khcVV8Wp56ploC0WzzSaf3bm-no57mve?usp=drive_link
                                  • Guzt Guzt
                                    @Guzt exactly that would be my advise
                                    I see that you still use Basecamp from way back when. Keep up with up progressive planning of MRA and make the world a bit more beautifull
                                    • Guzt Guzt
                                      Greenham
                                      Greenham
                                      Greenham
                                      wrote on last edited by Greenham
                                      #22
                                      @Guzt
                                      1 last question.
                                      What do you do when the tracklog and the route don't line up, but you want to KEEP the route. I can't move the Tracklog to match.
                                      Will the Garmin follow my route or the tracklog?
                                      This is the issue with GPS's and Motorcycles. If you want to take a more scenic route will the GPS let you?
                                      Mike
                                        Greenham
                                        Greenham
                                        Greenham
                                        Here is an example of what you are talking about. using @Guzt Workflow and using Tracklogs to compare your DESIRED route to the Tracklog I get these anomalies
                                        Clarksville 12025-01-30 114939.png Clarksville2 12025-01-30 114939.png Clarksville3 12025-01-30 114939.png
                                        Notice the gray line is the Tracklog the dark line is my preferred route of travel. Will these Tracklogs be the route the Zumo will take me?
                                        Finally I have this anomaly with a Tracklog/Route comparison.
                                        I've tried all kind of fixes like moving shaping points adding Via points, still get this odd occurrences. The Tracklog is Red, the route is black.
                                        • Greenham Greenham
                                          @Greenham Did you get those anomalys when switching between shortest en fastest?
                                          That can only be done using the Car profile. In the bike profile you don't have that choise.
                                          For planning I stricktly use the car profile.
                                          I compare the prefered route (planned in the Here map) with the TomTom and OSM maps and make shure adding extra shaping points to the route when there's an anomaly. Then in the end when I'm satisfied and the 3 maps are alike I transfer the route to the XT, using the Drive app.
                                          I don't use any avoid items in the planner and I dopn't use any in the XT. That way the route stays the same. Make sure that recalculating in your XT is OFF.
                                          Why: although there's a lot of different opinions on this theme, if you deviate from the route, let's say there's roadworks going on and the route is blocked, and you have recalculate ON, the XT will break free from its harness, the route, and grab it's change to change your route. There's a 100% garantee that it will mess up your rouite.
                                          If you want us to say something about the anomalys you've mentioned, share such a route here and make shure it's set to public.
                                          have fun
                                          Guzt
                                          Guzt
                                          Greenham
                                          Greenham
                                            150
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                            125
                                          • SilverFox Controller C2
                                            Hans Lamers
                                            Hans Lamers
                                          • Website update - Trip book PDF, route lock for collaborators, a close button in the planner and more
                                          • Startpunt wijzigen
