  3. [App] Announcements
  4. New update! (4.3.6) - offroad waypoints
32 Posts 11 Posters 18.1k Views 3 Watching
  • Rob Kelley Rob Kelley
    @Nick-Carthew ah that one, I am just playing it that now, I was looking for a button saying 'off road' ๐Ÿ™‚
    From what I can see, it doesn't route or count the mileage between this and the previous point.
    Rob Kelley
    Rob Kelley
    Rob Kelley
    @Rob-Kelley What's that four point arrow button to the right of the Bin? I don't have that and not seen it before.
    GSA1250
    HD Street Glide
    XT500 x 2
      @Rob-Kelley Correct, time and distance calculations between the two route points are turned off when skip is used.
        @Rob-Kelley said in New update! (4.3.6) - offroad waypoints:
        Thatโ€™s turns on a set of crosshairs for moving a route point on a touch screen (phone in my case).
        I touch the cross, crosshairs appear and I move the map around until the position I want is under the crosshairs and then I tap the move button.
          Hi all! ๐Ÿ™‚
          It is time for a new update! ๐ŸŽ‰
          This version is all about the support of offroad waypoints!
          Offroad waypoints
          Within the online MRA Routeplanner you can very conveniently mark some waypoints as "offroad". The main idea behind this is to skip a section of road that is unknown to the selected routing engine (HERE / TomTom / OSM). Ideal to avoid roads marked as closed (either seasonal or long term damaged) or things such as ferries.
          The app had no idea how to work with these "offroad" waypoints and just treated them as normal ones. Causing the route to be different than planned ๐Ÿ˜ž
          As of now, the app does support the offroad waypoints! ๐Ÿ˜
          In the planner you can edit any route you like and mark any waypoint as offroad! Just as in the website.
          If you then choose to navigate a route with offroad waypoints, you will see straight lines on the offroad sections. Just as planned! ๐Ÿ˜ƒ
          These sections will be made extra clear with a nice dashed line.
          While navigating over an offroad section, some things are however different:
          • No visual instructions
          • No audio instructions
          • Possible loss of ETA information
          • Automatic recalculations disabled
          You don't need them anyway, as you're offroad.
          Android Auto / CarPlay do not support the disabling of some visual elements. This can result in a slightly suboptimal experience when on an offroad section.
          As offroad waypoints rely on track navigation under the hood, you do need to be online for an optimal experience. When offline, you will receive an appropriate warning ๐Ÿ˜‰
          By introducing this feature in the app, we now support all the crucial features that the website has ๐ŸŽ‰
          Compass changes
          A lot of users were unaware what the selected camera mode was. Not entirely their fault as the icon remained the same and you did not receive any other confirmation.
          Now when tapping the compass, the icon will change based on the selected mode. Also, you will receive a short textual confirmation of the selected camera mode.
          Bluetooth controller changes
          • Support for Remotek firmware version 2.x
          • Fixed issue with BMW Carpe Iter controller
          Minor fixes
          • iPad export option
          • Manual day / night changes from CarPlay / Android Auto changed the base map style incorrectly
          • Missing pause icons
          • Not showing the same warning multiple times
          Minor changes
          • Added a loader in the in-app planner
          • Not including current location when calculating routes that are far away
          • Showing original route just before starting navigation (not only while navigating)
          • Open route from RouteXpert library or activity feed by tapping the image
          • Flow for starting routes created in a map other than HERE
          Android specific changes
          • Hide the notification bar and on screen navigation buttons when navigating
          • Support for more "intents" ensuring MyRoute-app is displayed more often as supported app to navigate with (such as with DMD2)
          What's next
          That's it for now!
          We are currently working on a complete rework of the home screen of the app ๐Ÿ˜ Expecting a release of this somewhere in March.
          The idea behind this is to improve the visual appearance of the app, less clicks for the user, smoother transition to navigation and offline availability of the home screen maps too.
          Cheers,
          Corjan
          Rob Kelley
          Rob Kelley
          Rob Kelley
          @Corjan-Meijerink said in New update! (4.3.6) - offroad waypoints:
          Thank you, nice to see a suggestion making it's way into the app so quickly.
          GSA1250
          HD Street Glide
          XT500 x 2
            @Rob-Kelley Good suggestions are always appreciated! ๐Ÿ™‚
            Especially when small and easy to implement I always try to process user feedback as fast as possible.
              Hi all! ๐Ÿ™‚
              Offroad waypoints
              Compass changes
              Minor fixes
              Minor changes
              What's next
              That's it for now!
              Cheers,
              Corjan
              cvlmtg
              cvlmtg
              cvlmtg
              just curious: why do you need to be online to navigate a track? what's the "optimal" experience?
              CD130 Corjan Meijerink Con Hennekens 3 Replies Last reply
              • cvlmtg cvlmtg
                @cvlmtg Good point, many off-road routes in the mountains, for example, do not go together with mobile data... Offline use is the only option.
                The adventure starts where the plans end | READY TO >> RACE ๐Ÿงก
                • Erik 35
                  Erik 35
                  Erik 35
                  Super hoe jullie toch steeds weer bezig zijn met het verder verbeteren en uitbreiden van de Next App.
                  iets waar wij als Eindgebruikers heel blij mee zijn .
                  Vraagje
                  In de grote update die jullie voor Maart gepland hebben is de snelheidsmeter in het scherm tijdens het rijden zonder te navigeren daar nu ook in meegenomen ?
                  dat is echt iets wat ik nog steeds mis
                  It's great how you are always working on further improving and expanding the Next App.
                  something that we as end users are very happy with.
                  Question
                  In the major update you have planned for March, the speedometer on the screen while driving without navigating is now also included?
                  that's really something I still miss
                  • cvlmtg cvlmtg
                    @cvlmtg that's unfortunately a technical limitation from HERE's side ๐Ÿ˜ž
                    I have requested offline support for track navigation! Not sure if or how soon they will honour that request.
                    • Erik 35 Erik 35
                      Vraagje
                      Question
                      @Erik-35 Dank voor de mooie woorden!
                      Dat is nog in overweging. Anders gaat het zeker daarna wel komen.
                      • cvlmtg cvlmtg
                        @cvlmtg said in New update! (4.3.6) - offroad waypoints:
                        @Corjan-Meijerink already explained. I'd just like to add that the availability of an internet connection is mostly important at the start of your route-as-track, especially if recalculation is disabled. The track that matches your route gets fetched from the online platform. If that is not possible, the app imitates a track based on your route, but that is less precise, and you can see the track cutting edges sometimes.
                        I assume that when once the track is fetched online, losing internet connection is no big deal. So most often, hopefully hotel wifi will be good enough at the start of the route. If I am completely mistaken, hopefully @Corjan-Meijerink will correct me ๐Ÿ˜‰
                          @Con-Hennekens No not really ๐Ÿ˜‰
                          Starting online and then going offline won't work result in issues.
                          However once you are offline there only needs to be the slightest deviation of the route to require internet for optimal experience. Even when recalculations are disabled and you rejoin the track, internally stuff is recalculated. Hence you'd ideally have internet.
                          martin-phogel.de Con Hennekens 2 Replies Last reply
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            Good to know!
                            I understand that the recalculation, which requires an internet connection, always affects the route, i.e. the โ€˜blue lineโ€™.
                            However, the track (or the initially calculated route when navigation route-as-track) is independent; the โ€˜white lineโ€™ remains visible in its original state, even without an internet connection, because it is stored locally on the device.
                            Is this correct?
                              Good to know!
                              Is this correct?
                              @Martin-Wilcke That is correct!
                                martin-phogel.de
                                martin-phogel.de
                                martin-phogel.de
                                Excellent!
                                No matter what, you can still follow the track on sight.
                                I can't wait to try the new โ€˜Offroad Waypointsโ€™ feature in MRA NN. It will make planning and navigating even longer, non-routable sections so simple.
                                You have developed an incredible solution that provides track/route-as-track navigation combined with offroad capabilities, which I have never seen in any other navigation software.
                                Well done!
                                  Excellent!
                                  Well done!
                                  @Martin-Wilcke Thanks! ๐Ÿ™‚
                                    #21
                                    No not really
                                    Thanks for this correction. It is difficult (for me ๐Ÿ˜‰ ) to understand that a track that has already been cached is being disregarded when a route (not track!) to the nearest trackpoint is calculated (which probably should not be done if recalculation is disabled anyway). Especially, like you mentioned to @Martin-Wilcke, the white line (thus the original track in this case) is not changing. I am clearly missing something ๐Ÿ˜‰
                                      No not really
                                      martin-phogel.de
                                      martin-phogel.de
                                      martin-phogel.de
                                      I certainly haven't completely understood everything yet, but I know how track/route-as-track navigation basically works. If you like, we can share our thoughts.
                                      Here is a good example (posted initially by @UwB), the "Maira-Stura Kammstrasse" in the Alps:
                                      https://www.myrouteapp.com/en/social/route/10444583?mode=share
                                      The part between VP 2 and 5 is routable with OSM/TT, but not with HERE:
                                      The route is stored internally in MRA so that the calculated path is completely modelled (I don't know how this works technically; it's probably similar to Basecamp with hidden SPs).
                                      In MRA NN, the route is therefore displayed in its original shape both in the preview and after opening.
                                      When it is started for "route-as-track" navigation, it is treated as a track and is not recalculated - not at the beginning or during navigation (white line).
                                      However, a new route (blue line) is calculated, which follows the track as closely as possible. If the route deviates too far from the track, it is displayed in this area as the crow flies, and no information (turn instructions, ETAs, distances) is shown during navigation.
                                      I suspect the issues discussed here arise when you rejoin the route at VP5. The actual path does not have to be re-determined in terms of "re-routing", but something may have to be "re-calculated" to show the adjusted ETAs and distances (and maybe turn instructions as well) - even if "auto-recalc" is turned off.
                                      Do you agree so far? What are your thoughts?
                                        Hi all! ๐Ÿ™‚
                                        Offroad waypoints
                                        Compass changes
                                        Minor fixes
                                        Minor changes
                                        What's next
                                        That's it for now!
                                        Cheers,
                                        Corjan
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        @Corjan-Meijerink Which issues exactly did you fix?
                                        Because there where a few. The extra bar-buttons didn"t react properly and trying to go trough the menu the [ENTER] by moving the wonderwheel to the right didn't work.
                                        Neverteless i still am impressed by al the updates and improvements you guys make.
                                        BMW R1250 GSA Ultimate Edition
                                        Garmin XT3
                                        Samsung S25+
                                        Enthousiast MRA/MRA Next gebruiker
                                        • peha
                                          peha
                                          peha
                                          Thank you for fixing this! It eliminates an annoying bug I encountered numerous times. And I can confirm this is no longer the case. ๐Ÿ˜Š
                                          BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
                                          VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
                                          Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
                                          Rob Kelley
                                          Rob Kelley
                                          martin-phogel.de
                                          martin-phogel.de
                                          peha
                                          peha
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Erik 35
                                          Erik 35
                                          cvlmtg
                                          cvlmtg
                                            Robineke
                                            Robineke
                                            206
                                            3.6k
                                            Reinhard Grossmann h 0
                                          • Overlay Routes like the App does and waypoints without routes
                                            Rob Kelley
                                            Rob Kelley
                                          • Route Breakdown
                                            Scarecrow
                                            Scarecrow
                                          • Brittany routes
                                            Tony 13
                                            Tony 13
                                            Stanisล‚aw
                                            Stanisล‚aw
                                          • Vergrendel scherm zet alles op z'n kop
