  3. [App] Announcements
  4. New update! (4.3.6) - offroad waypoints
32 Posts 11 Posters 18.7k Views 3 Watching
    Hi all! 🙂
    It is time for a new update! 🎉
    This version is all about the support of offroad waypoints!
    Offroad waypoints
    Within the online MRA Routeplanner you can very conveniently mark some waypoints as "offroad". The main idea behind this is to skip a section of road that is unknown to the selected routing engine (HERE / TomTom / OSM). Ideal to avoid roads marked as closed (either seasonal or long term damaged) or things such as ferries.
    The app had no idea how to work with these "offroad" waypoints and just treated them as normal ones. Causing the route to be different than planned 😞
    As of now, the app does support the offroad waypoints! 😏
    In the planner you can edit any route you like and mark any waypoint as offroad! Just as in the website.
    If you then choose to navigate a route with offroad waypoints, you will see straight lines on the offroad sections. Just as planned! 😃
    These sections will be made extra clear with a nice dashed line.
    While navigating over an offroad section, some things are however different:
    • No visual instructions
    • No audio instructions
    • Possible loss of ETA information
    • Automatic recalculations disabled
    You don't need them anyway, as you're offroad.
    Android Auto / CarPlay do not support the disabling of some visual elements. This can result in a slightly suboptimal experience when on an offroad section.
    As offroad waypoints rely on track navigation under the hood, you do need to be online for an optimal experience. When offline, you will receive an appropriate warning 😉
    By introducing this feature in the app, we now support all the crucial features that the website has 🎉
    Compass changes
    A lot of users were unaware what the selected camera mode was. Not entirely their fault as the icon remained the same and you did not receive any other confirmation.
    Now when tapping the compass, the icon will change based on the selected mode. Also, you will receive a short textual confirmation of the selected camera mode.
    Bluetooth controller changes
    • Support for Remotek firmware version 2.x
    • Fixed issue with BMW Carpe Iter controller
    Minor fixes
    • iPad export option
    • Manual day / night changes from CarPlay / Android Auto changed the base map style incorrectly
    • Missing pause icons
    • Not showing the same warning multiple times
    Minor changes
    • Added a loader in the in-app planner
    • Not including current location when calculating routes that are far away
    • Showing original route just before starting navigation (not only while navigating)
    • Open route from RouteXpert library or activity feed by tapping the image
    • Flow for starting routes created in a map other than HERE
    Android specific changes
    • Hide the notification bar and on screen navigation buttons when navigating
    • Support for more "intents" ensuring MyRoute-app is displayed more often as supported app to navigate with (such as with DMD2)
    What's next
    That's it for now!
    We are currently working on a complete rework of the home screen of the app 😏 Expecting a release of this somewhere in March.
    The idea behind this is to improve the visual appearance of the app, less clicks for the user, smoother transition to navigation and offline availability of the home screen maps too.
    Cheers,
    Corjan
    Rob Kelley cvlmtg Erik Plaggenborg Marinus van Deudekom 5 Replies Last reply
      Hi all! 🙂
      Offroad waypoints
      Compass changes
      Minor fixes
      Minor changes
      What's next
      That's it for now!
      Cheers,
      Corjan
      Rob Kelley
      Rob Kelley
      Rob Kelley
      @Corjan-Meijerink Nice, thanks for the info.
      How do I mark a waypoint as offroad on the web planner? I can't find it anywhere 🙂
      GSA1250
      HD Street Glide
      XT500 x 2
      • Rob Kelley Rob Kelley
        @Rob-Kelley The skip button in the route point menu, it has a 4x4 icon.
        Rob Kelley 1 Reply Last reply
          Rob Kelley
          Rob Kelley
          Rob Kelley
          wrote on last edited by Rob Kelley
          @Nick-Carthew ah that one, I am just playing it that now, I was looking for a button saying 'off road' 🙂
          From what I can see, it doesn't route or count the mileage between this and the previous point.
          GSA1250
          HD Street Glide
          XT500 x 2
          Rob Kelley Nick Carthew 2 Replies Last reply
            Rob Kelley
            Rob Kelley
            Rob Kelley
            @Rob-Kelley What's that four point arrow button to the right of the Bin? I don't have that and not seen it before.
            GSA1250
            HD Street Glide
            XT500 x 2
              @Rob-Kelley Correct, time and distance calculations between the two route points are turned off when skip is used.
                @Rob-Kelley said in New update! (4.3.6) - offroad waypoints:
                That’s turns on a set of crosshairs for moving a route point on a touch screen (phone in my case).
                I touch the cross, crosshairs appear and I move the map around until the position I want is under the crosshairs and then I tap the move button.
                  Hi all! 🙂
                  Offroad waypoints
                  Compass changes
                  Minor fixes
                  Minor changes
                  What's next
                  That's it for now!
                  Cheers,
                  Corjan
                  Rob Kelley
                  Rob Kelley
                  Rob Kelley
                  @Corjan-Meijerink said in New update! (4.3.6) - offroad waypoints:
                  Thank you, nice to see a suggestion making it's way into the app so quickly.
                  GSA1250
                  HD Street Glide
                  XT500 x 2
                    @Rob-Kelley Good suggestions are always appreciated! 🙂
                    Especially when small and easy to implement I always try to process user feedback as fast as possible.
                      Hi all! 🙂
                      Offroad waypoints
                      Compass changes
                      Minor fixes
                      Minor changes
                      What's next
                      That's it for now!
                      Cheers,
                      Corjan
                      cvlmtg
                      cvlmtg
                      cvlmtg
                      just curious: why do you need to be online to navigate a track? what's the "optimal" experience?
                      CD130 Corjan Meijerink MotoCon 3 Replies Last reply
                      • cvlmtg cvlmtg
                        @cvlmtg Good point, many off-road routes in the mountains, for example, do not go together with mobile data... Offline use is the only option.
                        • Erik 35
                          Erik 35
                          Erik 35
                          Super hoe jullie toch steeds weer bezig zijn met het verder verbeteren en uitbreiden van de Next App.
                          iets waar wij als Eindgebruikers heel blij mee zijn .
                          Vraagje
                          In de grote update die jullie voor Maart gepland hebben is de snelheidsmeter in het scherm tijdens het rijden zonder te navigeren daar nu ook in meegenomen ?
                          dat is echt iets wat ik nog steeds mis
                          It's great how you are always working on further improving and expanding the Next App.
                          something that we as end users are very happy with.
                          Question
                          In the major update you have planned for March, the speedometer on the screen while driving without navigating is now also included?
                          that's really something I still miss
                          • cvlmtg cvlmtg
                            @cvlmtg that's unfortunately a technical limitation from HERE's side 😞
                            I have requested offline support for track navigation! Not sure if or how soon they will honour that request.
                            • Erik 35 Erik 35
                              Vraagje
                              Question
                              @Erik-35 Dank voor de mooie woorden!
                              Dat is nog in overweging. Anders gaat het zeker daarna wel komen.
                              • cvlmtg cvlmtg
                                @cvlmtg said in New update! (4.3.6) - offroad waypoints:
                                @Corjan-Meijerink already explained. I'd just like to add that the availability of an internet connection is mostly important at the start of your route-as-track, especially if recalculation is disabled. The track that matches your route gets fetched from the online platform. If that is not possible, the app imitates a track based on your route, but that is less precise, and you can see the track cutting edges sometimes.
                                I assume that when once the track is fetched online, losing internet connection is no big deal. So most often, hopefully hotel wifi will be good enough at the start of the route. If I am completely mistaken, hopefully @Corjan-Meijerink will correct me 😉
                                  @Con-Hennekens No not really 😉
                                  Starting online and then going offline won't work result in issues.
                                  However once you are offline there only needs to be the slightest deviation of the route to require internet for optimal experience. Even when recalculations are disabled and you rejoin the track, internally stuff is recalculated. Hence you'd ideally have internet.
                                  martin-phogel.de MotoCon 2 Replies Last reply
                                    martin-phogel.de
                                    martin-phogel.de
                                    martin-phogel.de
                                    Good to know!
                                    I understand that the recalculation, which requires an internet connection, always affects the route, i.e. the ‘blue line’.
                                    However, the track (or the initially calculated route when navigation route-as-track) is independent; the ‘white line’ remains visible in its original state, even without an internet connection, because it is stored locally on the device.
                                    Is this correct?
                                      Good to know!
                                      Is this correct?
                                      @Martin-Wilcke That is correct!
                                        martin-phogel.de
                                        martin-phogel.de
                                        martin-phogel.de
                                        Excellent!
                                        No matter what, you can still follow the track on sight.
                                        I can't wait to try the new ‘Offroad Waypoints’ feature in MRA NN. It will make planning and navigating even longer, non-routable sections so simple.
                                        You have developed an incredible solution that provides track/route-as-track navigation combined with offroad capabilities, which I have never seen in any other navigation software.
                                        Well done!
                                          Excellent!
                                          Well done!
                                          @Martin-Wilcke Thanks! 🙂
                                          Rob Kelley
                                          Rob Kelley
                                          peha
                                          peha
                                          martin-phogel.de
                                          martin-phogel.de
                                          Erik 35
                                          Erik 35
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          cvlmtg
                                          cvlmtg
                                          • MRA Studio export speed
                                          • Hiya from UK
                                            Russ Nattrass 1
                                            Russ Nattrass 1
                                          • geeft routepunt niet weer
