  4. STILL having issues w/ my Zumo XT not following the route
34 Posts 8 Posters 14.9k Views 6 Watching
  • Mzokk Mzokk
    @Martin-Wilcke Thankyou. I can understand why you would use GPX1.2 as you get exactly what you have planned and your methodology for getting back on track is sound 👍 The only reason I haven't used that method is I hadn't thought of it 😊 Every day is a learning day!
    martin-phogel.de
    martin-phogel.de
    martin-phogel.de
    @Mzokk
    Due to weather conditions, I haven't had a chance to check out MRAs new/enhanced "navigate route as a track" feature in reality so far - but from my understanding, this could be the perfect way to navigate the route exactly as planned (like a track) and having just VIAs visible (similar to GPX 1.2 on an XT) but with the option to activate automatic re-calculation. It mainly depends on the algorithm that leads back to the track.
    Do you have any experience with this feature already?
    Greenham Mzokk 2 Replies Last reply
      @Nick-Carthew like Hans I also have a lot of experience with the XT and MRA. Like Nick said use the Here map. Then I Check of the route is the same for Here TomTom and OSM. The XT had a bit of a will of its own. Recalculate off. Use the 1.2 further. If you share the route weer can have a look at it and give you some tips. Make shure it's set to public
      Have fun
      Greenham
      Greenham
      Greenham
      @Marinus-van-Deudekom
      First thank you all who have tried to help me. It's slowly making sense thanks to you guys. I now understand the difference between planning and overlay maps.
      I now only use HERE, for planning then compare my work/route with Tom Tom and OSM.
      What is still unclear is exporting my route via 1.2gpx and I decide to skip a waypoint. All the following shaping points seem to be ignored and zumo defaults to the default routing method within the GPS (fastest, shortest etc) using the few waypoints that still haven't been passed/used.
      Until I understand this behavior I'm lost.
      Again I have recalculation off
      ![alt text](image url20250105_075332.jpg )
      The key seems to be between 1.1gpx vs 1.2gpx
      Should I just be expecting via 1.1 instead of 1.2gpx which is what I have always used
      Nick Carthew Mzokk martin-phogel.de Hans van de Ven MR.MRA 4 Replies Last reply
        @Mzokk
        Greenham
        Greenham
        Greenham
        @Martin-Wilcke
        I do not have experience aside from watching Serg do a video on it. Didn't completely understand what they were saying.
        • Greenham Greenham
          @Greenham said in STILL having issues w/ my Zumo XT not following the route:
          Great that you understand the difference between planning and overlay maps. This catches a lot of users out.
          Comparing your route with TomTom and OSM is good practice as it can highlight alternative route options but it is only necessary if you’re going to share your route with TomTom or OSM users.
          • Greenham Greenham
            wrote on last edited by Mzokk
            @Greenham From John Heaths excellent navigating with a Zumo Guide.
            " MyRouteApp.
            Very popular and provides a very good
            solution. Possible issues for the Zūmo user :
            Gpx v1.1
            Track, Via Points and Shaping Points. No
            Favourites. Zūmo has to calculate route - it
            may end up being very different.
            GPX v1.2
            Track and Via Points. The plot of the route
            is also transferred so the roads travelled are
            identical to those plotted on the MRA map.
            However, if the route is recalculated, it has
            only the Via Points to work with. None of
            the shaping points are transferred.
            If you use this format, it is important not to
            do anything that would make the Zūmo
            recalculate the route.
            Turn off Auto-Recalculate !
            No Favourites are transferred to the Zūmo.
            As stated above I use GPX1.1 and use lots of shaping points and display the track to ensure that my intended route and route as calculated by the XT match. The @ Martin-Wilcke method will also work well as long as you don't use recalculate to navigate back to the route.
            Here is an example of a route (magenta line) and track (yellow line) I want the route to be the same as the track and travel along the B128 but because of the spacing of the shaping points and via points the Zumo XT "Faster Time" algorithm routes down the A28 and up the B45 which adds miles and time to the route. You can fix this in three ways
            1. Tap the map on the unit (as shown) to add additional shaping ponts to match the track
            2. Make sure as stated above that there is a waypoint on the B128 as you plan the route
            3. Use GPX1.2 and make sure that you don't recalculate the route when you are on it by switching off automatic recalculation.
            As with all things its a bit of a learning curve and you are doing the right thing by testing and using the unit before you are on a live tour. That is very important.
            Also when planning your routes put the start some way up the road from where you are actually starting as this ensures that the unit passes through the start point and does not try to take you back to the start as you have missed passing through it by a few metres.
            Greenham 1 Reply Last reply
            • Mzokk Mzokk
              " MyRouteApp.
              Gpx v1.1
              GPX v1.2
              Greenham
              Greenham
              Greenham
              @Mzokk
              How do you get the track to display from the zumo?
              I have several 1.2gpx routes currently loaded on my zumo, but don't see the option to display track.
                @Mzokk
                @Martin-Wilcke No Martin I haven't yet tried the navigate route as Track so far. But I have been experimenting for the past 18 months this a phone and my Africa twin Android Auto with a view to relegating the Zumo to a back up. We are nearly there I think. Testing looks silly though
                • Greenham Greenham
                  martin-phogel.de
                  martin-phogel.de
                  martin-phogel.de
                  @Greenham
                  When using GPX 1.2, avoiding recalculation is key as a recalc will affect not just the section to the next VIA but the complete route!
                  Unfortunately, skipping a VIA will force a recalculation. Most of the time, you will pass all VIAs as planned. If you need to skip a VIA for any reason, the only way I know (on an XT) is as mentioned above:
                  Stop navigating the current route, find your way back (that's where having the track displayed additional to the route can help), and if you get back on track (important!), start navigating your original route again - it will start from your current position.
                  Avoiding recalculation is the significant downside of using GPX 1.2. If this doesn't match your preferences, GPX 1.1 is probably a better choice.
                  • Greenham Greenham
                    @Mzokk
                    martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    @Greenham
                    (picked from jfheath's excellent dokumentation)
                    • Mzokk Mzokk
                      martin-phogel.de
                      martin-phogel.de
                      martin-phogel.de
                      @Mzokk said in STILL having issues w/ my Zumo XT not following the route:
                      This could be me! 😀
                      I switched from Garmin to MRA NN a year ago and never looked back. If the new "route as track" feature works as expected, it's a killer.
                      In addition to the software, the device is also an issue. I tried a few smartphone solutions (it didn't convince me), then a Carpe Iter (too big) and I'm now with a DMD2 T665. Perfect. Yes, it's expensive, but "buy once, cry once", and you're immediately rid of all the annoying issues (e.g. power draining).
                      • Greenham Greenham
                        Thas is because: the gpx 1.2, which is a route-track with via points. So no shaping points in the gpx file
                        • Greenham Greenham
                          @Martin-Wilcke
                          @Greenham of you're using a 1.2 and you want to skip a viapoint (there are no shaping points in a 1.2) navigate to the displayed track after the skipped viapoint and then press skip waypoint om your XT. It will then keep on the route
                          Have you found out how to display the track under the route?
                          martin-phogel.de Greenham 2 Replies Last reply
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            @Marinus-van-Deudekom said in STILL having issues w/ my Zumo XT not following the route:
                            I don't know what you mean with "keep on the route", but skipping a VIA will force a recalculation, which may lead to a different result.
                              @Martin-Wilcke of you do that after the skipped viapoint but ON the route the XT will not recalculate and stay on the route. But make shure you do this exactly like I said
                                martin-phogel.de
                                martin-phogel.de
                                martin-phogel.de
                                OK - I learned something new!
                                • Greenham Greenham
                                  I am still having issues with my Zumo XT NOT following the route designed in MRA completely/correctly. I have added a bunch more shaping points, used the export to 1.2 gpx. It didn't take long before it routed me down a DEAD END ROAD.... I knew the area and just drove by it. I then took another road, thus passing a WAYPOINT. I "skipped" the waypoint via Zumo, it then said it was recalculating.
                                  From that point on, it seemed to ignore any shaping points and followed a recalculated fastest route using the few WAYPOINTS left from there on. The route was useless from then on... ( it routed me 16miles down an interstate until the next WAYPOINT) I don't ever route via interstates.
                                  Since getting back:
                                  • I have gone back in, changed from Google to the HERE map
                                  • Added a bunch more WAYPOINTS,
                                  • then did a comparison with TOM TOM and OPEN maps... They all followed the same route...
                                  MY QUESTION:
                                  Is it normal to skip a waypoint and have the Zumo recalculate even though I had recalculation turned off and taking what seemed like the fastest route using the final few WAYPOINTS?
                                  I am so losing trust between the MRA and Garmin. I have a 4 day 1,000 mile trip through the NC/VA/WVA mountains planned for this Spring. I don't want to worry about the Zumo randomly changing my route.
                                  Giuliano Rescaldani
                                  Giuliano Rescaldani
                                  Giuliano Rescaldani
                                  @Greenham I use Zümo since 2019 and it is an excellent navigator, I also use MRA to plan my route: MRA is also an excellent planner. The problem is that Zümo totally ignores the shaping points! Should you deviate 1m from the planned route, it wants to "recalculate" and your shaping points are gone! I make the following steps:
                                  -Plan through MRA.
                                  -Save as GPX
                                  -With a simple EXCEL VBA script, I remove all what is not a waypoint and I "convert" shape points in real waypoints.
                                  -Load it into the Zümo.
                                  -Let it calculate the route.
                                  -Download the created route on my PC
                                  -With a GPX visualizer, superimpose the route created with MRA and the route calculated by Zümo.
                                  -Place additional waypoints to force the Zümo to follow the route I want.
                                  -Repeat those steps until the route calculated by Zümo is what I want.
                                  It is a quit elong process, but then you can drive with an excellent navigator that follows the route you like and not what he thinks is best!
                                    Greenham
                                    Greenham
                                    Greenham
                                    I was on the highlighted route a few miles from the skipped waypoint. I knew something was gonna go wrong when I did it and saw "calculating route"
                                    I have not figured out (haven't looked much either) how to show a track when on a route.
                                      @Greenham
                                      You use the gpx 1.2, which is a route track with via points. So if you deviate from the route and the XT starts calculating, it will, according to the settings of the XT, take you to the next via point, in your case via the highway. When using the gpx 1.2, turn off the recalculation if you use the gpx 1.1 in this gpx there is both the route file and the treack file and you can also make the track visible
                                      gpx 1.2 (with track visible), flags are the via points
                                      gpx 1.1 (with track visible) flags are via points, dots are shaping points.
                                      I hope this helps you understand the difference between gpx 1.1 and gpx 1.2
                                      Greenham
                                      Greenham
                                      Greenham
                                      @Hans-van-de-Ven-MR-MRA
                                      Ok I see the difference. With that being the case why would a person want to use 1.2?
                                      Hans van de Ven MR.MRA Mzokk martin-phogel.de 3 Replies Last reply
                                      • Greenham Greenham
                                        @Greenham
                                        If they want to see only the via points (flags) on the screen. I personally always use gpx 1.2
                                        • Greenham Greenham
                                          @Greenham of you have recalculating off the XT will not recalculate en of you miss a viapoint.
                                          If you're past the viapoint you can press skip waypoint of you're ON the route the XT will keep you on the route without recalculating
                                          martin-phogel.de
                                          martin-phogel.de
                                          Hans ter Braak
                                          Hans ter Braak
                                          Greenham
                                          Greenham
                                          Giuliano Rescaldani
                                          Giuliano Rescaldani
                                            780
                                            612
                                          • MRA 6.0.0 (515) Track bar covered not displayed /// Streckenbalken überdeckt nicht angezeigt
                                          • New beta! 6.0.0 (514)
                                            ValléeDesFées
                                            ValléeDesFées
                                            267
                                          • MRA Route planner Next
                                            peha
                                            peha
                                          • Hoe offline navigatie rijden
                                            Barto
                                            Barto
