  4. Input Settings, Turned off v Standard
8 Posts 4 Posters 1.7k Views 2 Watching
  • Rob Kelley
    Rob Kelley
    Rob Kelley
    Hi
    I've been looking at the App input settings, mine is set to 'Turned off', the next option is 'Standard', the manual says 'Choose here whether you use standard input or BarButtons.. etc'.
    'Turned off' isn't mentioned in the manual, what's the difference between this and 'Standard'?
    Thanks
    GSA1250
    HD Street Glide
    XT500 x 2
    • Rob Kelley Rob Kelley
      Hi
      Thanks
      @Rob-Kelley If you’re not using Bluetooth buttons to control the app, Turned off is the setting you need.
      Rob Kelley 1 Reply Last reply
        Rob Kelley
        Rob Kelley
        Rob Kelley
        @Nick-Carthew Thanks but what is Standard for?
        GSA1250
        HD Street Glide
        XT500 x 2
        Nick Carthew Corjan Meijerink 2 Replies Last reply
          @Rob-Kelley Standard Bluetooth buttons I guess. I use a SilverFox Controller so my setting is on SilverFox.
            @Rob-Kelley standard is the most common configuration that could work if you are using another device which is not listed there 🙂
              Rob Kelley
              Rob Kelley
              Rob Kelley
              @Corjan-Meijerink Thanks.
              GSA1250
              HD Street Glide
              XT500 x 2
              • Andre Trudeau
                Andre Trudeau
                Andre Trudeau
                @corjan-meijerink Hate to revive an old thread but is there a keymapping for the "standard" input available somewhere? This page only outlines the various remotes: https://support.myrouteapp.com/en/support/solutions/articles/12000100670-bluetooth-controllers#General-information
                Thanks!
                • Andre Trudeau Andre Trudeau
                  Thanks!
                  @Andre-Trudeau standard is the barbuttons 🙂 Same keymapping under two different names.
                  Rob Kelley
                  Rob Kelley
                  Andre Trudeau
                  Andre Trudeau
                  • Route wordt afgesneden
                    Wim Hompes
                    Wim Hompes
                    Jacob Waterweg
                    Jacob Waterweg
                  • OSM Routing with MRA
