  4. Top 1/3 of the screen is blue
12 Posts 5 Posters 1.9k Views 2 Watching
  • Allan Dealundefined Offline
    Allan Deal
    When navigating a route, the top 1/3 of the screen is blued out from the blue "up next box" all the way across to the speed indicator. Basically, I'm only seeing the bottom 2/3 of the map, therefore I can't see very far ahead. It's a fairly new development and I haven't a clue how to correct it. Using an Iphone 12 with IOS 18 (did it before the update) and a carpuride 7" on my motorcycle. It didn't do it until recently (last few weeks) Is there some setting that's gotten goofed up? I can't figure it out. It's rather inconvienant as I can't look ahead to approaching curves to preplan. Anyone else experiencing this?
    Corjan Meijerinkundefined Con Hennekensundefined 2 Replies Last reply
    • Allan Dealundefined Allan Deal
      @Allan-Deal could you share a screenshot / photo?
      Allan Dealundefined 1 Reply Last reply
        Allan Deal
        I don't have a pic, was riding, but another person shared a post on another matter and thiers looked just like mine. Here is their picture...
          @Allan-Deal, you probably have the tilt value in the app settings too high.
            @Allan-Deal as said by @Con-Hennekens check your tilt settings. I’d recommend lowering them πŸ˜‰
            • Rene 2a 0undefined Offline
              Rene 2a 0
              same problem here with a samsung S24+
              will try lowering the tilt setting.
              Ducati Multistrada V2S
              Evotech SP Connect mount
              and S24+
                The blue represents the sky.
                  Allan Deal
                  @Con-Hennekens Thank you for the suggestion. That took care of it. The settings had been bumped all the way up. Thank you very much.
                    @Allan-Deal, I am just glad it worked out πŸ˜‰
                      @Nick-Carthew You are a true artist!
                        @Corjan-Meijerink said in Top 1/3 of the screen is blue:
                        Move aside Banksy 😊
                          Rene 2a 0
                          "problem" is solved by lowering the tilt value
                          thank you
                          and S24+
                          Rene 2a 0undefined
                          Rene 2a 0
                          Allan Dealundefined
                          Allan Deal
                          • Manual 'Compare Route calculation'
                            Herman Veldhuizenundefined
                          • Hull to Rotterdam ferry not recognised
                            Steve Jarrellundefined
                            Steve Jarrell
                            1.7k
                          • A few observations
                            Thomas Miklundefined
                            Thomas Mikl
                          • Hoe een kaart met bepaalde plaatsen als POI aanmaken.
                            nomkoundefined
                          • Herberekenen werkt niet.
                          • Color of Via points issue
