  4. Tolls or no tolls ?
Tolls or no tolls ?
4 Posts 3 Posters 839 Views 1 Watching
  • Aggelos Minoudis
    Aggelos Minoudis
    Aggelos Minoudis
    Hello folks I use my route app with my iPhone for motorcycle tours. Is there any parameter that I can avoid highways and tolls or sth? Any selection also if I want to join big highways or country roads ?
    Thanx
    • Aggelos Minoudis Aggelos Minoudis
      Thanx
      @Aggelos-Minoudis, You are posting in the "[Web] Suggestions and Discussion" category, but it looks like you are asking a question, not giving a suggestion. Also you say you are using the app, so why posting in a web category instead of the app category?
      Can a moderator please relocate this message?
      Then, to answer your question, of course there is 😉
      Are you looking for this in the navigation mode or in the planner mode?
      Navigation mode:
      ONLY possible when navigating to a destination. Scroll down the options panel BEFORE tapping the yellow flyer button, there is a section called "allowed roads". For pre-planned routes you cannot change the settings in navigation mode. They are inherited from the planner mode. You would violate your route if you change it prior to navigating the route.
      Planner mode:
      Hamburger menu - Route options
      You see, adding a little context to a question makes answering them a lot easier 😉
      Aggelos Minoudis 1 Reply Last reply
        Navigation mode:
        Planner mode:
        Aggelos Minoudis
        Aggelos Minoudis
        Aggelos Minoudis
        @Con-Hennekens thanx a lot. So far I enjoy the app but I find some difficulties. Also sorry about that is there also an option for the shorter distance leg or no ? Thanx a lot
          wrote on last edited by RetiredWingMan
          @Aggelos-Minoudis you know what you mean but I have no idea what you are asking. Suggest you review the manual(s), https://www.myrouteapp.com/support
          • Nick Carthew Nick Carthew moved this topic from [Web] Suggestions and Discussion on
          Aggelos Minoudis
          Aggelos Minoudis
            387
          • test Myroute APP
            1.7k
            LE DIZES Freddy
            LE DIZES Freddy
            7.4k
            562
          • How to plan correctly
            Erdna
            Erdna
            436
            Hubert Thori
            Hubert Thori
          • Tour results and a question
