  4. Suggestion for announcements
announcements
35 Posts 12 Posters 21.6k Views 4 Watching
    It seems that a lot of users are misunderstanding the methodology used for announcing waypoints. For the new planner platform currently under development I have the following suggestions:
    • Disable announcing the name by default (this is usually just an uninteresting address, hence the current number method)
    • Announcing the name is irritating because that name changes every time you replace a waypoint, it changes back to an uninteresting address.
    • Only announce the name (address) unless a checkmark is placed at "announce name"
    • Users then should place the interesting info in the note, not in the name.
    • Maybe the name field should be ignored in the announcements should even be renamed to address and made unchangeable, who needs two fields for extra info anyway?
    My own preferred planning method would then change to:
    • Set announcements to ALL
    • Enter the announcement in the notes field
    • leave the "include name (or address)" field unchecked.
    • An announcement is ONLY made if something is entered in the note field, or the address is spoken when the relevant checkmark is set.
    This way only sensible info is announced, and no uninteresting addresses are being spoken. Users can still choose to have only VIA points or ALL waypoints announced.
    @Con-Hennekens see wat you mean. I made a mestake. I wanted the note to be announced later not the waypoint. Now the note was readout way before I was @the place where I wanted it to be readout to me..
    • BMcG BMcG
      Hi to all & apologies for this post length plus I think I may be the one causing the trouble & confusion over in the other thread Text to Speech function questions
      @Con-Hennekens said in Text to Speech function questions:
      I agree however that the current method takes some knowledge about it in advance.
      I am glad we can agree that the current system is a little confusing without the extra special knowledge 😂
      This confusion or requirement to know the extra knowledge is why I believe the announcement function cannot stay the same,
      it needs to be cleaned up so it is easier for all to understand
      I think your suggestion would make things even more complicated. I think there would be a more simple method possible.
      but here we disagree, I think my suggestion is the simple method 😂
      It is a simple 4 stage progression switch
      1. Off - no announcements
      2. Notes- announce only the notes field
      3. Via - announce the Via hard points names + the notes field
      4. All - announce everything, it means All = all of the soft point names, all the Via hard point names & all the notes, no hidden numerical filters
      So setting 1 "Off" is obviously for those who like silence & don't care for announcements
      You can still add info in the Notes field & select "Off" but nothing would be announced,
      information in the notes field would still show on the screen layout if you had "Upcoming Waypoint" selected as would the point name but you would hear nothing
      Setting 2 "Notes" means the user can selectively choose which points get a announced by simply adding text to the Notes field of that point
      There is no need for check boxes to say announce this point, the simple addition of text to the Notes field acts like the check box
      If you have nothing in the Notes field you hear nothing,
      If you add a note you hear it but you would not hear the "unnecessary pointless" address information in the point name field
      I think most users would choose this setting as it allows them to control when & what they want to hear
      Setting 3 "Via" is similar to the current setup, you would hear an announcement of the hard point names plus any additional note information
      If you only want to hear the hard point names announced you don't add additional text in the notes field
      & setting 4 "All" is everything for those who like an overdose of information,
      don't choose All if you don't want the to hear all the address name stored in the point name field
      All means as above = everything, it is unfiltered you hear all the point names & all the notes
      IMO this is the simplest system & gives the user the most flexibility in MRA Navigation & is more compatible with other navigation systems
      @Con-Hennekens said in Suggestion for announcements:.
      • Maybe the name field ...... made unchangeable
      Please no no no, the point name field is the standard common field to show additional user editable information with other systems
      @Brian-McG
      I would go for this option: Via - announce the Via hard points names + the notes field
      I can't make it any simpler😊
      • Inge Bakermans Inge Bakermans
        @RetiredWingMan Absolutely agree with you on this. I always change the name of a waypoint when it is something important to me. Would love to see it not change the name when moved.
        Would appreciate it though if the note part could hold more characters than it does currently. And yes, notes should also be spoken.
        Peter Schiefer
        Peter Schiefer
        Peter Schiefer
        @Inge-Bakermans said in Suggestion for announcements:
        I have also some concerns with the complexity of WP, with digit, no digit in the name for a SP.
        But not to get a new name for a necessary move is so easy. When the WP is moved and you got the confirmation screen do not press „Accept“, press „Cancel“. The movement will be done and the name and Infos text is carried over unchanged.
        May it is in the „Handbook“. For me it was also an Info which I read here in the Forum.
        Peter
        • Peter Schiefer Peter Schiefer
          @Peter-Schiefer interesting. There must be an option to confirm wp moves because I don't get a confirmation message block.
            @Brian-McG
            For both things you mention, you can use a via point. I always make sure that there is a gas station in the route after x number of KM. So that I can fill up there, usually between 180 and 250 KM.
            I also use a via point for unpaved roads, just as a warning.
            And that can all be planned
            @Hans-van-de-Ven-MR-MRA said in Suggestion for announcements:
            I would certainly not want to do this! In the unlucky situation where this 'announcement via point' must be autoskipped, it cannot and requires manual interaction. Having the ability to get the information from a shaping point is crucial to me. I want to use via only for explicit at via usage: that is, a place that MUST be visited.
            Peter Schiefer 1 Reply Last reply
              Peter Schiefer
              Peter Schiefer
              Peter Schiefer
              @Stefan-Hummelink said in Suggestion for announcements:
              I would certainly not want to so this! In the unlucky situation where this 'announcement via point' must be autoskipped, it cannot and requires manual interaction. Having the ability to get the information from a shaping point is crucial to me. I want to use via only for explicit at via usage: that is, a place that MUST be visited.
              As I mentioned now few times, the handling with shaping and Viapoints the differences in announcements by inputs with digits or no digits and distance is confusing. It is a cause of errors at the planning phase and need too much attention.
              Actually the reliability is worth.
              My idea now is if a SP is used as important set a „blind“ VP short behind this SP so it will not skipped by calculation or a recalculation by new circumstances.
              Garmin, i can only repeat is for me the master. Only VP (Wp with Alarm) are those with announcement,
              And by the why, what you now called up is for me a point wher all the good things of MRA with taking information to WPs like text and pictures contains conflict in it self.
              If SP with such Infos can be skipped automatically and I am on a new route not considered that a SP is or will be passed, this can not be a requirement.
              Peter
                @Con-Hennekens I like being able to change the name of the waypoint. That way i can easily tell what the waypoint is when looking at the list of waypoints. I would prefer that a waypoint name that has been manually entered not be changed it I move the waypoint. I don't have any issues with the current announcement methodology other than when waypoints "interfere" with each other causing missed announcements.
                @RetiredWingMan said in Suggestion for announcements:
                That is a great addition, thanks!
                  Just leave it as it is, only be able to lock the name if it is a via point, so that it is not changed when moving. If you put it down correctly right away, you don't have to move it anymore. 😊
                  As @RetiredWingMan indicates, it is very useful to see in the list of waypoints what kind of point it is.
                  Garmin navigation systems also use this Tag: <name></name> to announce hard (via) points.
                  I would then choose to only announce the via points together with the note, because that is a requirement for a route that is in the RouteXpert library.
                  Why would you want to announce a formation point?
                  Why would you want to limit announcements to VIA points? VIA points are solely intended to be mandatory, no other features should be hung up on being VIA points.
                  • BMcG BMcG
                    @Brian-McG said in Suggestion for announcements:
                    Point taken, I agree with this, and changed my OT accordingly.
                      @Peter-Schiefer said in Suggestion for announcements:
                      That is really unnecessary if no features are interfering with the sole purpose of a VIA point: make it mandatory...
                        Peter Schiefer
                        Peter Schiefer
                        Peter Schiefer
                        I assume that some are so convinced with MRA that they do not hear the concerns.
                        My finding with no doubts is that the realibilty of announcements get worse since 4.3 by whatever reason.
                        If there is an annother verbal notice like route advice within the 2 kilometers or just before there is no verbal hint. In a lucky situation yoy got the info Waypoint reached but this also coud be ignored.
                        Peter
                          #22
                          If I was so "convinced with MRA", I would not have made the suggestion I made above... I assume that some are so convinced of their own methods and opinions that they think the rest of the world should change those accordingly?
                          I think the comment I made has little to do with your concerns though.
                            #23
                            Correct and normal route points do not need to be announced for me. I also only selected the via points to be announced. Other points are there to shape the route and you can use 188 viapoints in the app.
                              #24
                              @Hans-van-de-Ven-MR-MRA, I think the keyword here is:
                              I use announcements on shaping points A LOT, to point to interesting things along the road. It would be unwise to make them mandatory just to be able to get the note spoken. It would defy the purpose of auto-skipping.
                              HABVEN aka MrMRA Peter Schiefer 2 Replies Last reply
                                Then I would leave it as it is now. You can choose.
                                  Peter Schiefer
                                  Peter Schiefer
                                  Peter Schiefer
                                  for me a conflict, use SPs for additional may important infos like highlights longside the street and these could be skipped.
                                  The only big problem for me is the 2 Kilometer distance for POI annoncements with only one call which than may up to 2 minutes to reach the point and for the final destination you got 3 calls.
                                  Peter
                                  BMcG 1 Reply Last reply
                                    BMcG
                                    BMcG
                                    BMcG
                                    wrote on last edited by BMcG
                                    #27
                                    I think the system already does this,
                                    in the web planner when you drag / move an existing point it will open a confirmation dialog box after the point is placed
                                    if you select "Cancel" the new position is accepted but the new name is not, the old previously entered name is retained
                                    in the mobile route planner it is a little bit more awkward / unintuitive
                                    pick a point & select the move icon
                                    after you have moved the point to the new location & click "move" to accept the new spot
                                    the confirmation / point information panel appears
                                    at the top you will see the new location / spot name
                                    in the name box you will see the old previous name
                                    simply place the cursor in the name box then type or add a space / backspace
                                    just do something in the name box
                                    when you now close the confirmation / point information panel the OLD name will be retained
                                    by the way I am just extending / repeating what @Peter-Schiefer mentioned in an earlier post
                                    & I appreciate nobody has taken the time to even consider or find fault with my suggestion, it is so simple, maybe its complicated 😂
                                    Baltus MotoCon 2 Replies Last reply
                                    • BMcG BMcG
                                      Baltus
                                      Baltus
                                      Baltus
                                      wrote on last edited by Baltus
                                      #28
                                      @Brian-McG When I read all the reactions I get the idea that no one has read my proposal. Because everything that the various people want can be solved like this.
                                      In my opinion, it is simple and straightforward to solve. Place all the text you want to be spoken in the notes field. Make sure you can check the box that you want to have that text spoken. If you do not check anything, it is just a standard note. Where you place this point in the route, it is spoken. If you want to report two kilometers before the gas station that there is a gas and coffee stop in two kilometers, then you place the message two kilometers before the gas station. You indicate the location of the gas station in your route in the usual way. This way, everyone is free to have something reported in distance or time and only an option needs to be created to have a text of your choice spoken. It does not matter whether you want to use a formation point or a via point for this. If there are people who still want to hear all the text or all the notes, you can give them a choice in Navigation settings/audio as it is by now.
                                      Peter Schiefer BMcG 2 Replies Last reply
                                      • Baltus Baltus
                                        Peter Schiefer
                                        Peter Schiefer
                                        Peter Schiefer
                                        #29
                                        @Baltus
                                        Baltus,
                                        Long text in verbal announcement, be carefull, I do not know what the „Mother language“ for MRA text infos is, but I detect that with German text you got relativ often not understandable words.The internal engine for text to speach is not perfect. And a longer text will come in conflict with routing instructions.
                                        I propose not to use more then 5 to 8 words in one sentence.
                                        Peter
                                        Baltus 1 Reply Last reply
                                        • Baltus Baltus
                                          BMcG
                                          BMcG
                                          BMcG
                                          Hi @Baltus it is fun how we all like to write but not so much to read 😂
                                          & I have to say thank you for raising the original post that started all this discussion 👍 👍
                                          First I would like to say there are two parts to the announcement question
                                          1. The What
                                          2. The When
                                            I find conflating options/ scenarios to just lead to confusion & nobody really understanding or looking at the issues in their simplest form
                                          My previous suggestion soley refers to "The What", this being what will be announced & what the structure or triggers are for controlling the announcement
                                          & @Baltus I think we are saying the same thing regards the control, I think my suggestion does exactly the same as what you are saying, it just does not require any check box
                                          as for "The When" I was trying to avoid this topic as it has been rehashed many times on here & any change regarding this always seems to be pushed down, I was hoping maybe to get the control / trigger side of things changed first then maybe with some luck "The When" but as everyone wants to join the issues.....
                                          Again @Baltus I agree with you 100%, the whole 750m shape point, 2km Via points is daft & have said as much here
                                          Having the announced point name / notes occur at the location the point is placed gives the user the most control.
                                          If the What was announced & the When was made & controlled as per my 2 suggestions I think there is enough flexibility in that setup that everyone could have what they want to hear, when they want to hear it
                                          • BMcG BMcG referenced this topic on
                                          Mopetenpit
                                          Mopetenpit
                                          BMcG
                                          BMcG
                                          Peter Schiefer
                                          Peter Schiefer
                                          Baltus
                                          Baltus
                                          Inge Bakermans
                                          Inge Bakermans
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                          • Sharing live location with friends on Android Auto problem
                                          • AI planner: AI guidance previewable on the map
                                          • Datenbasis
