  3. Using Multiple Maps
Using Multiple Maps
8 Posts 3 Posters 1.0k Views
  • John Forresterundefined Offline
    John Forrester
    Hi, i have made up a day by day tour route. I would like to join them all together for a complete route for reference. Is this possible and how do i do it, thanks, any help or advice. John
    • John Forresterundefined John Forrester
      Drabslabundefined Offline
      @John-Forrester I think you should read this:
      stringing-together-a-journey
        John Forrester
        Thanks I have now mastered that.
        Now one other issue, After I put a route together i.e. A to B to C, when it calculated it made my route circular which is not what I want, have I done something wrong? Any advice please? John
        Drabslabundefined Nick Carthewundefined 2 Replies Last reply
          @John-Forrester What do you mean by circular? It sends you back to point A?
          John Forresterundefined 1 Reply Last reply
            Nick Carthewundefined Offline
            @John-Forrester It would be easier to solve your problem if you could share the route on here, make sure the privacy is set to public.
            • Drabslabundefined Drabslab
              John Forrester
              @Drabslab , yes it makes it a circular route with same start and finishing point.
              John
                John
                @John-Forrester Then most likely you have repeated the point A (or somethign very near to it) at the end of your route.
                Please check.
                If that is not the solution, please give us access to the route (like Nick suggested) seo someone can have a look.
                  Please check.
                  John Forrester
                  @Drabslab
                  Hi, I will re check my route waypoints as you suggest. Thankyou. John
                  Drabslabundefined
                  John Forrester
                  • How to reverse route?
                  • Navigation loopt steeds vast
                  • Audio cuttet via Bluetooth
                    7.6k
                    Rob Verhoeffundefined
                    52
                    1.8k
                  • Nog 6 plaatsen beschikbaar
                  • using Mra on 2 devices.
                  • Update 5.0.4 - Minor improvements
