  4. Add Current Range to Route Tool Tip
12 Posts 10 Posters 2.7k Views 5 Watching
  • Ronnie Mooreundefined Offline
    Ronnie Moore
    I do long distance motorcycle rides and scavenger hunt rallies. I normally start my planning by setting the start and destination for the day. This could be 1000 miles or more per day between start and finish waypoints. I then add gas stops based on the range of my gas tank.
    It would be nice to have the range from start show up on the tool tip while hovering over the route or maybe in the slider bar at the bottom. Currently I have to drop a waypoint determine the range and delete the waypoint and add another.
    If there is another way to achieve this please let me know.
    Erdnaundefined Bart De Medtsundefined 2 Replies Last reply
    • Frappawotsitundefined Offline
      Frappawotsit
      I agree this would be a nice to have feature, very useful when planning Touring routes too.
      • Alasdair Denton-Millerundefined Offline
        Great idea. I want this too.
        I normally "sketch out" routes with a few Via points and then go and add in extra shaping points later to hit specific roads, then I add in fuel stops.
        I would love to be able to see on the route what the distance from start is automatically. I could then look at (for example), approximately 200 miles +/- 20, then zoom in on that region and select fuel POIs.
        That would be very helpful.
        • Ronnie Mooreundefined Ronnie Moore
          Erdnaundefined Offline
          Erdna
          @Ronnie-Moore Cheers from Austria,
          I don´t know if I get that correct, but the solution is already there...
          I bet you do know the regular range, so why not plan the route and then use the left navigation panel to see at what waypoints a fuel stop would be needed? The work in looking for the fitting fuel station is exactly the same as if you would have a "range indicator"?
          Regards,
          André
          Ronnie Mooreundefined 1 Reply Last reply
          • Erdnaundefined Erdna
            Regards,
            André
            Ronnie Moore
            @Erdna The example you show has many waypoints. I'm wanting a start and end waypoint only and the ability to add the gas stops without any other waypoints. I could just add a bunch of waypoints to the route and try to determine the gas stops from there, but that is a lot more work. I'm thinking something similar to how Garmin Basecamp does it would be nice.
            • CD130undefined Offline
              Hopefully the MRA team can implement this in the new route planner 👍
                @Ronnie-Moore Great suggestion!
                  A scale on the bottom bar is all that is required
                  Con Hennekensundefined Bart De Medtsundefined Dave J 0undefined 3 Replies Last reply
                    @Nick-Carthew, now THAT is a great and simple idea!
                      @Nick-Carthew Correct!
                        Dave J 0undefined Offline
                        @Nick-Carthew Brilliant idea.
                        iPhone 15 Pro
                        • Jörgenundefined Offline
                          I like the idea too. 👍
                          Not only for gas stations useful.
                          The bar a bit smaller or switchable.
                          Dave J 0undefined
                          CD130undefined
                          Erdnaundefined
                          Erdna
                          Ronnie Moore
                          Frappawotsit
                          • Need to adjust Time based on speed limits.
                          • Update 5.2 - Persistent Map Items
                            Lluis Arasanzundefined
                            Ruurt Visserundefined
                            Ruurt Visser
                            583
                          • Probleem met gedeelde route
                            Rob Verhoeffundefined
                          • Autonomous smartphone management
                          • Sharing Routes and Tracklogs
                            Dae 0undefined
                            Dae 0
                          • New version 5.2 questions
                            Keith Hofgartnerundefined
                            Keith Hofgartner
                            Ed Lauwerens 0undefined
                            Ed Lauwerens 0
                            2.4k
