  4. This is routing incorrectly isn't it?!?
30 Posts 7 Posters 12.5k Views 4 Watching
  • Tim Watson Tim Watson
    @Marinus-van-Deudekom Thank you!
    Wow, by changing the Transport mode from Motorcycle to Car the route length instantly changed from 14.54 to 18.92 miles.
    I'm really grateful you found that, and I look forward to testing it.
    However, I'm intrigued why the devs put the Transport mode in, and allowed a default mode other than Car to be set in the user profile, when only the Car profile works with the only map supported by the app?
    I can see the Transport mode changes something, but is it documented anywhere what is changing? I would expect this route to navigate the same by car, motorcycle or camel! 😄
    @Tim-Watson That I don't know, my camel riding skills are close to none😁
    Driving by car or motorcycle is the same as far as Here is concerned. The other profiles like motorhome actually have impact on the route.
    For now just use the car profile and enjoy your rides
      @Tim-Watson Hi Tim
      Your shapingpoint 6 and especially your viapoint 5 are off the route. My guess is that due to the crossing in the route MRA couldn't determine the right path do therefore skipped viapoint 5 and calculated as it did.
      Could you try it again with the points exactly on the route. To do so make sure you zoom in Max
      @Marinus-van-Deudekom said in This is routing incorrectly isn't it?!?:
      A VIA point is there to NOT be autoskipped. If a waypoint is too far off a road so that it cannot be reached, you will get a warning and the route wil not start at all. So I do not think that is it.
      @Tim-Watson, do I understand correctly that you were navigating this route on your Nav6? In that case the device itself chooses how to navigate between waypoints. the (non?) logic to skip WP5 therefore is inherent to the device, not the route. It looks like a really small loop. Maybe there is some logic in the device to prevent those (usually unwanted) loops, I really cant say.
      Tim Watson 1 Reply Last reply
        @Tim-Watson Hi Tim
        Took another glance at it with the PC and then I saw the light:
        1: You've made the route with the motor profil on
        2: I changed it to auto witch is the only type you can use at this moment with the Here maps. Then it became quit clear. The route that you wanted to go is beeing altered and giving you the route isues that you had.
        3 solution: I added a couple of shaping points and that should do the trick.
        It looks like this:
        Here's the url to the route I've changed:
        https://www.myrouteapp.com/route/open/9782354
        If you have another testrun I think it will provide you want you wanted.
        My comments in the first responce are nevertheless valid. You can see that I've placed the shaping and viapoint ON the route. Thus making shure the desired route is calculated.
        make your routes with the auto profil on 🙂
        Although there have been some problems related to the Motorbike profile, it is absolutely untrue to says that it does not work with HERE maps. It is perfectly usable, even if there are circumstances in which it might be better to use CAR profile instead.
        Tim Watson Marinus van Deudekom 2 Replies Last reply
          Tim Watson
          Tim Watson
          Tim Watson
          @Con-Hennekens Hi. No, I used a Nav6 before this week, but this week am trying out MRA and a Chigee with Android Auto. It's not going very well. Back to the Nav6 for now. 🙂
            Tim Watson
            Tim Watson
            Tim Watson
            Can you explain what these problems with the motorcycle profile have been? I can't find anything that says which to use, or indeed which to avoid.
              @Con-Hennekens hoi @Con-Hennekens
              The advice from the devs is not to use the profile. Like in Tim's case it causes problems that at completely unnecessary. I agree with the devs. Maybe you can explain what would be useful in the bike profile. I could guess like maybe road closures für bikes but I experienced that even that doesn't work at this time. What could be the advantage of that profile.
              Dae 0 1 Reply Last reply
                Dae 0
                Dae 0
                Dae 0
                Maybe @Corjan-Meijerink can give an authoritative answer straight from the horse’s mouth on the use of the motorcycle profile, both in planning mode and navigation mode (some of us only use MRA for planning).
                It’s important to know if we shouldn’t be using these modes, and if it is the case then it needs to be made more prominent to stop new users being unaware and having a really bad experience. You can see from the original post in this thread that the new user has gone back to the Nav VI because of a bad experience. That’s not good if the root cause is something that was known about but poorly communicated.
                MotoCon 2 Replies Last reply
                • Dirk Kevin K.
                  Dirk Kevin K.
                  Dirk Kevin K.
                  wrote on last edited by Dirk Kevin K.
                  #22
                  Hallo,
                  Please look at,
                  Toolkit / Avoid / Unpaved Roads
                  These settings must be readjusted for each new route, Why?
                  iPhone 15 Pro (iOS 18.4.1)
                  iPad Pro (iPadOS 18.4.1)
                  MyRoute-APP (5.1.0 - 462), All-Lifetime)
                  Honda NC750S DCT / Carpuride W502 / Garmin XT
                  BMW F800R / Carpuride W702B / Navigator VI
                  SENA 50S / Cardo Packtalk Edge
                  • Dae 0 Dae 0
                    @Dae-0 said in This is routing incorrectly isn't it?!?:
                    I happen to know that @Corjan-Meijerink uses the motorbike profile almost exclusively himself. The motorbike profile is there because it is included in the HERE SDK. Maybe Corjan cares to elaborate?
                    Roads exist that are closed for 4 wheels, but are open for 2 wheels.
                    Closures with this sign are not closed for motorbikes. I can only assume the motorbike profile takes that into account correctly.
                    @Tim-Watson said in This is routing incorrectly isn't it?!?:
                    There was a problem with showing the wrong exit at roundabouts that appeared to be exclusively for the motorbike profile. I understand that this has been solved for some time already.
                    Also there is an ongoing problem where route optimization as "shortest" instead of "quickest" is not available for the motorbike profile. That is mainly a problem if you want to go over scheduled ferries. In that case it is advised to switch to car profile and the "shortest route" optimization.
                      @Con-Hennekens this is what I mean @Con-Hennekens the bike profile doesn’t look at the closed roads for bikes. I Hope @Corjan-Meijerink will give his final verdict so we can close this part of the subject 🙂
                      • Dae 0 Dae 0
                        That for sure is true. However it is known that almost no one reads such a documentation. Most people just ask questions on the forum, and many users are here to help 😉
                        Concerning @Tim-Watson his bad experience, it is very likely that probably unintentional some skipping buttons were pressed. A VIA point (hand symbol) does not get skipped automatically. Therefore it is good info whether the problem reoccurs. If it does, it is best to submit a support ticket, so the devs can ask for logs to check what's wrong.
                          Can you substantiate that with an example? It would be very good to know, and to mention to HERE.
                            @Con-Hennekens yes I can
                            Making an route for my RouteXpert training I couldn’t find why a street was impossible to drive trough with the OSM. Looking at the situation Sith streetview I discovered that thé Riad was closed for bikes. Here and TomTom didn’t have that problem. Changing to the bike profile didn’t change anything. So for once OSM was right.
                            Other example if you want to cross a river by ferry. Most of the times the bike profile will lead to a non ferry crossing of the river where when using the car profile you can cross the river by ferry
                              Yes, but that does not proof that the motorbike profile does not honor the car-only closure correctly. It more like proofs that HERE and TomTom are unaware (yet) of the bike-closure. Did you check that with HERE and TomTom?
                              I already explained that above, and this is also no proof of the motorbike profile to disregard roads that are open for bikes but not for cars.
                                This post is deleted!
                                  So I'm testing MRA via Android Auto on a Chigee AIO-5 (spoiler - what a disaster, back to the Nav6), and I created a test route that routes in a way I wouldn't expect.
                                  Starting at 1, I'd expect it to route to 2, 3, 4 and then 5 which is a via point. No. It routes 1 to 2 to 3, and at the t-junction after 3 it turns left towards 6. What?! Auto skipping of waypoints was on, but my understanding is that it never skips via points, only shaping points. So why would it turn left after waypoint 3?
                                  Am I misunderstanding something?
                                  Why is using the Chigee a disaster?
                                  Dae 0
                                  Dae 0
                                  Stephen Rowland
                                  Stephen Rowland
                                  Tim Watson
                                  Tim Watson
                                  Dirk Kevin K.
                                  Dirk Kevin K.
                                    Axel Lange
                                    Axel Lange
                                  • In het kort......
                                  • Route probleem
                                    Jack 13
                                    Jack 13
                                    162
