  4. Zoom Scale
Zoom Scale
zoomscale
11 Posts 6 Posters 6.1k Views 3 Watching
  • Adam Sobanski Adam Sobanski
    Hi guys, in the meantime I really like the MRA functionality and it is my preferred app for navigation via a smartphone. I hope the battery drain will get solved as this is IMO the major disadvantage here. I know you work with HERE but other apps like Scenic use HERE too and do not have such power consumption.
    One think that I am missing is a zoom scale telling me for instance how sharfp a upcoming turn / curve is so I can adapt my speed - yet I know thios only if I know at which zoomlevel I am currently on my map. Would it be possible to add this to the map layout?
    Many thanks for this cool app anyway
    Adam
    hi @Adam-Sobanski said in Zoom Scale:
    doesn't this tell you how sharp a curve is, when it is moving away you can speed up, moving closer you should slow down.
    for me it is much safer to rely on my road skills than a nav screen, yes the screen may show me that i have a series of bends or a switchback ahead, but, personally i would not regulate my speed on the reliance of a nav screen
    K1600 GTL
    iPhone 13 Pro, carpuride 702b
    Adam Sobanski 1 Reply Last reply
    • paul69 paul69
      Adam Sobanski
      Adam Sobanski
      Adam Sobanski
      @paul69 Hi Paul, thanks for the comment - yet, I did not ask for a teaching how to ride safely but for a functionality that should be standard anyway on a map. Regards, Adam
      iPhone 14 pro max
      BMW R1250GS
        Having a visible scale in itself is not a bad idea, it gives reference to how far you are actually looking forward on the map. To be readable though, it would likely take up too much screen estate.
        I disagree that it is like a standard feature, since most apps and devices I know don't have that either. Paper maps usually do, but they don't zoom 😉 . I do agree that it is ill practise to use it as a method for deciding how fast to approach corners.
        • Nick Carthew
          How would the scale work when you have your map view set with tilt. Parallax would make any scale inaccurate and therefore worthless.
          MotoCon Adam Sobanski 2 Replies Last reply
            @Nick-Carthew, good point, but I think that it is still possible. I remember an earlier suggestion I posed, to make the circle around the flyer a fixed size, let's say 25 mtrs in diameter on the map for example. The further you are zoomed out, the smaller that circle gets, giving you an indication of the scale. Only the scale at the position of the flyer is interesting I think, because you can relate that to your position in the real world. And this is not exact like a scale on a paper map, but noone is measuring distances on screen with a ruler to calculate the distance in reality 😉
              Adam Sobanski
              Adam Sobanski
              Adam Sobanski
              @Nick-Carthew pretty simple: set the map to a view without tilt
              iPhone 14 pro max
              BMW R1250GS
                Adam Sobanski
                Adam Sobanski
                Adam Sobanski
                @Con-Hennekens Scenic have it and I like it a lot
                iPhone 14 pro max
                BMW R1250GS
                • Adam Sobanski
                  Adam Sobanski
                  Adam Sobanski
                  wrote on last edited by Adam Sobanski
                  @Peter-Schiefer I am even more speechless, how you conclude (same as Paul) that I want to race or what so ever. It is so tiring to run across so many teachers in forums like that.
                  I asked for a simple feature and instead I am told how to drive safely and that I am driving too fast - Guys, just read my text and stop reading between the lines or whatever you do or try to do.
                  If you cannot contribute to my request, just don’t write anything
                  iPhone 14 pro max
                  BMW R1250GS
                  • Adam Sobanski
                    Adam Sobanski
                    Adam Sobanski
                    @Peter-Schiefer thanks for calling me a young guy- which I am definitely not. You are too much reading between the lines and assuming things that are not there. I am 56 btw., not racing, careful rider, 25 years of experience on motorcycles,…
                    I do not need tips and advice in how to ride. Just asked for something that Iike to use - that’s it
                    iPhone 14 pro max
                    BMW R1250GS
                      Locking this post as I don’t see it leading to a productive conversation 🙂
                      @Adam-Sobanski thanks for the suggestion
                      Adam Sobanski
                      Adam Sobanski
                      • Route wordt afgesneden
                        Wim Hompes
                        Wim Hompes
                        Jacob Waterweg
                        Jacob Waterweg
                      • OSM Routing with MRA
