  3. Sharing routes with friends
13 Posts 8 Posters 2.9k Views 3 Watching
  • abowenundefined Offline
    abowen
    Hello,
    If I share a route with “Friends”, can those friends modify my original version of the route? Same question for “Public”. Thanks.
    -Alan
    Con Hennekensundefined Reinhard-32undefined Nomko Nomdenundefined 3 Replies Last reply
    • abowenundefined abowen
      Hello,
      -Alan
      @Alan-Bowen, they can not change YOUR route, but they can copy it into their own library and change that one.
        Hello,
        -Alan
        Reinhard-32undefined Offline
        @Alan-Bowen
        https://youtu.be/c9rBCZUPA4E
        Kindly regards
        Reinhard
        Montana 700i and Mac
          Hello,
          -Alan
          Nomko Nomdenundefined Offline
          Nomko Nomden
          @abowen
          If you share routes with friends, they are able to download/copy your routes for their own use. And as such, they can modify those routes. But they cannot modify routes under your account directly.
          When i go to the folder wioth routes of some friends of mine and i select a route, i have ton use the upperright button Gebruik route (use route) to download my friends route into my own MRA route folder and modify it.
          I am not able to modify any route directly in my friends folder.
          | MRA Gold Member |
          | MRA Next + Kawasaki Z650 |
          • No6671undefined Offline
            No6671
            As the other poster noted…
            Unfortunately (!). It is very difficult to plan a trip for a group of friends WITH them.
            FOR them it’s not a big deal.. but if anyone wants to add some POIs, or wants to see this, or that, it becomes a hassle.
            It should be a possibility to plan ONE route together.
            Goran
            Get up. Travel. Make friends. Sleep. Repeat.
            • No6671undefined No6671
              @No6671 I you can't get together with your friends then consider using something like Zoom where everyone can see the route and suggest changes which can be made by the route owner.
              No6671undefined 1 Reply Last reply
                No6671
                @RetiredWingMan
                I know. But it’s awful. In these days working together on one document is not a problem anymore. And nobody needs to zoom, just to correct/ annotate or change something.
                Goran
                Con Hennekensundefined Nick Carthewundefined 2 Replies Last reply
                  @RetiredWingMan
                  @No6671, In a word document or excel sheet everyone can work on their own part. It would become a big mess when every one is editing the same sentence. That is how working on the same route would be. It would be possible though to give people different tasks, like one is shaping the route, another is adding POI for tankstops or lunch, and a third person adds some information to waypoints. However, the second and third task are only really worthwhile when the shaping of the route is done and agreed on.
                    @RetiredWingMan
                    Nick Carthewundefined Offline
                    @No6671 I agree with @Con-Hennekens. I couldn’t think of anything worse than someone else interfering with my precious route!
                    You can probably tell, I’m a bit of a control freak 😅
                    Rob Veermanundefined 1 Reply Last reply
                      Rob Veermanundefined Offline
                      Rob Veerman
                      @Nick-Carthew Interfering could end up in ruining your precious creation. You don’t have to be a control freak to not want this to happen.
                        No6671
                        I understand you guys. ☺️
                        It’s only, there should be the option to do so. Don’t know what kind of coworkers you all have, hahaha, but in my case it works well. 🙂
                        Even with zoom or so, one could alter the route, while all others see it life. It’s dead simple.
                        Goran
                          abowen
                          I'm the OP. Thanks for all the replies. When I posted this question my concern was that I didn't want anyone changing routes I've curated. There could be "sharing permissions" of view-only and edit and it could work like a shared Google doc or Office file where people could collaborate and edit the file - that could be handy for trip planning, but I'd want the option.
                          Follow-up question, if I share a route today and a friend "uses" my route and copies it into their library, it's a point in time copy? If I change the route tomorrow the new changes will not be applied to my friends copy? Yes?
                          -Alan
                            -Alan
                            @abowen said in Sharing routes with friends:
                            Correct, once the route is in your friends library it is their copy of your route.
                            Nomko Nomden
                            Rob Veerman
                            abowenundefined
                            abowen
                            No6671undefined
                            No6671
                              Nomko Nomden
                              279
                              398
                              Ronnie Mooreundefined
                              Ronnie Moore
