  4. Roundabout exit instructions
18 Posts 9 Posters 3.2k Views 2 Watching
  • AndrewDixon2902 Offline
    AndrewDixon2902
    hi, I also found that off-line routes gave "take the 1st exit" but some (not all) on-line routes seemed to give the correct voice instruction.
    I shall watch keenly for when the solution/fix is available
    • AndrewDixon2902 AndrewDixon2902
      @AndrewDixon2902 said in Roundabout exit instructions:
      Yes, that's well known. Routes with motorcycle profile go wrong, those with Car profile go without issue.
      AndrewDixon2902 1 Reply Last reply
        AndrewDixon2902
        @Con-Hennekens thanks Con. would you suggest using car profile rather than motorcycle as a workaround?
          @AndrewDixon2902, yes that's the general advice for now. As I understood, the problem should have been solved by now, but HERE apparently needs a bit more time.
          • Corjan Meijerink Offline
            I've sent out some angry emails asking HERE about the status! It's indeed not yet fixed as promised.
            JP d 1 Reply Last reply
              JP d Offline
              JP d Offline
              JP d
              @Corjan-Meijerink any update, currently doing the NC500 with offline maps on my Oneplus 9 pro and still have this problem. My friend using an iphone using same routes but not offline is working fine 🤔 Cheers 🍻
              Nick Carthew Corjan Meijerink 2 Replies Last reply
              • JP d JP d
                Nick Carthew Online
                Nick Carthew Online
                @JP-d Are you using motorcycle as your transport mode? If so, try changing to car.
                • JP d JP d
                  @JP-d so the issue has been fixed!
                  The online maps won't display the issue.
                  Offline maps might show the issue if you have that one very specific map version downloaded that contains the issue.
                  I'd recommend either switching to car mode (as this is not affected) or update the offline maps (not recommended on crappy hotel wifi)
                    @RetiredWingMan Should not be the case as the issue only occurred when using the online maps 😉
                    They need to check if the issue hasn't accidentally also been added to an offline maps version / SDK build. Anyhow, we'll discover that soon enough!
                    Erdna Offline
                    Erdna Offline
                    Erdna
                    @Corjan-Meijerink said in Roundabout exit instructions:
                    Cheers,
                    I cannot confirm this. Was travelling Corse and Sardegna three weeks ago and only using offline navigation with same result.
                      JP d Offline
                      JP d Offline
                      JP d
                      @Nick-Carthew thanks ill give it a go
                        JP d Offline
                        JP d Offline
                        JP d
                        wrote on last edited by JP d
                        @Corjan-Meijerink Thanks, I've updated offline maps and changed vehicle in MRA planner and MRA Nav to Car. I'll post an update later 🤘🏼
                        Ps: Hotel WiFi hasn't been too bad 🏴󠁧󠁢󠁳󠁣󠁴󠁿
                        • JP d JP d
                          Nick Carthew Online
                          Nick Carthew Online
                          @JP-d said in Roundabout exit instructions:
                          How has the NC500 been? Was up there a few weeks ago.
                            JP d Offline
                            JP d Offline
                            JP d
                            @Nick-Carthew excellent news roundabout instructions are working! Wish I messaged on day 1! I've been struggling. On day 7 now heading home just went past Glasgow (anti-clockwise). We actually did the NC767 extended NC500 from MCN.
                            More of a sight seeing trip which isn't my thing I prefer fast winding roads. But I can say I've done it.
                            Weather was pretty good some rain, hail and blustery wind low of 5 degrees.
                            Thanks for your help.
                            JP d
                            JP d
                            Erdna
                            Erdna
                            BikeLover
                            BikeLover
                            Mike Whitwam
                            Mike Whitwam
                            AndrewDixon2902
                            AndrewDixon2902
                              263
                              siebo vd berg
                              siebo vd berg
                              514
                            • Transport modes?
                            • Google maps and Streetview
                              768
                            • New Zealand Routes
                            • MRA 5.2.2 (489) Avoidances are not taken into account///Vermeidungen werden nicht berücksichtigt
