  4. Roundabout exit instructions
18 Posts 9 Posters 2.8k Views 2 Watching
  • Mike Whitwamundefined Offline
    Mike Whitwam
    I know this has been posted previously but i would like to confirm the issue of the instruction of take 1st exit on all roundabouts is still present as of now 8/5/24.
    Version 4.1.2 - 305
    Hope it gets fixed soonπŸ˜‰
    • Mike Whitwamundefined Mike Whitwam
      Version 4.1.2 - 305
      @Mike-Whitwam That is correct! Had a call with HERE and they told me the fix will be deployed on Friday πŸ™‚
        @Corjan-Meijerink does that mean we need to download new maps after Friday?
          @RetiredWingMan Should not be the case as the issue only occurred when using the online maps πŸ˜‰
          They need to check if the issue hasn't accidentally also been added to an offline maps version / SDK build. Anyhow, we'll discover that soon enough!
          BikeLoverundefined Erdnaundefined 2 Replies Last reply
            BikeLoverundefined Offline
            BikeLover
            @Corjan-Meijerink installed thΓ© update today (09/05) issue still exists, Will check on friday.
            • AndrewDixon2902undefined Offline
              AndrewDixon2902
              hi, I also found that off-line routes gave "take the 1st exit" but some (not all) on-line routes seemed to give the correct voice instruction.
              I shall watch keenly for when the solution/fix is available
              • AndrewDixon2902undefined AndrewDixon2902
                @AndrewDixon2902 said in Roundabout exit instructions:
                Yes, that's well known. Routes with motorcycle profile go wrong, those with Car profile go without issue.
                AndrewDixon2902undefined 1 Reply Last reply
                  AndrewDixon2902
                  @Con-Hennekens thanks Con. would you suggest using car profile rather than motorcycle as a workaround?
                    @AndrewDixon2902, yes that's the general advice for now. As I understood, the problem should have been solved by now, but HERE apparently needs a bit more time.
                      I've sent out some angry emails asking HERE about the status! It's indeed not yet fixed as promised.
                      JP dundefined 1 Reply Last reply
                        JP dundefined Offline
                        JP d
                        @Corjan-Meijerink any update, currently doing the NC500 with offline maps on my Oneplus 9 pro and still have this problem. My friend using an iphone using same routes but not offline is working fine πŸ€” Cheers 🍻
                        Nick Carthewundefined Corjan Meijerinkundefined 2 Replies Last reply
                        • JP dundefined JP d
                          Nick Carthewundefined Offline
                          @JP-d Are you using motorcycle as your transport mode? If so, try changing to car.
                            @JP-d so the issue has been fixed!
                            The online maps won't display the issue.
                            Offline maps might show the issue if you have that one very specific map version downloaded that contains the issue.
                            I'd recommend either switching to car mode (as this is not affected) or update the offline maps (not recommended on crappy hotel wifi)
                              Erdnaundefined Offline
                              Erdna
                              @Corjan-Meijerink said in Roundabout exit instructions:
                              Cheers,
                              I cannot confirm this. Was travelling Corse and Sardegna three weeks ago and only using offline navigation with same result.
                                JP d
                                @Nick-Carthew thanks ill give it a go
                                  JP d
                                  wrote on last edited by JP d
                                  @Corjan-Meijerink Thanks, I've updated offline maps and changed vehicle in MRA planner and MRA Nav to Car. I'll post an update later 🀘🏼
                                  Ps: Hotel WiFi hasn't been too bad 🏴󠁧󠁒󠁳󠁣󠁴󠁿
                                    @JP-d said in Roundabout exit instructions:
                                    How has the NC500 been? Was up there a few weeks ago.
                                      JP d
                                      @Nick-Carthew excellent news roundabout instructions are working! Wish I messaged on day 1! I've been struggling. On day 7 now heading home just went past Glasgow (anti-clockwise). We actually did the NC767 extended NC500 from MCN.
                                      More of a sight seeing trip which isn't my thing I prefer fast winding roads. But I can say I've done it.
                                      Weather was pretty good some rain, hail and blustery wind low of 5 degrees.
                                      Thanks for your help.
                                      Erdnaundefined
                                      Erdna
                                      JP dundefined
                                      JP d
                                      BikeLoverundefined
                                      BikeLover
                                      Mike Whitwam
                                      AndrewDixon2902
                                      • Maximum amount of POI's that can be added ?
                                        Peter Zehentreiterundefined
                                        6.3k
                                      • App friert ein
                                        Travellexxieundefined
                                      • Thanks MRA!
                                        38.3k
                                      • Hoe een kaart met bepaalde plaatsen als POI aanmaken.
                                      • Mi spiegate che problemi ha ???
                                        Albyusundefined
                                        Albyus
                                        390
                                      • New beta! 5.2.1 (480)
                                        Martin Whiteundefined
                                        Martin White
                                        13
