  4. MRA not getting to my home address?
7 Posts 6 Posters 1.2k Views 3 Watching
  • Ron Z Offline
    Ron Z Offline
    Ron Z
    MRA Next is not finding my home address correctly on a route when I stored it as a Favorite. This is using MRA Next on my iPhone. Any ideas on what else I can try?
    2009 BMW K1300GT
    Garmin zümo XT
    2023 BMW R18 Transcontinental
    TomOnTour Rob Verhoeff paul69 3 Replies Last reply
    • Ron Z Ron Z
      TomOnTour Offline
      TomOnTour Offline
      TomOnTour
      wrote on last edited by TomOnTour
      @Ron-Z What is the problem MRA NExt has with your home address? Wrong routing, does it not find the address at all?
      I have done the same thing, like you did and stored a favourite for my home address. As a long term Garmin user it is named HOME 🙂
      But the name doesn‘t matter st all.
      If you go to my favourites and I select my HOME it immediately starts the calculation and I could, if I want to change the routing behaviour to curvy or anything else.
      Greetings
      Thomas
      MyRoute-APP Navigation Next (V5.2.0 - 474) on DMD T665 Navigation phone and on DMD T781
      using iPad Pro (iPadOS 26.6) and Macbook Air (macOS 26.6.1)
      • Ron Z Ron Z
        Rob Verhoeff Offline
        @Ron-Z I can only reproduce this if my physical address is located very far from the road (your saved favorite) and there is no accessible road (according to the Here map) directly leading to my front door.
        • Rob Veerman Online
          Rob Veerman Online
          Rob Veerman
          And what if you use the coordinates and then store those?
          • Ron Z Ron Z
            paul69 Offline
            paul69 Offline
            @Ron-Z said in MRA not getting to my home address?:
            hi,
            do you actually need to have it exactly marked?,
            Personnaly, I do have an address near to my home, to use as favourite for when i require MRA to get me there from a particular point. this works for me perfectly.
            K1600 GTL
            Oukitel RT3
            iPhone 13 Pro, carpuride 702b
            • Ron Z Offline
              Ron Z Offline
              Ron Z
              After further investigation it appears the HERE data is incorrect for my location. The circled street area in red does not exist:
              The above image is what MRA gave me when I set a route to my location while at my location. Taking a route up to 228th St that does not exist.
              Here is the same image from a HERE map in Garmin BaseCamp:
              The correct layout taken from a TomTom map is correct:
              I've reported the map error to Garmin, so I'll see if it ever gets corrected.
              But MRA does not attempt to come North up Marigold Ave when it should, instead the route takes me to my home address where it doesn't exist on another street. Weird...
              2009 BMW K1300GT
              Garmin zümo XT
              • Ron Z Offline
                Ron Z Offline
                Ron Z
                @Peter-Schiefer Thanks Peter! Just reported.
                2009 BMW K1300GT
                Garmin zümo XT
                Rob Veerman
                Rob Veerman
                TomOnTour
                TomOnTour
                Ron Z
                Ron Z
                  272
                • Google maps and Streetview
                  Stevedo 6 0
                  Stevedo 6 0
                  777
                  siebo vd berg
                  siebo vd berg
                  517
                • Transport modes?
                • New Zealand Routes
                • MRA 5.2.2 (489) Avoidances are not taken into account///Vermeidungen werden nicht berücksichtigt
