  4. Add option for stripping shaping points in gpx export
30 Posts 9 Posters 16.4k Views 3 Watching
  • MartinW
    MartinW
    MartinW
    @Con-Hennekens @Jörgen
    I don't think that any of the tools mentioned will help. It's not about format conversion, but about changing the content (stripping SPs).
    I have created a route with both MRA-Export 1.2 and BC-Transfer (with ‘Strip-SP-Option’) and the result is almost identical (the BC-version additionally contains gpxx:subclasses, but that should be irrelevant).
    On my Zumo XT both versions behave the same. It may be different on a Garmin outdoor device, but I doubt it.
    • MartinW MartinW
      @Martin-Wilcke, My suggestion was more targetted towards the mentioned Garmin Edge. It seems that JaVaWa is able to turn GPXs into courses for the Edge. But besides that, Javawa is able to "unflag" soft waypoints, which sounds very much like the stripping you explained. But I am not really educated about that.
      I will try to import a GPX 1.2 into my Oregon later, see what happens.
      MartinW 1 Reply Last reply
      • ConiKost
        ConiKost
        ConiKost
        Well, so many answers here. Thank you very much! I will do some tests and report back.
        Shiny!
          MartinW
          MartinW
          MartinW
          I'm looking forward to the result!
          Here I've stored the two route versions I created - if you like, you can also load them onto your oregon and see how they differ...
          https://hidrive.ionos.com/share/pquvtok.yw
          ConiKost 1 Reply Last reply
          • GT JWR
            @Peter-Schiefer excercise caution doing this, as if you reduce it by too many points, that actual route planned will change.
            For me, to help avoid that from happening, I will experiment reducing the points until the route changes, then undo that change to get the route as planned, back. From there, if I feel there are still too many points, I will start to delete them individually. Again, caution needs to be used as at a certain point, the route will change if not careful.
            Good luck!
            • Erdna
              Erdna
              Erdna
              wrote on last edited by Erdna
              Hi everybody,
              interesting topic, although it doesn´t concern my use case. Hope you´ll find a solution or at least a workaround.
              Just to give an example of scale and "sustainble" use of routing points: this route is 13 days and approx. 7200 km. It uses 192 waypoints. The individual day trips have around 25 to 30 waypoints and average ca. 550 km. 🙂
              My "dirty solution" for the problem with the old Garmin would be simple: I´d build a loop. Let´s say your planning is a stop at waypoint 8, but you have no waypoints. Why not set waypoint 9 before the real stop? If you reached your planned stop, the Garmin would tell you to turn back. Not suitable for leading groups, I guess.^^
              Regards from Austria,
              André
              • ConiKost
                ConiKost
                ConiKost
                #14
                All right, I did now run some tests and have so say, that I was completly wrong in my mind. The "GPX 1.2" export does work indeed. No shaping points are exported, so a route with more than 50 shaping points just works fine. The route is also correctly being shown.
                But: There seems to be an issue with Outdoor devices. All VIA points are missing and not shown. Only Start and End Point is shown, but all Via Points between are gone. This seems only be an export issue, as the VIA points are corrently shown on the MRA web route planer. I can also see those VIA points in the GPX 1.2 file, but the Montana seems just not detect them. I can reproduce that with my Montana.
                This does not happen, when using the same exported route from BaseCamp.
                I am attaching the same route
                1. Transfer with BaseCamp including Shaping Points
                2. Transfer with BaseCamp without Shaping Points
                3. Transfer GPX 1.2 from MRA to Montana
                @Hans-van-de-Ven-MR-MRA This would be an investigation worth, because if that could be fixed, we would have full support for Outdoor devices like Montana.
                The routes can be found here:
                MRA Route GPX 1.2
                BC Route with Shaping Points
                BC Route without Shaping Points
                Shiny!
                • MartinW MartinW
                  ConiKost
                  ConiKost
                  ConiKost
                  @Martin-Wilcke I have the same issue with your example routes. "Test BC.gpx" works correctly and shows the VIA point in the middle. With "Test 1.2.gpx", the VIA point in the middle is missing and not shown.
                  Shiny!
                  • ConiKost ConiKost
                    MartinW
                    MartinW
                    MartinW
                    @ConiKost said in Add option for stripping shaping points in gpx export:
                    That's strange and I didn't expect it.
                    I have looked at the files - the differences are rather insignificant. But obviously the Montana behaves differently, because the MRA 1.2 is displayed correctly on the XT:
                    I have made two manual changes to the MRA 1.2 to find out the secret. Can you please load the ‘MRA Route version 2’ saved here
                    onto your Montana and check whether one of the two Viapoints is displayed?
                    • MartinW MartinW
                      ConiKost
                      ConiKost
                      ConiKost
                      #17
                      @Martin-Wilcke Thanks for the new route. Unfortunately the VIA points are still missing.
                      You can see on the second image, that its just missing, there is no indicator, that there is a VIA point.
                      Shiny!
                      • MartinW
                        MartinW
                        MartinW
                        Astonishing.
                        Perhaps it is not due to a lack of information about the waypoints but to the definition of the route itself.
                        Would you like to investigate this issue further?
                        If so: I have changed the route again, it is now Version 3.
                        Can you please download it to your device?
                        If there are still no ViaPoints displayed, it would be interesting to know whether they are actually there and are just not shown or whether they have been removed.
                        Do you have the option on the device to
                        a) load the route and display the waypoints before starting the navigation? This should then look something like this:
                        b) start the navigation and then display the directions? Something like this:
                        I'm curious to see if we can track down the problem 🙂
                        Jörgen ConiKost 2 Replies Last reply
                        • MartinW MartinW
                          Astonishing.
                          Just an idea, compare the files in an text editor to see what is different.
                          • ConiKost ConiKost
                            MRA Route GPX 1.2
                            @ConiKost
                            The developers should dive into that as soon as they have time
                            • Jörgen Jörgen
                              MartinW
                              MartinW
                              MartinW
                              @Jörgen
                              Yes, that was exactly my idea. I use MS Visual Studio Code, which has a good compare feature.
                              There are a few differences between the MRA and the BC version and I'm trying to figure out which one is crucial. Unfortunately, the gpxx extensions are probably responsible for that, but they are a proprietary Garmin development and not publicly known. Most of the time you can only get to the bottom of these effects by trial and error...
                                @ConiKost
                                MartinW
                                MartinW
                                MartinW
                                @Hans-van-de-Ven-MR-MRA said in Add option for stripping shaping points in gpx export:
                                Of course! But perhaps we can try out a few things in advance to make it easier for the developer to analyse the problem.
                                This topic is a broad field and you can invest quite a lot of time in it.
                                • MartinW MartinW
                                  Astonishing.
                                  ConiKost
                                  ConiKost
                                  ConiKost
                                  #23
                                  @Martin-Wilcke Thank you for your help. I am interested in further testing 🙂 Your number 3 test works, that all VIA points are now being shown. But the whole route is gone. The route is now point to point shown.
                                  Unfortunately, the Montana route planer does not show the VIA points in a list as your Zumo does. This is a sutpid Garmin software decision, as the GPSMap 276Cx could do this and was based on Montana software.. the only option, where is does show VIA points like Zumo in a list, if I do transfer a route from Basecamp with "Direct Navigation". Thats the only case, where this works. You can find such example route here: clickme (This means only straight lines, no routing)
                                  This is can example, what I mean. It only works with my uploaded direct Route from Basecamp. Your "MRA Route Version 3", despide being direct, does not show its points, so it's apprently not detected as direct route?
                                  @Hans-van-de-Ven-MR-MRA Great, many thanks. Do you want to open for that a support ticket?
                                  Shiny!
                                  • MartinW
                                    MartinW
                                    MartinW
                                    @Peter-Schiefer
                                    Thanks for the link, I‘ll check it out!
                                    • MartinW
                                      MartinW
                                      MartinW
                                      @ConiKost
                                      OK - here comes the next and hopefully final attempt (Version 4):
                                      This version contains all the additional information from the BC file, which either has static values or can be derived relatively easily.
                                      I'm curious to see if it works!
                                      • MartinW
                                        MartinW
                                        MartinW
                                        @ConiKost
                                        ooops, little bug in version 4, please use version 5.
                                        • MartinW MartinW
                                          @ConiKost
                                          ConiKost
                                          ConiKost
                                          ConiKost
                                          @Peter-Schiefer Thanks, I will have a look.
                                          @Martin-Wilcke Thank you. I tried V5 and Unfortunately no change. Still missing VIA points.
                                          Shiny!
                                          MartinW Canario 2 Replies Last reply
                                          MartinW
                                          MartinW
                                          Erdna
                                          Erdna
                                          ConiKost
                                          ConiKost
                                          Canario
                                          Canario
                                            MartinW
                                            MartinW
                                            MartinW
                                            MartinW
                                            Rob Veerman
                                            Rob Veerman
                                            467
                                            Rory Burke
                                            Rory Burke
                                          • Béta to no-béta
