  4. Add option for stripping shaping points in gpx export
30 Posts 9 Posters 15.8k Views 3 Watching
  • ConiKost ConiKost
    @Martin-Wilcke I have the same issue with your example routes. "Test BC.gpx" works correctly and shows the VIA point in the middle. With "Test 1.2.gpx", the VIA point in the middle is missing and not shown.
    martin-phogel.de
    martin-phogel.de
    martin-phogel.de
    @ConiKost said in Add option for stripping shaping points in gpx export:
    That's strange and I didn't expect it.
    I have looked at the files - the differences are rather insignificant. But obviously the Montana behaves differently, because the MRA 1.2 is displayed correctly on the XT:
    I have made two manual changes to the MRA 1.2 to find out the secret. Can you please load the ‘MRA Route version 2’ saved here
    https://hidrive.ionos.com/share/pquvtok.yw
    onto your Montana and check whether one of the two Viapoints is displayed?
    ConiKost 1 Reply Last reply
      ConiKost
      ConiKost
      ConiKost
      #17
      @Martin-Wilcke Thanks for the new route. Unfortunately the VIA points are still missing.
      You can see on the second image, that its just missing, there is no indicator, that there is a VIA point.
      Shiny!
      • martin-phogel.de
        martin-phogel.de
        martin-phogel.de
        Astonishing.
        Perhaps it is not due to a lack of information about the waypoints but to the definition of the route itself.
        Would you like to investigate this issue further?
        If so: I have changed the route again, it is now Version 3.
        Can you please download it to your device?
        If there are still no ViaPoints displayed, it would be interesting to know whether they are actually there and are just not shown or whether they have been removed.
        Do you have the option on the device to
        a) load the route and display the waypoints before starting the navigation? This should then look something like this:
        b) start the navigation and then display the directions? Something like this:
        I'm curious to see if we can track down the problem 🙂
        Jörgen ConiKost 2 Replies Last reply
          Astonishing.
          Just an idea, compare the files in an text editor to see what is different.
          • ConiKost ConiKost
            All right, I did now run some tests and have so say, that I was completly wrong in my mind. The "GPX 1.2" export does work indeed. No shaping points are exported, so a route with more than 50 shaping points just works fine. The route is also correctly being shown.
            But: There seems to be an issue with Outdoor devices. All VIA points are missing and not shown. Only Start and End Point is shown, but all Via Points between are gone. This seems only be an export issue, as the VIA points are corrently shown on the MRA web route planer. I can also see those VIA points in the GPX 1.2 file, but the Montana seems just not detect them. I can reproduce that with my Montana.
            This does not happen, when using the same exported route from BaseCamp.
            I am attaching the same route
            1. Transfer with BaseCamp including Shaping Points
            2. Transfer with BaseCamp without Shaping Points
            3. Transfer GPX 1.2 from MRA to Montana
            @Hans-van-de-Ven-MR-MRA This would be an investigation worth, because if that could be fixed, we would have full support for Outdoor devices like Montana.
            The routes can be found here:
            MRA Route GPX 1.2
            BC Route with Shaping Points
            BC Route without Shaping Points
            @ConiKost
            The developers should dive into that as soon as they have time
            • Jörgen Jörgen
              martin-phogel.de
              martin-phogel.de
              martin-phogel.de
              @Jörgen
              Yes, that was exactly my idea. I use MS Visual Studio Code, which has a good compare feature.
              There are a few differences between the MRA and the BC version and I'm trying to figure out which one is crucial. Unfortunately, the gpxx extensions are probably responsible for that, but they are a proprietary Garmin development and not publicly known. Most of the time you can only get to the bottom of these effects by trial and error...
                @ConiKost
                martin-phogel.de
                martin-phogel.de
                martin-phogel.de
                @Hans-van-de-Ven-MR-MRA said in Add option for stripping shaping points in gpx export:
                Of course! But perhaps we can try out a few things in advance to make it easier for the developer to analyse the problem.
                This topic is a broad field and you can invest quite a lot of time in it.
                  Astonishing.
                  ConiKost
                  ConiKost
                  ConiKost
                  #23
                  @Martin-Wilcke Thank you for your help. I am interested in further testing 🙂 Your number 3 test works, that all VIA points are now being shown. But the whole route is gone. The route is now point to point shown.
                  Unfortunately, the Montana route planer does not show the VIA points in a list as your Zumo does. This is a sutpid Garmin software decision, as the GPSMap 276Cx could do this and was based on Montana software.. the only option, where is does show VIA points like Zumo in a list, if I do transfer a route from Basecamp with "Direct Navigation". Thats the only case, where this works. You can find such example route here: clickme (This means only straight lines, no routing)
                  This is can example, what I mean. It only works with my uploaded direct Route from Basecamp. Your "MRA Route Version 3", despide being direct, does not show its points, so it's apprently not detected as direct route?
                  @Hans-van-de-Ven-MR-MRA Great, many thanks. Do you want to open for that a support ticket?
                  Shiny!
                  • martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    @Peter-Schiefer
                    Thanks for the link, I‘ll check it out!
                    • martin-phogel.de
                      martin-phogel.de
                      martin-phogel.de
                      @ConiKost
                      OK - here comes the next and hopefully final attempt (Version 4):
                      This version contains all the additional information from the BC file, which either has static values or can be derived relatively easily.
                      I'm curious to see if it works!
                      • martin-phogel.de
                        martin-phogel.de
                        martin-phogel.de
                        @ConiKost
                        ooops, little bug in version 4, please use version 5.
                          @ConiKost
                          ConiKost
                          ConiKost
                          ConiKost
                          @Peter-Schiefer Thanks, I will have a look.
                          @Martin-Wilcke Thank you. I tried V5 and Unfortunately no change. Still missing VIA points.
                          Shiny!
                          martin-phogel.de Canario 2 Replies Last reply
                          • ConiKost ConiKost
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            @ConiKost
                            Too bad. Then the gpxx:subclasses must probably also be included, but I have no idea how the content can be determined or derived. Maybe someone else has an idea...
                            • ConiKost ConiKost
                              Canario
                              Canario
                              Canario
                              @ConiKost
                              I use outdoor Garmins since decades for my Moto bike Tours. Having ViaPoints part of the route is one of the most important things for my routing. With export/import of the GPX 1.2 files and recalculation set to off in the Montana 700i, the Routing works fine but the ViaPoints are missing.
                              It surely seems to have something to do with the GPXX : Subclass Tags. It would be great, if ViaPoint support for Garmin Outdoor Devices could be implemented in MRA. Until then, I will stick with Basecamp, possibly running on a virtual machine with Windows 10 or 11 in the future.
                              • Canario Canario
                                @ConiKost
                                ConiKost
                                ConiKost
                                ConiKost
                                @Canario said in Add option for stripping shaping points in gpx export:
                                @ConiKost
                                To be honest, I don't have high hopes, that this will be proper supported in future, as most of the users here uses automotive devices like Zumo/Tread. And the roadmap seems to have more important features on it's list (which I can even understand..)
                                Shiny!
                                martin-phogel.de
                                martin-phogel.de
                                Erdna
                                Erdna
                                ConiKost
                                ConiKost
                                Canario
                                Canario
                                • Route wordt afgesneden
                                  Wim Hompes
                                  Wim Hompes
                                  Pierre c
                                  Pierre c
                                • OSM Routing with MRA
                                • reuse pictures
