  4. Position delay/lag quick fix - which app works, which do not?
navigationnextpositiondelay
36 Posts 10 Posters 22.0k Views 4 Watching
    @Stefan-Hummelink, I thought it made no difference as to which other app you have running, as long as they use the Google location service? I'll gather some info.
    @Con-Hennekens said in Position delay/lag quick fix - which app works, which do not?:
    This on its own would be contradicted by the fact that running GMaps in parallel did nothing at all for the delay on my OP6. 😄
      Hi All,
      As is quite familiar by know, several users are bothered by a position delay of the cursor/flyer in relation to the actual position the road. I was one of the first users here to confirm (back in spring 2023 or so) that running another GPS app, such as Flitsmeister in parallel to MRA Navigation Next almost completely solves this issue. At the time I was already relieved to find that FM worked a charm and did not look any further.
      Since this issue has by now been identified to be caused by the HERE SDK, I've checked whether or not FM is the only app that shows improvements to the position delay.
      I would like to ask all users that are familiar with this use, that is: they are still bothered with it, to check whether or not other GPS apps are also effective in signficantly reducing the position delay/lag.
      These results may aid Corjan and HERE in finding the root cause.
      Phone characteristics:
      • Brand: OnePlus
      • Type: OnePlus 6 (ONEPLUS A6003)
      • OS version: Android 11, OxygenOS 11.1.2.2
      • OS Build nr: ONEPLUS A6003_22_211125
      I checked the following apps:
      • Flitsmeister: delay gone
      • Waze: delay gone
      • TomTom MyDrive: no effect
      • Google Maps: no effect
      On behalf of us all: thanks 😁
      @Stefan-Hummelink,
      First case is in, my wife 😉
      • Brand: Oppo
      • Type: A72 (CPH2067)
      • OS version: Android 11, ColorOS 11.1
      FlitsMeister seems to help, but we have to check again.
        Hi All,
        • Brand: OnePlus
        • Waze: delay gone
        @Stefan-Hummelink,
        Second case in, my son 😉
        • Brand: Motorola
        • Type: G73 (XT2237-2)
        • OS version: Android 13
        Flitsmeister active in background does not help.
          Hi All,
          • Brand: OnePlus
          • Waze: delay gone
          @Stefan-Hummelink,
          Third case in, a friend 😉
          • Brand: Oppo
          • Type: A5 (CPH1931)
          • OS version: Android 10, ColorOS7.1
          GMaps seems to help a bit, Flitmeister not tried yet.
            @Stefan-Hummelink, I think the devices chipset could be a big deal for this problem. But that is more difficult to ask for.
              devices chipset
              Indeed, if the HERE dev's think that may be a good to know, they can extract it based on our provided model info :).
                devices chipset
                @Stefan-Hummelink, exactly.
                • RetiredWingMan
                  FM is not available in my area, j found that running a Speedometer app in the background fixes the issue.
                  Samsung Galaxy S20 5G. Android 13 UI 5.1
                    @RetiredWingMan Thanks for reporting! 😄
                    • Jörgen
                      iPhone 12
                      iOS 17.4.1
                      MRA 4.1.2 303
                      No other GPS tool running
                      No delay
                      • Jörgen Jörgen
                        iPhone 12
                        iOS 17.4.1
                        MRA 4.1.2 303
                        No delay
                        @Jörgen said in Position delay/lag quick fix - which app works, which do not?:
                        No delay
                        Hahahaha Although it was the idea to post the phones that do have a delay, your response is always welcome 😁...
                        Jörgen 1 Reply Last reply
                        • Stefan Hummelink Stefan Hummelink referenced this topic on
                          The GPS receiver is in most cases a part of the phones SOC.
                          The cause is probably the SOC software together with Here software
                          You need to build a large database with Phones specs and which has the problem or not. From there Here needs to do some fixes.
                          Sadly there are to much different phones in use to build a proper database on this forum.
                          My Input:
                          I use Android Auto which uses the Goldwings GPS receiver.
                          This one is most of the time a bit behind. How much?
                          Mostly 20-50 meters but sometimes up to 200 meters.
                            My Input:
                            @M-Schrijver said in Position delay/lag quick fix - which app works, which do not?:
                            Haha ya, for sure. This was an initial attempt. 😊
                            • Peter Verweij
                              Peter Verweij
                              Peter Verweij
                              Here also on both an iPhone SE 2020 and a Google Pixel 7, there is a significant delay and therefore worthless to start and promote use in our Oldtimer Club.
                              If there is a solution please do, because this makes all other great solutions within MRA unusable.
                                No delay
                                @Stefan-Hummelink said in Position delay/lag quick fix - which app works, which do not?:
                                No delay
                                Ok, ok,
                                Today with
                                Oukitel tablet RT3
                                Android 12,
                                MRA 4.1.2 V 303
                                Big delay (20-30m)
                                With Altimeter App runing in the background
                                No or acceptable delay.
                                • Jörgen Jörgen
                                  No delay
                                  Ok, ok,
                                  Today with
                                  Oukitel tablet RT3
                                  Android 12,
                                  MRA 4.1.2 V 303
                                  Big delay (20-30m)
                                  Awesome! This is the kind of information that may be useful for @Corjan-Meijerink to feedback to HERE, or HERE can read this forum thread haha.
                                  • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0 referenced this topic on
                                  • Corjan Meijerink Corjan Meijerink moved this topic from [App-Beta] Problems, Bugs and other Issues on
                                    With genuine enthusiasm I can announce that the position delay will be fixed in the upcoming 4.1.3 update! 🎉
                                    Thanks for testing @Stefan-Hummelink ❤
                                    He had an Android device that displayed the issue consistently and now that is gone! 😃 Therefore I can only conclude that our efforts were not in vain!
                                    Stefan Hummelink RetiredWingMan 2 Replies Last reply
                                      #20
                                      @Corjan-Meijerink said in Position delay/lag quick fix - which app works, which do not?:
                                      So glad and proud that I was able to contribute to your solution! 😎
                                        @Corjan-Meijerink Great news ! One more step towards a solid reliable app. I plan to stay away from AA and CP for the foreseeable future. 😀
                                        • Yannick R
                                          Yannick R
                                          Yannick R
                                          wrote on last edited by Yannick R
                                          #22
                                          Same problem here!
                                          Brand: Oppo
                                          Type: Reno 6pro
                                          OS version: Android 13.1
                                          Waze: delay gone
                                          My friend has the same problem with:
                                          Brand: Oppo
                                          Type: Reno 10 pro
                                          Waze: delay gone
                                          Tom Brady
                                          Tom Brady
                                          Yannick R
                                          Yannick R
                                          Peter Verweij
                                          Peter Verweij
                                          • Routing issue
                                          • Live tracking
                                            458
                                          • Default view opennig RoutePlanner
                                          • More personalized dashboard
                                          • Search from AA Auto not working
                                            peha
                                            peha
                                          • A13 Favorites and POIs how is the difference now in the new planner
                                          • Zichtbaarheid secundaire wegen
                                          • Temperature scale for the UK
