  4. unable to calculate route
27 Posts 3 Posters 9.5k Views 2 Watching
    @Patrick-33 thanks for sharing!
    On your tablet, could you go the the account page, scroll down to the version number, long press this and share the displayed file with me?
    You can email it to corjan@myrouteapp.com πŸ™‚
    Patrick 33
    Patrick 33
    Patrick 33
    File sent
    I tried a new reinstallation just before generating the info file
    Corjan Meijerink MotoCon 3 Replies Last reply
    • Patrick 33 Patrick 33
      File sent
      @Patrick-33 Awesome!
        File sent
        @Patrick-33 said in unable to calculate route:
        I think you need to regenerate the error first, else it will not be in the logfile after a re-install.
          File sent
          @Patrick-33 due to the clean install, the logs are not containing all the information πŸ˜‰
          Could you at least go to the offline maps section (where you saw the error) - then attempt to start a route again - then share the logs with me again? πŸ˜ƒ
          Patrick 33 2 Replies Last reply
            Patrick 33
            Patrick 33
            Patrick 33
            @Corjan-Meijerink ok
              Patrick 33
              Patrick 33
              Patrick 33
              @Corjan-Meijerink File returned after error
                @Patrick-33 did you actively deny the requested location permissions or were they never prompted?
                Please check the location permissions of the app and allow them πŸ™‚
                Then report back to see if the issue is resolved. I see a lot of error messages stating that the location could not be retrieved.
                Patrick 33 1 Reply Last reply
                  Patrick 33
                  Patrick 33
                  Patrick 33
                  The authorization was set to "only allow if the app is used". I put "always allow"
                  I restarted the app, but still the same message.
                  I send a new log file
                    @Patrick-33 now it's interesting πŸ™‚
                    Thanks for the quick cooperation.
                    I unfortunately don't see an obvious issue in the logs 😞
                    Will research this a bit more later on.
                    Patrick 33 4 Replies Last reply
                      Patrick 33
                      Patrick 33
                      Patrick 33
                      @Corjan-Meijerink Thank you for your help
                        Patrick 33
                        Patrick 33
                        Patrick 33
                        There is also the problem that I cannot download the maps offline. If it helps...
                          Patrick 33
                          Patrick 33
                          Patrick 33
                          If it helps, in the "Download" and "Downloads" menus I don't have any files while on the phone, they are present.
                          I feel like I'm always offline on the tablet...
                            Patrick 33
                            Patrick 33
                            Patrick 33
                            @Corjan-Meijerink Good morning, For your information, I just reset the tablet settings and everything works again on the myroute application.
                            MotoCon Corjan Meijerink 2 Replies Last reply
                              @Patrick-33, thanks for reporting back. Did you have any security, anti-virus or, privacy apps installed previously by any chance?
                                @Patrick-33 great! πŸ™‚
                                  Patrick 33
                                  Patrick 33
                                  Patrick 33
                                  @Con-Hennekens said in unable to calculate route:
                                  Yes, it has BitDefender on it.
                                    @Patrick-33, I think it will be mighty interesting if you reinstalled Bitdefender after resetting your tablet, and if your testing was done prior of after that. Bitdefender probably has some code that could intervene with access to the HERE servers. For DuckDuckGo this has already been proven less or more...
                                      Patrick 33
                                      Patrick 33
                                      Patrick 33
                                      wrote on last edited by Patrick 33
                                      #24
                                      I uninstalled and reinstalled BitDefender and yes, it is the problem.
                                      Unable to calculate route.
                                      I'm uninstalling Bit defenbder at the moment.
                                      Edit : And it's persistent because even after uninstalling BitDefender, I still have to reset the settings.
                                        Thanks for trying and reporting. If you want to keep using BitDefender on your device, I assume there are methods for whitelisting specific apps in some controlpanel. You might get some help with that through their customer support or forum.
                                        @Corjan-Meijerink, Looks like we have another culprit to add to the list πŸ˜‰ . Maybe it is wise to check of the HERE (or MRA?) servers are on some blacklist that is used by some of the AV or privacy software companies?
                                          Patrick 33
                                          Patrick 33
                                          Patrick 33
                                          #26
                                          Yes I think it is possible to configure BitDefender, but at the moment we are traveling and don't really want to play around with the configurations. Too much need for MRA at the moment.
                                          We will do without BitDefender.
                                          Patrick 33
                                          Patrick 33
                                            Tegel Werner
                                            Tegel Werner
                                          • BΓ©ta to no-bΓ©ta
