  4. unable to calculate route
27 Posts 3 Posters 8.0k Views 2 Watching
  • Patrick 33 Offline
    Patrick 33 Offline
    Patrick 33
    Good morning,
    Since yesterday, on my S7 tablet, I have no longer been able to launch a route. I have this problem with all my routes. On the app on my phone everything works fine, but not on the tablet.
    I get a message "unable to calculate route".
    Do you have an idea of ​​the problem ?
    Sincerely
    Patrick
    • Patrick 33 Patrick 33
      Good morning,
      Sincerely
      Patrick
      Corjan Meijerink Offline
      @Patrick-33 are you by any chance using a VPN connection or DuckDuckGo app that changes your internet routing?
      HERE has reported an issue that some clients are unable to connect to their servers when using that.
      Patrick 33 1 Reply Last reply
        Patrick 33 Offline
        Patrick 33 Offline
        Patrick 33
        @Corjan-Meijerink Thanks for your help.
        No, no VPN, The tablet is connected to a Netgear router or to the phone's wifi.
        The app works on the phone.
          @Patrick-33 thanks for the reply!
          Maybe open the offline maps and see if there is an update available? πŸ™‚
          Just thinking along. Otherwise a clean install could be good idea.
          What Android version is your tablet on? Is that different than the version on your phone?
            Patrick 33 Offline
            Patrick 33 Offline
            Patrick 33
            I already tried uninstalling and reinstalling, but I still had the problem.
            Concerning the maps, I had downloaded the offline maps before my departure, but in the offline maps menu, I have this message... see image (maybe a clue...)
            Message "unable to retrieve the latest map update information"
            La version android de la tablette est la 13 sur One UI 5.1.1
            La version android du tΓ©lΓ©phone est la14 sur One UI 6
              @Patrick-33 thanks for sharing!
              On your tablet, could you go the the account page, scroll down to the version number, long press this and share the displayed file with me?
              You can email it to corjan@myrouteapp.com πŸ™‚
                Patrick 33 Offline
                Patrick 33 Offline
                Patrick 33
                File sent
                I tried a new reinstallation just before generating the info file
                Corjan Meijerink Con Hennekens 3 Replies Last reply
                  File sent
                  @Patrick-33 Awesome!
                    File sent
                    @Patrick-33 said in unable to calculate route:
                    I think you need to regenerate the error first, else it will not be in the logfile after a re-install.
                      File sent
                      @Patrick-33 due to the clean install, the logs are not containing all the information πŸ˜‰
                      Could you at least go to the offline maps section (where you saw the error) - then attempt to start a route again - then share the logs with me again? πŸ˜ƒ
                      Patrick 33 2 Replies Last reply
                        Patrick 33 Offline
                        Patrick 33 Offline
                        Patrick 33
                        @Corjan-Meijerink ok
                          Patrick 33 Offline
                          Patrick 33 Offline
                          Patrick 33
                          @Corjan-Meijerink File returned after error
                            @Patrick-33 did you actively deny the requested location permissions or were they never prompted?
                            Please check the location permissions of the app and allow them πŸ™‚
                            Then report back to see if the issue is resolved. I see a lot of error messages stating that the location could not be retrieved.
                              Patrick 33 Offline
                              Patrick 33 Offline
                              Patrick 33
                              The authorization was set to "only allow if the app is used". I put "always allow"
                              I restarted the app, but still the same message.
                              I send a new log file
                                @Patrick-33 now it's interesting πŸ™‚
                                Thanks for the quick cooperation.
                                I unfortunately don't see an obvious issue in the logs 😞
                                Will research this a bit more later on.
                                Patrick 33 4 Replies Last reply
                                  Patrick 33 Offline
                                  Patrick 33 Offline
                                  Patrick 33
                                  @Corjan-Meijerink Thank you for your help
                                    Patrick 33 Offline
                                    Patrick 33 Offline
                                    Patrick 33
                                    There is also the problem that I cannot download the maps offline. If it helps...
                                      Patrick 33 Offline
                                      Patrick 33 Offline
                                      Patrick 33
                                      If it helps, in the "Download" and "Downloads" menus I don't have any files while on the phone, they are present.
                                      I feel like I'm always offline on the tablet...
                                        Patrick 33 Offline
                                        Patrick 33 Offline
                                        Patrick 33
                                        @Corjan-Meijerink Good morning, For your information, I just reset the tablet settings and everything works again on the myroute application.
                                        Con Hennekens Corjan Meijerink 2 Replies Last reply
                                          @Patrick-33, thanks for reporting back. Did you have any security, anti-virus or, privacy apps installed previously by any chance?
                                          Patrick 33
                                          Patrick 33
                                            281
                                          • Google maps and Streetview
                                            790
                                            siebo vd berg
                                            siebo vd berg
                                            529
                                          • Transport modes?
                                          • New Zealand Routes
