  3. Ability to tell differance between waypoints and destinations
9 Posts 7 Posters 3.8k Views
  • Bobsan Offline
    Bobsan Offline
    Bobsan
    Tyre was amazing at doing this, you could (can) design a route and with older sat navs they announce just the upcoming destinations like fuel stops, lunch stops, rest stops and hotels and give you a distance to next destination. The ability to do this in paramount in designing a good route. The waypoints are of no interest to motorist they simply keep the device on track its the destinations along the way thats important and how far apart they are from each other. Tyre can do all of this My Route cannot.
    • Greenham Offline
      Greenham Offline
      Greenham
      I agree. This is common even in Basecamp. You can easily change between a "shaping point" which does NOT announce and a "waypoint" which does announce. But you have to go through the waypoint or it will keep trying to re-route you BACK to that waypoint that the system thinks you missed, where the shaping point lets just blow by and on to the next.
      In my VERY LIMITED experience with MRA we create "shaping points" in Garmin parlance.
      Alan Hilton 1 Reply Last reply
      • Greenham Greenham
        Alan Hilton Offline
        Alan Hilton Offline
        Alan Hilton
        @Greenham No, we create WPs in MRA, not shaping points. In fact I wish I knew how to create a shaping point using MRA, so as not to be compelled to route past if. The only way I know of creating a shaping point is by way of the very tedious, time consuming and error prone method of using the satnav editor.
        • Andreas 1o Offline
          Andreas 1o Offline
          Andreas 1o
          wrote on last edited by Andreas 1o
          Hello,
          may I jump on this topic and switch over to this issue on my Garmin Zumo 390.
          As the Zumo has the function to skip the next waypoint (shown as a flag on the map) in case of e.g. a construction caused detour, I need to export the track out of MPA with such waypoints (flags) and not with such "shaping points" (shown as simple dots) which I cannot skip. Zumo also does not simply ignore these MPA Points when passing by such location, so it seems to be not the typical Garmin/BaseCamp shaping point either....!?!?
          My current work around: I have to load the whole route as new, delete all the points I have passed yet and recalculate the route as new again.... This sounds simple but is mostly hair rising...!
          What is your experience when transferring a route to the Zumo?
          Many thanks.
          Andi
          sudolea Guzzist 2 Replies Last reply
          • Bobsan Offline
            Bobsan Offline
            Bobsan
            My original point is if your'e going to discontinue a very good working platform in favour of a newer version at the very least make it as good as or better than its predecessor. My Route is a very poor replacement and lacks the basic requirement of sat nav navigation, apart from the massive loss I mentioned above you cant even rename waypoints in your route design as latest tom tom devices doesn't recognise them.
            Please someone from MyRoute reply and justify the lack of basic facilities you've omitted.
            zzoemie 1 Reply Last reply
            • Bobsan Bobsan
              zzoemie Offline
              zzoemie Offline
              zzoemie
              @Bobsan 👍 👍 👍 👍 👍
              • Andreas 1o Andreas 1o
                Hello,
                Many thanks.
                Andi
                sudolea Offline
                sudolea Offline
                sudolea
                @Andreas-1o After importing such a route In BaseCamp, you can convert all these route-composing waypoints (alerting you when passing along the point) into (what is called here) "shaping" points (NOT alerting you when passing along it). How ? Select all these points, right-click, and select "do not alert" (or something like it in BaseCamp's English version). You shouldn't delete them ?!
                Guzzist 1 Reply Last reply
                  Hello,
                  Many thanks.
                  Andi
                  Guzzist Offline
                  Guzzist Offline
                  @Andreas-1o
                  I have same probs by using MRA and loading routes to Garmin 396.
                  On long trips, I do route planning with MRA on my Tablet (Android), which is more comfortable than doing direct on Garmin device.
                  But if I load routes from Tablet to Garmin, waypoints from MRA are no longer waypoints in Garmin; they became shaping ponts!
                  The only way to correct this is to open the route on Garmin, change every single shaping point into an waypoint and just the start the route.
                  Please develop a solution in MRA to get select option for a routing point, to be a way point or shaping point. Or make every routing point to a waypoint, bevause Garmins devices have the option to sikp next waypoint during routing.
                  • sudolea sudolea
                    Guzzist Offline
                    Guzzist Offline
                    @sudolea
                    Please See my replay before. BaseCamp is not always present. Changes then mußt be done in Garmin device, which is an ugly way.
                    Greenham
                    Greenham
                    sudolea
                    sudolea
                    Alan Hilton
                    Alan Hilton
                    zzoemie
                    zzoemie
                    Bobsan
                    Bobsan
                    Andreas 1o
                    Andreas 1o
                    • Export to BMW CRN
                    • NC500 glitch
                    • How to merge two tracks
                      4.7k
                    • Rondrit genereren
                    • Hiding home address / waypoint for shared routes
                      Wim Peeters
                      Wim Peeters
                    • POI naming/text display
                      478
