  4. Duplicate POIs
Duplicate POIs
13 Posts 4 Posters 96 Views 1 Watching
  • Jeremy Palmerundefined Offline
    Jeremy Palmer
    I constructed a route, A to B. There were duplicate system (not user) generated POIs. These only appeared when using HERE/default Gold/Nav maps.
    • Jeremy Palmerundefined Jeremy Palmer
      Jack van Tilburg
      @Jeremy-Palmer
      Do you mean using MRA Navigation?
      Because you say:
      But you can only use the Here map with MRA Nav.
      Jeremy Palmerundefined 2 Replies Last reply
        @Jeremy-Palmer
        Because you say:
        Jeremy Palmer
        @Jack-van-Tilburg
        Yes, MRA Nav app. on iPhone SE 2020 running latest version.
        (Thank you for replying 👍).
        Jeremy Palmerundefined 1 Reply Last reply
          @Jack-van-Tilburg
          Jeremy Palmer
          @Jeremy-Palmer
          Sincere apologies, the error is when using MRA website.
          Sorry to confusion.
            @Jeremy-Palmer
            Because you say:
            Jeremy Palmer
            @Jack-van-Tilburg
            Sincere apologies - I meant when using MRA website.
            [link text](link url)
              @Jack-van-Tilburg
              Jack van Tilburg
              @Jeremy-Palmer
              Would you please share a link to the route using the "Share" function in the Page Menu?
              Make sure the privacy setting is set to 'Public'
                @Jeremy-Palmer
                Jeremy Palmer
                @Jack-van-Tilburg
                Link shared, Jack
                Jack van Tilburgundefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
                  @Jack-van-Tilburg
                  Link shared, Jack
                  Jack van Tilburg
                  @Jeremy-Palmer
                  Okay thanks.
                  But I expected to find the link here in this topic 🙂
                  Maybe it is this one?
                  https://www.myrouteapp.com/en/social/route/8374972?mode=share
                  But then you have to explain in more detail what the problem you mean is because I don't immediately see anything strange. 😞
                    @Jeremy-Palmer
                    Okay thanks.
                    @Jack-van-Tilburg, If you look closely at the screenshot above, you will notice that there POI (not real POI but map-layer icons) that are visible twice with a short distance.
                    Strange indeed, but most likely a map error.
                      The Cock Horse...? 🤣
                        Jack van Tilburg
                        Yep, a pretty dubious environment there. 😀
                          Jack van Tilburg
                          By the way, those double symbols are bus stops.
                          One on the left and one on the right of the road.
                            @Jack-van-Tilburg
                            Link shared, Jack
                            @Jeremy-Palmer
                            I think you are using the OSM map, because the segments icons are only available in the OSM map.
                            The POI's that you see on the map is Map Data.
                            Jack van Tilburg
                            Jeremy Palmer
                            • Te veel problemen
                              M. Schrijverundefined
                              522
                            • New beta! 5.1 (457)
                              Stanisławundefined
                              Stanisław
                              Axel Härtlundefined
                              Axel Härtl
                              2.3k
                            • BDR Route GPX Support
                              BertMundefined
                              Richard Blaauwundefined
                              Richard Blaauw
