Duplicate POIs
@Jeremy-Palmer
Do you mean using MRA Navigation?Because you say:
These only appeared when using HERE/default Gold/Nav maps.
But you can only use the Here map with MRA Nav.
@Jack-van-Tilburg
Yes, MRA Nav app. on iPhone SE 2020 running latest version.
(Thank you for replying
@Jack-van-Tilburg
).@Jeremy-Palmer
Sincere apologies, the error is when using MRA website.
Sorry to confusion. -
@Jeremy-Palmer
@Jack-van-Tilburg
Sincere apologies - I meant when using MRA website.
[link text](link url)
@Jack-van-Tilburg
@Jeremy-Palmer
Would you please share a link to the route using the "Share" function in the Page Menu?
Make sure the privacy setting is set to 'Public' -
@Jeremy-Palmer
Make sure the privacy setting is set to 'Public'@Jack-van-Tilburg
Link shared, Jack -
@Jack-van-Tilburg
Link shared, Jack@Jeremy-Palmer
Okay thanks.
But I expected to find the link here in this topic
Maybe it is this one?
https://www.myrouteapp.com/en/social/route/8374972?mode=share
But then you have to explain in more detail what the problem you mean is because I don't immediately see anything strange.
@Jeremy-Palmer
Okay thanks.
@Jack-van-Tilburg, If you look closely at the screenshot above, you will notice that there POI (not real POI but map-layer icons) that are visible twice with a short distance.
Strange indeed, but most likely a map error.
The Cock Horse...?
The Cock Horse...?
Yep, a pretty dubious environment there.
By the way, those double symbols are bus stops.
One on the left and one on the right of the road.
@Jack-van-Tilburg
Link shared, JackI think you are using the OSM map, because the segments icons are only available in the OSM map.
The POI's that you see on the map is Map Data.
