  4. MRA Routeplanner using by default gravel roads
36 Posts 7 Posters 17.9k Views 1 Watching
    @Thomas-Scharrer Also in the app. When you have a route loaded for navigation, before you press the Start button, scroll up to see Allowed roads and un-select Dirt roads.
    Thomas Scharrer Offline
    Thomas Scharrer
    @Nick-Carthew I have tested now a little the HERE map for planning routes and yes it is better with respect to recognising gravel roads but otherwise I see unfortunately only disadvantages with this map compared to google maps because it is just a lot more basic. For example it cannot even find or recognise a gas station, meaning you are not able to search for s specific gas station with it. As you can see in the below picture compared to google maps, obviously it doesnt even now this gas station exists there.
    I think I will soon give up with MRA or maybe start again in a couple of years when it is more useful. For motor bike trips I can anyway not use it since voice guidance is not working and my car has google maps implemented so its jut a lot more complicated and inconvenient to use MRA. It is still a good route planner with google maps map though
      Nick Carthew Online
      Nick Carthew Online
      @Thomas-Scharrer This is why the overlay maps are available to use. Plan on the HERE map and switch between different overlay maps. Google is good for finding Cafes, restaurants, fuel stations etc. Michelin has the scenic roads indicated by a green line. OpenStreetMap has an incredible amount of detail when you zoom in, especially in towns and cities and you can see different types of roads including gravel roads.
      Don’t give up, just invest a little more time in getting to know all of the tools and maps to use. There is no better RoutePlanner than MRA.
        Thomas Scharrer
        wrote on last edited by Thomas Scharrer
        #14
        @Nick-Carthew thanks for encouraging me not to give up. I have tried hard the last couple of weeks to stay positive and use the HERE map for route planning.
        Unfortunately I have to say that the HERE map is not working at all for me and I am seriously loosing it with this map. It might be that this map works well in central Europa but here in Scandinavia its just not usable at all.
        The reason why it is not usable is because its cannot connect tow way points as you want them to be connected to create your desired route.
        Here the explanation, please note that I had many cases like this when I used the HERE map but I am showing here only one example.
        Picture 1: shows that the point 6 and 7 are very close together but the HERE map will NOT connect them and finds long ways to drive around.
        Picture 2: is just a zoomed detail view to show the problem. As you can see there are only some meters between these points.
        Picture 3: shows what happens when you switch to open street map. It immediately and automatically connects the the two points as it should be. However when switching back to the HERE map it is messed up again.
        This is the reason why I am not able to use the HERE map for route planning, this is crazy.
        Picture 4: shows that you can actually move these points together extremely close but it will still not connect them and will find the craziest ways to drive around.
        I guess you will argue now (as defence) that this specific piece of road is a gravel road and I have selected to avoid gravel roads but that is not the case. I have been there before and I can assure that this is not a gravel road. I can also send proof from google street view if you like.
        So unfortunately my conclusion is:
        • Either you accept to have some gravel roads in you tours but you are actually able to plan tours with open street map
        • or you dont have gravel roads but you have totally crazy and unusable route planning system.
        EDIT: please note that the pictures ended up in opposite order
          Nick Carthew Online
          Nick Carthew Online
          @Thomas-Scharrer Are you using the HERE planning map?
          When I replicate your route I do not see a problem.
            Thomas Scharrer
            @Nick-Carthew yes I am using the HERE planning Planning map, that is the whole problem. If I change the planning map to open street map it works perfectly fine.
            Maybe this is then some bug only I am experiencing but I had similar cases quite often now when I forced myself to use the HERE map as planning map.
            It seems that in my here map it doesnt recognise that this is a possible turn so its always trying to avoid it
              Nick Carthew Online
              Nick Carthew Online
              @Thomas-Scharrer Can you share this route with me please and I might be able to find a solution.
                Thomas Scharrer
                @Nick-Carthew I had deleted this route because I never managed to create it. I tried now to recreate the same and for some unexplainable reason it worked now in this position even though I tried everything before to make this work without success. Maybe there has come an update on the HERE map since I tried to create it?
                I will let you know when I notice the next case like this
                  Nick Carthew Online
                  Nick Carthew Online
                  @Thomas-Scharrer It could have been a road closure that affected your route when you first planned it.
                    Thomas Scharrer
                    @Nick-Carthew thats hard to believe but I have no other explanation. You can see from my screenshots that it was impossible to to connect these two points
                      Thomas Scharrer
                      #21
                      @Nick-Carthew I tried one more time because I felt totally stupid and now it happened again, here is the shared route
                      https://www.myrouteapp.com/en/social/route/8241032?mode=share
                      feel free to switch between the HERE map and the open map
                        Nick Carthew Online
                        Nick Carthew Online
                        @Thomas-Scharrer Interesting. The route that I made has now changed and looks like yours now. If I turn the traffic overlay on it shows a black line to indicate a road closure.
                        I checked this on the TomTom MyDrive website and on Google maps and neither of them show a road closure. Just some roadworks on the roundabout.
                        The route is ok again if you use the Disable Seasonal Closures tool.
                        I know that this isn't the perfect solution but it works.
                        You can report road problems directly to the HERE map using this link: https://mapfeedback.here.com/#/report
                        I have already reported it but the more people that report it then the more likely that HERE will do something about it.
                          Thomas Scharrer
                          @Nick-Carthew thanks a lot for looking into this, I thought already I am crazy.
                          I will experiment with this seasonal closure feature and the traffic overlay on some of my routes where I had such issues.
                          • Con Hennekens Offline
                            I think it is not very handy that the seasonal closures also handle the maintenance closures. Especially when you live in an area where REAL seasonal closures are no issue, the function poses more problems than they solve. It would be great if these two things could be split, but I guess that they are handled also by HERE as one thing. Maybe it is better to rename this function to "Temporary road closures", and skip the seasonal part.
                            Nick Carthew Dave J 0 2 Replies Last reply
                              Nick Carthew Online
                              Nick Carthew Online
                              @Con-Hennekens I don’t think that there is a temporary road closure at this location. I checked two other maps and did an internet search. The problem lies with the HERE map not the Seasonal Closures tool. All we can do as a community is keep reporting these problems.
                                @Nick-Carthew, yes, but the other sources could be wrong too. I don't think it is wise to claim changes by anyone then someone who has seen the situation at hand himself.
                                But what I really meant is that Seasonable closures are principally different from temporary maintenance closures. It deserves a specific category. If I choose to disable temporary maintenance closure, it is odd that I could be let over a snowey mountain pass or vice versa. Also there is nothing seasonal about maintenance road closures. But yes, probably only whishful thinking on my part 😉
                                  Thomas Scharrer
                                  @Nick-Carthew
                                  I have checked now several of my routes which were totally messed up when using the HERE map and I have to say I am happy again because it seems the seasonal closure function is the only reason for all the mess.
                                  I my opinion there is something wrong in general with this function because I had such issues as described above quite often with the here map and now having disabled this function no problem anymore.
                                  Regarding the specific example above, I can assure you that that this road is not even closed, meaning this is not a full road closure and for sure not a seasonal one. I have also checked the official traffic information from the norwegian traffic department and there is nothing mentioned for this road with respect to closure etc. whihc means the road is open.
                                  Based on this I would suggest to just forget about the seasonal closure function for the time being because without that everything seems to work. Maybe later the function will be improved but I can live without it. In nOrway we have seasonal closures for mountain roads etc so its much more reliable to check for those the official norwegian sources I think.
                                    @Nick-Carthew
                                    Thomas Scharrer
                                    @Nick-Carthew
                                    here is another example not far from the above location.
                                    I could give you 20 such cases without problem.
                                    This road is also for sure not closed.
                                    Also when I switch on and off the traffic overlay, it looks like the whole norway has a problem because everything turns red so not sure if these functions should be trusted.
                                    Con Hennekens Hans van de Ven MR.MRA 2 Replies Last reply
                                      @Nick-Carthew
                                      @Thomas-Scharrer, That's very strange... In the netherlands this is not so problematic for sure. I have no idea Why this is such a mess for HERE in Norway. I think however that disabling (in general) seasonal closures for avoiding maintenance closures IS a big problem, because being guided over closed mountain roads can lead to VERY substantial detours. For you, for the time being, there does not seem to be an alternative I am afraid.
                                        Dave J 0 Offline
                                        Dave J 0 Offline
                                        @Con-Hennekens makes sense to me.
                                        iPhone 15 Pro
                                          @Nick-Carthew
                                          #31
                                          @Thomas-Scharrer
                                          @Nick-Carthew
                                          It could be a time closure, between 23:00 and 07:00 and that is the time in Norway. So when you open the route in another country it can be that the route no wil go over a particular road
                                          I had that in Norway in Rondane NP. I looked at the route in Navigation at 05:00 and the road was closed. I looked later 07:00 and the road was open.
                                          The do that for the animal life, so that there is no traffic on particular roads
                                          Thomas Scharrer
                                          Thomas Scharrer
                                          • Welke instelling
                                            1.1k
                                          • The slow death of Zumo...
                                          • Rejoining routes
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                            498
                                            Carl Lee
                                            Carl Lee
                                            594
                                            Terry Cox 0
                                            Terry Cox 0
                                            Karl-Heinz Schwendner
                                          • New Zealand Touring Group
