  4. Diversions due to road closed…
16 Posts 7 Posters 4.1k Views 1 Watching
  • richtea999
    @Mark-Bowles The navigation app already seems to do that according to Corjan. See here:
    https://forum.myrouteapp.com/topic/4712/suggestion-display-road-closures-on-map/9
    I've seen it partly in action (as in the route I made altered itself dynamically), but with no hints as to why. I guess I may have not seen the red line, or had the app set up incorrectly.
    Things that I believe need to be done before you'll see this are:
    • enable Nav settings -> Functional -> Traffic aware route calculation
    • be online, not offline (to receive the traffic info)
    • use a 'route' not a 'track'
    Also useful is Nav settings -> Screen layout- > Show original route, so you can see when/where you've gone off-route.
    • RetiredWingMan
      I headed out one day on a road I've travelled a 100 times. I noticed a detour on the route ahead. Sure enough, when I got there, the road was closed. Something similar on my trip out east. Planned months ago, a few days before we left, one of the routes had been changed. I suspected due to forest fires. On the day we headed that way the route was open again.
      Everything worked great.
        Happy to hear the positive experiences!
        Mark Bowles 1 Reply Last reply
          Mark Bowles
          Mark Bowles
          Mark Bowles
          The issue is when there is an unplanned road closure. Then I need to tell the app to reroute but I don’t think I can….
          • Mark Bowles Mark Bowles
            @Mark-Bowles, I just choose another direction and and see what the app suggests.
              Mark Bowles
              Mark Bowles
              Mark Bowles
              @Con-Hennekens generally, what the app suggests is turn around and go back to the original route!
                @Mark-Bowles, we have an auto-skip function for that.
                Adam Sobanski 1 Reply Last reply
                  Adam Sobanski
                  Adam Sobanski
                  Adam Sobanski
                  wrote on last edited by Adam Sobanski
                  Hi Con-Hennekens,
                  I had this issue today with an unforeseen road being closed. Can you pls. explain to me how this auto-skip functionality works? I toolkit another turn, that was possible and MRA tried to route me back all the time, then I manually skipped the next via point, but it joust got confused still trying to route me via the closed road. I had. Then to randomly go quite some kilometers the ‚wrong‘ way until it reroutet me to the next waypoint. That is not very convenient.
                  Besides, if ma via points are 15-20 km distance from each other that will entirely mess up my route.
                  Two of my other Navi apps, have a closed route functionality, where I tell it how many kilometers it should re-route before guiding me back to the original route.. Values are: 1, 2, 5, 10, 15, 20 km - then the apps know, the original route is closed for this part
                  iPhone 14 pro max
                  BMW R1250GS
                  • Adam Sobanski Adam Sobanski
                    Hi Con-Hennekens,
                    @Adam-Sobanski, Don't use via points but shaping points. Via points are NOT skipped bij the autoskip function, shaping points are (via points have the hand-symbol). If you skip a shaping point (auto or by hand) you are directed to the next shaping point in the quickest possible way. If that is through the skipped shaping point, that's just what it is. Also that is an indication that you actually placed enough shaping points. If this function messes up your route, that is just an indication of NOT enough shaping points.
                    It is actually quite funny to see how some feel a need for the auto skipping function to be infallible while others feel the need to switch it and recalculation off altogether 😉
                      Adam Sobanski
                      Adam Sobanski
                      Adam Sobanski
                      @Con-Hennekens actually I have had all my points having set as shaping points (the reverse drop symbol) - still I I want a re-route of a closed road in MRA I have to drive randomly another direction w/o knowing if this is the right one, hoping its the right one, This can lead to routing back to a closed route a few times - that#s too much try & error for my taste
                      iPhone 14 pro max
                      BMW R1250GS
                        @Adam-Sobanski, It is what it is. If a closure is not processed in the map, there is not much any navigation software can do to avoid it.
                          Adam Sobanski
                          Adam Sobanski
                          Adam Sobanski
                          you are right, the navi software cannot help to avoid it but it can help to find a way around it. Calimoto and Scenic for instance allow you to stop at the unexpected closure, tell the app:
                          • The route is closed here
                          • It closed for 1, 2, 5, 10, 20 kilometers
                          It will take this distance into account to find a way around this closed part of the road --> no random try&error forcing the App to finally re-calculate in a meaningful way.
                          MRA does constantly try to guide me back to my route as this is likely the best route to the next and may be nex+1 shaping point.
                          iPhone 14 pro max
                          BMW R1250GS
                          Nick Carthew Con Hennekens 2 Replies Last reply
                            @Adam-Sobanski said in Diversions due to road closed…:
                            Normally, any roadworks that have been in place for some time will have diversion signs to follow, just follow the signs. You can choose to show your original route in the Navigation settings > Screen layout. This shows your original route in white letting you know when you have re-joined.
                              Adam Sobanski
                              Adam Sobanski
                              Adam Sobanski
                              @Nick-Carthew
                              Yep, that will certainly work but not necessarily in the most elegant way as:
                              • I am driving mostly lowest category of roads where diversion signs are not always there or not always clear
                              • diversion signs typically show the way to a town / village - I am not learning by heart through which villages my route is - so I do not easily know which diversion sign to follow
                              • in many cases the village on the diversion sign is not even on my route - that would result in additional loop way
                              • I am riding a motorcycle so my goal is not a village but a route
                              I think these (any may be other reasons) were sufficiently important for (at least motorcycle) navi app developers to build in the 'closed route' functionality to increase user experience
                              iPhone 14 pro max
                              BMW R1250GS
                                @Adam-Sobanski, I have never seen any unexpected closures of which I knew the distance of closure up front. Usually I drive into the closure if possible, most of the time it is not a real problem for motorbikes.
                                Adam Sobanski
                                Adam Sobanski
                                Mark Bowles
                                Mark Bowles
                                • test Myroute APP
                                  1.9k
                                  Hubert Thori
                                  Hubert Thori
                                • A03 POIs Show collection fixed on map
