  4. Hervatten navigatie
Hervatten navigatie
5 Posts 5 Posters 1.1k Views
  • HSundefined Offline
    HSundefined Offline
    HS
    Op mijn toestel een Samsung A52, werkt het hervatten van de navigatie niet. Dus: stoppen navigatie en daarna kiezen voor hervatten navigatie geeft enkel een grijs scherm.
    • HSundefined HS
      RetiredWingManundefined Online
      @HS several people have reported similar problems. I've also seen it recover after a minute or two. Usually you have to hard kill the app and restart it.
        I have been experiencing this also. Especially on my CAT which is a lot less powerfull than my P30 pro. So maybe that is a factor. Another factor seems to be the offline navigation function. I do not experience this problem in offline mode, only in online mode (even with a valid internet connection).
        Maybe other readers can test this and confirm (or not).
        PS: this message should be moved to the APP category instead of the WEB category.
        Marco 7vundefined 1 Reply Last reply
        • Hans van de Ven MR.MRAundefined Hans van de Ven MR.MRA moved this topic from [Web] Problems, Bugs and other Issues on
          Marco 7vundefined Offline
          Marco 7v
          I have the same experience. Pauzing the route results in a stalling app. Restart and than proceed your route. Annoying.
          Maybe it is solved when using the offline mode.
          R1200RT
          Iphone 2022SE
          SP connect
          ZUMO XT
          • Albert van den Elsenundefined Offline
            I had the same problem yesterday. Fortunately, I am still using my Garmin XT as my primary navigation. I only use the MRA app to check if it works like my Garmin XT.
            The rider in front of me took a different route than the planned one. A few seconds later. MRA-app crashed. OK, I decided to send the crash report. Even when I tried to resume my route nothing happened. 3K later, I managed to resume the route.
            Next step was to switch to offline navigation. 50 K later... Same problem in the same situation and another crash.
            I hope Corjan and his team can see what happens in the crash reports.
            iPhone 15,
            Carpe Iter Tablet V4C
            Sena 20S EVO headset
            Harley Davidson Road King M8
            Marco 7vundefined
            Marco 7v
            HSundefined
            HS
            • Geen kaart
              266
            • App behaviour when in offline mode at a construction site
              Peter Zehentreiterundefined
            • MRA: The Hassle-Free App
              M. Schrijverundefined
            • Ervaring met Garmin streetcross op MT-07
              Karel Sterrenburgundefined
              Karel Sterrenburg
            • Waypoint met foto
            • Basecamp-Kurviger Overlay!
            • View POI always
              Nick Carthewundefined
