  4. Android - Is it possible to select Audio output e.g. Speaker/Bluetooth
3 Posts 2 Posters 898 Views
  • ElmLifeundefined Offline
    ElmLife
    wrote on last edited by ElmLife
    Hi folks,
    I may have missed something here, but wanted to find out if there is an option to select where the audio from MRA outputs on the Android version of the App?
    For example, if the phone is connected to a device via Bluetooth, but I still want MRA to output over the phone speakers, I'd like to be able to select that.
    Or for example, if when connected by Bluetooth, I want MRA to output the audio to the bluetooth device, but as a 'phone call' to interrupt the music etc...
    A lot of Navigation apps out there allow you to modify where the audio output plays.
    Is this possible in MRA, have a missed something? Or is it potentially something that could be added into development?
    Cheers
    • ElmLifeundefined ElmLife
      Hi folks,
      Cheers
      @ElmLife, This message will probably be moved to the Suggestions category.
      But yes, choosing where to output the voice guidance would be very handy indeed, especially in car use of course. This was on the suggestions-list from the get go, but as far as I remember there was a technical argument to not implement it (yet). But knowing there will be work done on the audio stability and functions, we keep our hopes up 😉
      ElmLifeundefined 1 Reply Last reply
        ElmLife
        @Con-Hennekens said in Android - Is it possible to select Audio output e.g. Speaker/Bluetooth:
        Hi Con-Hennekens. Thanks for the reply and the information. I understand the development teams likely have thousands of suggestions, and often expect there are technical reasons as to why/how something can/can't be implemented. So all makes sense. If it can be done then great, as would be a nice feature to have......
        All that said, I am enjoying using the app its definitely being developed well.
        • Nick Carthewundefined Nick Carthew moved this topic from [App] Problems, Bugs and other Issues on
        ElmLifeundefined
        ElmLife
        • TyuTyu from Hungary
          Cleoundefined
        • Different paths between TT and Here algorithms
          Aiello antoninoundefined
        • Problems with DIY POI Files
        • Kaart Griekenland in griekse letters
          Léon Hassingundefined
          Léon Hassing
        • geen afstand in overzicht
          Leike Lodiersundefined
        • positie indicator meerdere keren ver van de route
          Rene 2a 0undefined
          Rene 2a 0
          889
        • LOGIN ISSUE
        • Start route bij dichtstbijzijnde routepunt werkt niet
          Philippe Veysundefined
          Philippe Veys
