  4. Descargas mapas sin conexión
8 Posts 4 Posters 1.9k Views 2 Watching
  • fasundefined Offline
    fas
    Cuando le doy ha descargar mapas sin conexión se queda pillado cuando la descarga es grande. Ejemplo pido descargar España entera y se queda pillado. Tengo que reiniciar el teléfono para salir de la aplicación
    • fasundefined fas
      Rob Verhoeffundefined Offline
      @fas said in Descargas mapas sin conexión:
      Which OS are you using? iOS or Android? For iOS, simply force closing the app and restarting it should suffice. The download will then resume. This issue has already been brought up and is on the developers' radar.
      fasundefined 1 Reply Last reply
        fas
        @Rob-Verhoeff Android. Pero al iniciar de nuevo ocurre lo mismo
        • fasundefined fas
          That's annoying! I'm not very familiar with Android. Perhaps someone else will come back to you on this.
          • fasundefined fas
            When I download offline maps, it gets stuck when the download is large. Example I ask to download the whole of Spain and it gets caught. I have to restart the phone to exit the app
            This happens sometimes, especially with flaky wifi conditions. Many users have this problem. On Android you do not need to reboot the phone, you can simply force close the app, start it again and restart the download. After a few seconds, the download will resume where it left off. It is a good idea to leave your phone alone with the app running for a while.
            • fasundefined fas
              But when I start again the same thing happens.
              If it reoccurs, it seems the downloaded parts got corrupted.
              Go into your android settings, Apps, and delete storage under the MyRoute-app options. Then try again.
                fas
                @Con-Hennekens said in Descargas mapas sin conexión:
                Gracias. Lo volvere a intentar
                • fasundefined fas
                  @fas I also set my screen timeout to the longest value possible (10 mins for me). This helps to keep the app and download running.
                  fasundefined
                  fas
                    Jim Fosterundefined
                    Jim Foster
                    7.7k
                    white.mouseundefined
                    M. Schrijverundefined
                    680
                  • Veekeersinfo en omleiden
                    Bouke Entundefined
                    2.0k
                  • Camperroutes
                  • Track vs Route
                    Roger Needham 0undefined
                    Roger Needham 0
