  4. Planning Vs Navigation (OpenStreetMap Vs Here)
6 Posts 3 Posters 2.1k Views
  • Rajpundefined Offline
    Rajp
    I think I’m getting confused, or missing a step, but it feels like I have to almost double plan and double check the route when move it from planning to navigating. Let me explain….
    1. Using myRouteApp website, I plan a new route using the default OpenStreetMap map. This map contains detailed data and POI, and so I carefully plan the route (shaping points) and stops (waypoints).
    2. Once I have the route completed, I then switch to the myRouteApp on iOS, and select the route I created on the web.
    3. I click to Navigate, and it warns me that the route was created using OpenSteetMap and may not transfer accurately to Here maps for navigating. And indeed, when I look closely at the navigation route, it is slightly, but definitely different to the planned route.
    So then after step 1 above, I switch the web app to use Here map, and again the route has changed, so then I have to meticulously go through the route again in Here maps to make corrections - doubling the work.
    Alternatively I could plan the route directly using Here map, but that overlay has very poor details, no/limited POIs, and actually not a good map at all for planning.
    So Is my flow incorrect? What is the best approach? Is there something I’m missing when planning or navigating?
    Nick Carthewundefined Travellexxieundefined 2 Replies Last reply
    • Rajpundefined Rajp
      Nick Carthewundefined Offline
      @Raj-2 Plan your route using the HERE planning map, use any of the overlay maps for information. Overlay maps are just that - an overlay.
        Travellexxieundefined Offline
        @Raj-2 When I am planning a route, I cycle through more than one overlay to optimize my route. Most of the time I use Michelin and look up details with Streetview. With this help I place Waypoints and shaping points. When I am all done I look closely in HERE if points are placed off-road. I Correct them and, in my case, I send it to my Garmin.
        MRA Lifetime Gold
        • Travellexxieundefined Travellexxie
          @Lex-Kloet When you use an overlay map the track line that you see is created by the planning map so there is no need to look closely in the HERE map as the track line is created by HERE if that is the planning map that is used.
          My first example shows the OSM overlay on a HERE planning map. You can see the difference in the position of the road. My second example is from the HERE overlay.
            This satellite view of the same road above shows that there can often be some inaccuracies in the mapping and it is why we advise people to not place route points too close to roundabouts, viaducts and junctions.
            Travellexxieundefined 1 Reply Last reply
              @Nick-Carthew I know what you mean. But what I meant is I "draw" the tour roughly in the overlays, without caring about the positioning in the HERE map. That is the finetuning that I do afterwards.
              MRA Lifetime Gold
              Rajpundefined
              Rajp
                Peter Zehentreiterundefined
                3.2k
              • Starting navigation in the middle o the programmed Route.
                richard 3vundefined
                richard 3v
              • Hi, new UK based user.
                Dave J 0undefined
              • Duizend bochten
                Castermans Paulundefined
                Castermans Paul
                Jan Weerheimundefined
                Jan Weerheim
              • Ajouter une station service dans le parcours
                LE DIZES Freddyundefined
                LE DIZES Freddy
