  4. Battery drain when navigating
57 Posts 22 Posters 1.0k Views 8 Watching
  • infoevertkuiken.nl infoevertkuiken.nl
    @Corjan-Meijerink here my battery usage today. Used MRA between 7:30 and 9 and 4:30 and 6. My battery doesn’t like cold weather and this morning was ccccolddd (1 degree Celsius and fog). I think this is ok. My phone (iPhone 7) is always on the charger when driving. I do have background location set to “when using app” because I noticed several crashes when not even using MRA and quite some battery usage. 497DC53A-C653-4462-8CA4-303DD2ABD150.png
    @Evert-Kuiken This is fine indeed!
    • Jure Sirena 0
      Jure Sirena 0
      Jure Sirena 0
      Yesterday I did cca 150km in car with charger. Battery stayed on same level. Didnt fall but didnt charge also. Improvement from last version, however charger is still mandatory
      • Rob Verhoeff Rob Verhoeff referenced this topic on
        @Rolf-Aalders That indeed really should not be the case!
        Flat Twin Therapy
        Flat Twin Therapy
        Flat Twin Therapy
        @Corjan-Meijerink Any progress on this topic? 🤞 🤞 🤞
        Since January 2024 I started recording some of my rides commuting and touring the R1200RT in The Netherlands:
        https://youtube.com/@FlatTwinTherapy
        • Flat Twin Therapy Flat Twin Therapy
          @Rolf-Aalders Not really! See the changelog for the new update: https://forum.myrouteapp.com/topic/3392/new-beta-v3-2-9
          This is the last known real critical issue 🙂
          Flat Twin Therapy 1 Reply Last reply
            Flat Twin Therapy
            Flat Twin Therapy
            Flat Twin Therapy
            @Corjan-Meijerink Thanks for pointing me to that post!
            Maarten v 1 Reply Last reply
              Maarten v
              Maarten v
              Maarten v
              @Rolf-Aalders Today riding with the MyRoute-app,battery was 88% and my iPhone 13 mini in the usb socket for voltage…….2 hours later the battery was 35% procent and still dropping…. So with the Navigation on the battery is draining verg fast even in usb socket . Than i turned Navigation off and close the app and battery was in 1,5 hour back at 80 % …..my conclusion that i can,t use the app because of battery drainage…..
              Maarten v Flat Twin Therapy 2 Replies Last reply
              • Maarten v Maarten v
                Maarten v
                Maarten v
                Maarten v
                @Maarten-v . I use the version 3.2.9-154
                  Flat Twin Therapy
                  Flat Twin Therapy
                  Flat Twin Therapy
                  wrote on last edited by Flat Twin Therapy
                  #28
                  @Maarten-v
                  I have indeed the same. I cannot use navigation because of the battery drain...
                  To be honest... Battery drain.. + the Android app just crashes very, very (very!) often, of which I cannot recover safely due to gloves on, while riding motorcycle...
                  This makes the app actually useless... ;( ;(
                  I'm only using it for trips I already know, to test if these 2 issues are solved yet, so that I can actually start using it.
                  @Corjan-Meijerink any updates on the battery drain and the crashes (android)? Is there perhaps anything that I can help? Perhaps sharing logsfiles, if that is possible?
                    @Maarten-v
                    @Rolf-Aalders both will be more intensively investigated after the CarPlay update
                    • Jure Sirena 0
                      Jure Sirena 0
                      Jure Sirena 0
                      We are all reporting same issue to guys they know it. We have to stop using app to save battery even if charged. What is interesting (at least what I’ve noticed) that almost all reported issues are on iphone 13….mine is iphone 13 pro, ios 16.3.1
                      Just an observation
                      • Jörgen
                        No, also noticed with iPhone X.
                        The little 12-5Volt converter plug does not supply enough power to compensate for the consumption, the iPhone was empty after 1 hour (start at 45% battery charge).
                        But because this is known, I'm sure it will be solved soon. 👍
                        • Nick Carthew
                          I will add my findings to this debate. Yesterday I used the app to navigate and track a route of about 120 miles. I stopped several times and paused the tracking. The original route was 66 miles and when I reached the destination I chose to edit the route and I added several route points to take me back home. The first of these new route points was RP7 so when I opened the newly edited route I gave a long press on RP7 to set as the start point. Everything worked perfectly as it should have.
                          My phone is an iPhone 11 and it's mounted on a Quadlock handlebar mount. I had it plugged into a 12v supply via a usb cable. My phone had about 80% battery when I started and when I got home the battery was at 100%. I also noticed that there was no significant heat despite the phone being within the Quadlock case. I had no other apps open while navigating.
                          • RetiredWingMan
                            I also find battery usage to be excessive - Older Samsung Galaxy S7 - MRA Mobile Next app 3.2.9. Battery usage was so bad during one hour of navigating I had to stop it. The phone was connected for fast charging. The phone was hot. I'm hoping that once I can download maps to my SD Card and run offline that battery usage will be significantly reduced. That is how I currently run with MRA Navigation - GPS and WIFI only. No cellular service.
                            • Mopetenpit Mopetenpit
                              My contribution to the topic "battery charging". I drove a short distance today with the bike and Navigation Next. At the start I had a battery charge of 73%, at the finish was 64%. The route is 3.4 km long and of course only takes a few minutes. Equipment: iPhone 13 pro, iOS version 16.3.
                              Ad Koppenol
                              Ad Koppenol
                              Ad Koppenol
                              @Mopetenpit said in Battery drain when navigating:
                              Ook de batterij op mijn iPhone 13 Pro, iOS 16.3.1 loopt snel leeg. Tijdens een rit van een uur verloor de accu 2% aan volume, terwijl hij aan de USB-oplader 12V van de auto was aangesloten. De iPhone werd ook erg warm. Zo durf ik geen gebruik te maken van de app tijdens de lange ritten in de vakantie.
                              Flat Twin Therapy CD130 2 Replies Last reply
                              • Ad Koppenol Ad Koppenol
                                Flat Twin Therapy
                                Flat Twin Therapy
                                Flat Twin Therapy
                                Can you give a status update on the battery performance while navigating on Android? Has that been fixed?
                                Thanks!
                                  Thanks!
                                  @Rolf-Aalders actively in progress. We are working closely with HERE to improve the performance.
                                    This post is deleted!
                                      Flat Twin Therapy
                                      Flat Twin Therapy
                                      Flat Twin Therapy
                                      Oh that is really good to hear. Thanks!
                                      This is the only issue preventing me from actively using it.
                                      • Rob Verhoeff
                                        Today I took a drive with connected iPhone 13 to the USB port via cable. I have no idea if the phone became too hot (you can't feel it with gloves on 😁 ), but the battery logging indicates that charging stopped at 85%. The iPhone has an internal safeguard to protect the battery. I have complete confidence that everything will be fine.
                                        • Karl Mumford
                                          Karl Mumford
                                          Karl Mumford
                                          I have just returned from a trip to Ireland where I tried to use the new MyRoute app to navigate with my Android 10 Ulefone Armour X7 Pro. I found that even with the phone on charge with a 1.5A charger it was draining the battery enough to not be able to last the day.
                                          I switched back to using the MRA Navigator stand-alone app because that is able to allow the phone to charge up even when in use.
                                          MyRoute app version 4.0.1 - 194
                                          MRA Navigation version v1.6.12
                                          CD130 Karl Mumford 2 Replies Last reply
                                          Stephen Rowland
                                          Stephen Rowland
                                          Maarten v
                                          Maarten v
                                          Mopetenpit
                                          Mopetenpit
                                          Arno 0
                                          Arno 0
                                          infoevertkuiken.nl
                                          infoevertkuiken.nl
                                          M PRP
                                          M PRP
                                          Paul 41
                                          Paul 41
                                          Ad Koppenol
                                          Ad Koppenol
                                          Flat Twin Therapy
                                          Flat Twin Therapy
                                          Jure Sirena 0
                                          Jure Sirena 0
                                          Simannjo
                                          Simannjo
                                          Karl Mumford
                                          Karl Mumford
                                          Willy DEOM
                                          Willy DEOM
                                          • Positioning club Membership Locations every new planned route
                                            OGRIII
                                            OGRIII
                                          • Lock route editing
                                            50
                                          • Rangen
                                          • Informatie Routeplanner Next
                                            13
                                            27
                                            357
                                          • F012 Tracklog folder / routes folder / how is it going right now?
                                          • Bug with Avatar on profile
