  4. Next closes immediatly when starting a planned route
problemandroid 12huawei p30 pro
32 Posts 10 Posters 362 Views
    I am not able to start a route from the route library. The app immediately closes down. It remains active in the background, but when I re-open it from the background apps it shows no route. Instead it opens like it was closed before.
    Screenrecording here:
    https://photos.app.goo.gl/dHXxpUmxbR6vnFbx8
    Starting a route by entering a destination through the lookingglas seems to work as expected. I am using a Huawei P30 Pro. I have a CAT S52 also, at home, I'll try this evening if it does the same.
    So my first experience is not as enthusiastic as most others 😉
    EDIT:
    I tried a newly created short 5wp route and that showed the same problem.
    Also I restarted my phone after the update, to rule that out.
    Michel van Hagen MRA-Founderundefined 1 Reply Last reply
      EDIT:
      Michel van Hagen MRA-Founderundefined Offline
      Administrator
      @Con-Hennekens That's just fine here. Could you share a screen recording video?
      • Michel van Hagen MRA-Founderundefined Michel van Hagen MRA-Founder
        @Michel-van-Hagen-MRA-Founder, Michel, read my previous post again 😉
        Andrew Meltonundefined 1 Reply Last reply
          Andrew Meltonundefined Offline
          Andrew Melton
          I had the same issue downloaded the app rebooted the phone and start the app, then select / open a route and it displays but as soon as a I pressed start the screen went blank and returned to the desktop display. It did this several time but now after about 20 mins it seems to be working
          MRA V 3.2.4
          Phone Oppo X3 Lite
          OS Android 12
          Could be just taking its time to get configured maybe? Not tried using it to Navigate yet
            I have just tried on my CAT S52, this is the one I usually use on the bike. But it shows exactly the same issue. Besides Andrew I have not read anything similar. But I am guessing there is something in my account causing this. It cannot be a coincident that I am one of one, and have it on two phones...
            EDIT:
            I also tried my Lenovo Tablet now, and actually I DO get a step further... when I start navigating a route, it actually does start navigating. (slow because it's a cheap one). It beats me however, how my two much higher specced phones aren't doing what they should...
            • Andrew Meltonundefined Andrew Melton
              MRA V 3.2.4
              Phone Oppo X3 Lite
              OS Android 12
              @Andrew-Melton, Well I am many hours further, but no improvement. Glad it works for you.
                Strange. I would suggest uninstalling the app completely and clearing cache / data from Settings > Apps > MyRoute-app Mobile too.
                That might help! Especially since this is the first report of such issues, I am a bit unsure of what the issue can be.
                  @Corjan-Meijerink, A complete re-install I tried while you were typing that request 😉 But it did not make a change (on both phones). Now I also followed your suggestion about the cache-data, and user data, and also that makes no difference...
                  • Is there some way to get diagnostic data to you?
                  • can you PM me with details of a known working account? Maybe I can test if it's account related that way.
                    @Con-Hennekens I’ll contact you personally tomorrow! 🙂
                      @Corjan-Meijerink, I need to withdraw some earlier findings because they were incorrect:
                      I stated that my tablet did function with navigating, but later I found that it was navigating the "follow the line" method, not using Next's turn by turn.
                      Also I stated that a direct-to-destination route was navigatable (is that a word?), but also that one tricked me into the "follow the line" method. The difference between "follow the line" and "Turn by Turn" is not very clear. The icon that is used at A is identical to the icon used for a turn by turn route planned in the planner. I was thinking the icon for B would have something to do with multiple route suggestions, but apparently it does not.
                      @Corjan-Meijerink, you are welcome to contact me personally.
                        @Con-Hennekens I agree that the icons used can be slightly confusing. I'll make sure this is improved in the next update 🙂
                        We want the users to be able to use the Mobile app as they know and also allow Navigation Next users to use the Navigation. The current choice does work but doesn't provide the best experience.
                          @Corjan-Meijerink, I completely agree with that! I think the most logical way is to improve the Next icons, not the Planner icons. But most important right now (for me that is...) is to find a solution for the crashing app. It looks like that happens as soon as any Next turn-by-turn function gets called.
                          • MyRoute-app communityundefined MyRoute-app community moved this topic from [Beta] The MyRoute-app on
                          • Tim  Thompsonundefined Offline
                            Tim Thompson
                            Just adding my 2 cents here...
                            I've experienced this problem as well. Once it manifests, it seems to continue to fail (closes immediately when starting navigation). My current work-around is to open a different route and start it. This seems to work consistently. I then go back and select the original route and open/start it. For whatever reason, this seems to work.
                            Edit...
                            Just to clarify what I mean by starting a route...
                            If I get past that point - then all is good. But at times it is an "if".
                            Edit^2...
                            Also noted it closing unexpectedly with choosing to edit (pencil icon) from this screen.
                            • Tim  Thompsonundefined Tim Thompson
                              Edit...
                              Edit^2...
                              @Tim-Thompson, yes, that makes us two of a kind 😉 Bevause it seems to be a very rare problem.
                              I already told @Corjan-Meijerink, this in a support chat, in my experience once my first route-load works then, without quitting the app, I can load all thinkabel routes. But when the first load fails, I can't load any route until perhaps by force-closing the app.
                                This will be investigated coming week! 🙂
                                  @Corjan-Meijerink, I have full confidence 😉 I didn't mean to disturb your weekend!
                                    @Con-Hennekens You haven’t at all 🙂 No worries!
                                    • Hans Kremersundefined Offline
                                      Hans Kremers
                                      For what it ist worth, I'm seeing the same behaviour in a Huawei P20 Pro, Android 10
                                      After selecting and starting the navigation, the screen goes Black and the Desktop appears
                                      I tried several routes, all with the same result.
                                      Starting navigation with the same routes in a Lenovo P11 Pro (Android 12) works fine
                                      Regards,
                                      Hans
                                      • Hans Kremersundefined Hans Kremers
                                        Regards,
                                        Hans
                                        @Hans-Kremers Thanks! Tomorrow - Thursday are scheduled for app development so we’ll start the investigation shortly! 🙂
                                        ASPKundefined 1 Reply Last reply
                                          ASPKundefined Offline
                                          ASPK
                                          Je rencontre exactement le même problème avec mon Samsung S20FE.
                                          Si je démarre Next, je charge un itinéraire de la bibliothèque, je lance la navigation et l'application se ferme. Si je redémarre une seconde fois, çà fonctionne et je peux ouvrir tous les autres itinéraires sans soucis.
                                          b0hd1undefined
                                          ASPKundefined
                                          ASPK
                                          Mike Whitwamundefined
                                          Mike Whitwam
                                          Koen VHundefined
                                          Koen VH
                                          Hans Kremers
                                          Tim Thompson
                                          Andrew Melton
                                          • snelheid zichtbaar
                                            Erik 35undefined
                                            Erik 35
                                          • free ride
                                            Ewout 2undefined
                                            Ewout 2
                                          • Strange behavior
                                            white.mouseundefined
                                          • Just a little tweak
                                            Alex redsundefined
                                            Alex reds
                                          • MRA 5.0.1 - 433 Datei (Route) teilen an MRA
                                          • scenic route inkorten
                                            pehaundefined
                                            peha
                                            2.4k
