  3. Next
Next
21 Posts 10 Posters 1.3k Views 1 Watching
  • Daryl Greenundefined Offline
    Daryl Green
    I have just received a post on Facebook about MyRoute App Next , at the moment I am a Gold member of MRA and also have The navigation App too, I’m failing to understand the advantages of or the need to purchase The MRA Next App could someone please explain this to me
    • Daryl Greenundefined Daryl Green
      Nick Carthewundefined Online
      @Daryl-Green said in Next:
      MRA Navigation Next will be a totally new app built from the ground up. It will supersede the old navigation app and those with an existing lifetime account for MRA Navigation will automatically have their accounts transferred over to MRA Navigation Next.
      MRA Navigation Next and SilverFox B8J bar buttons.
      Quadlock wireless mount for IPhone 11.
      Cardo Scala Packtalk Bold.
      TomTom Rider 500. (In the cupboard now)
      sudoleaundefined Siepermann- Ronaldundefined 2 Replies Last reply
        sudoleaundefined Offline
        sudolea
        @Nick-Carthew said in Next:
        .... It will supersede the old navigation app and those with an existing lifetime account for MRA Navigation will automatically have their accounts transferred over to MRA Navigation Next.
        <sceptical mode>
        ... and the update will come the day right before your next holiday trip starts 😊
        </sceptical mode>
        Drabslabundefined Con Hennekensundefined 2 Replies Last reply
          Siepermann- Ronaldundefined Offline
          Siepermann- Ronald
          @Nick-Carthew wordt er ook gekeken naar de werking van de Next/app in Apple Carplay.
          Gebruik momenteel op de motor Navigation in combinatie met Apple CarPlay.
          Als navigatiemiddel is deze combinatie onbetrouwbaar. Veelvuldig vastlopen van de display op het stuur en regelmatig moet de navigation App opnieuw opgestart worden het Automatisch verwijderen van de voorbij gereden tussenpunten werkt ook niet goed. Soms maar 1 en maximaal 3 tussenpunten worden verwijderd.
          Hoop dat maar dit soort problemen is/wordt gekeken.
          • Siepermann- Ronaldundefined Siepermann- Ronald
            @Siepermann-Ronald MRA Navigation Next wordt een volledig nieuwe en opnieuw ontworpen app die moderne codering zal gebruiken. Dit zal de ontwikkelaars in staat stellen om problemen een stuk gemakkelijker af te stemmen.
            • sudoleaundefined sudolea
              <sceptical mode>
              </sceptical mode>
              Drabslabundefined Offline
              @sudolea said in Next:
              <sceptical mode>
              </sceptical mode>
              Butveverything will work flawlessly😜
                <sceptical mode>
                </sceptical mode>
                <sceptical mode>
                </sceptical mode>
                Probably yes, I saw an ETA of 1st of June. But I think the "old" app will still be usable, so I would not panic šŸ˜‰
                Streetpilot 2610 / Zumo 660 / Zumo 395 / CAT S52 + MRA app
                  <sceptical mode>
                  </sceptical mode>
                  @Con-Hennekens said in Next:
                  <sceptical mode>
                  </sceptical mode>
                  Most likely, the old app will disapear the same moment the new one becomes available
                  • Drabslabundefined Drabslab
                    <sceptical mode>
                    </sceptical mode>
                    @Drabslab said in Next:
                    Why?
                      Why?
                      Because, to my knowledge, the same happened when the new version of "mobile" was introduced"
                      and it is general practice to make "old" versions dissapear from production as soon as a new one is available because it takes a lot of effort and resources to maintain two versions in parrallel. Often also because the underlying databases are not fully compatible.
                      Potentially, the best thing will be to have an automated and automatic upgrade from the current nav app, to next, which may of course lead to some confusion as we have seen in the past when updates of mobile and the routeplanner caused quite some anger on this forum.
                      Hence, good testing making sure that it all works, and good communication (and here i don't mean the typical publicity messages) well on time (not 24h before the new version rolls out) would be key.
                      A managed upgrade scenario may perhaps be beneficial.
                      Nick Carthewundefined Con Hennekensundefined 2 Replies Last reply
                        The current MRA Navigation is a separate app the new MRA Navigation Next will run inside MRA Mobile so for the transition period both app will run.
                          That was an inline update. It has been told multiple times Next will be a complete new separate app and therefore it will not interfere with the existing Navigation app.
                          The "anger" we have seen probably DOES NOT make it potentially the best thing after all?
                          Having it in a separate app has the benefit of being able to manage the transition yourself šŸ˜‰ If learned ANYTHING from the Mobile app, it is that an automatic irreversible upgrade is not desirable, especially with that many changes, and especially mid season for the largest part of the userbase.
                            yep, timing is crucial, and decent communication ...
                            To summarise, it ain't that easy. šŸ™‚
                              @Drabslab @Con-Hennekens The Navigation app (as it now is) will continue to exist in the early stages of Navigation Next. This is because the Next app is developed with MyRoute-app Mobile (yeej, finally one single app to rule them all).
                              This means that the Navigation app will always be a backup during the first months. Somewhere early 2023 the Navigation app will be removed and the Mobile app (with Navigation Next in it) will have fully replaced the Navigation app as you now know it.
                              So long story short. When we are done, there is one app. The MyRoute-app šŸ˜‰
                                @Corjan-Meijerink said in Next:
                                @Drabslab @Con-Hennekens (yeej, finally one single app to rule them all).
                                UNLIMITED POWER
                                Sauron will love it!!!
                                • Davide Meloncelliundefined Offline
                                  Davide Meloncelli
                                  hi guys I wrote twice to the MRA navigation next form, no answer.
                                  Before buying MRA Navigation next in presale, I ask if the new app will have the navigation item menu and voice navigation in Italian.
                                  thanks
                                  Davide
                                  • Davide Meloncelliundefined Davide Meloncelli
                                    thanks
                                    Davide
                                    Hans van de Ven MR.MRAundefined Online
                                    @Davide-Meloncelli
                                    Hi @Davide-Meloncelli Yes, the intention is to offer Next in the languages that are also available on the website. (Dutch, English, German, Spanish, French, Italian)
                                    • Tony 13undefined Offline
                                      Tony 13
                                      I was trying to find out what will happen to my lifetime Gold membership. I had asked MRA over a week ago but heard nothing back. I have not found anything on this. Anyone know what is happening?
                                      Hans van de Ven MR.MRAundefined Nick Carthewundefined 2 Replies Last reply
                                      • Tony 13undefined Tony 13
                                        @Tony-13
                                        When you have MRA Navigation lifetime nothing changes
                                          @Tony-13 said in Next:
                                          Hi Tony. Your question is a little confusing because lifetime gold is referring to the route planner. MRA Navigation does not have a gold account option.
                                          If however you have a lifetime account for MRA Navigation then when MRA Navigation Next is released, your lifetime account will automatically be upgraded to MRA Navigation Next.
                                          Tony 13undefined
                                          Tony 13
                                          Drabslabundefined
                                          Siepermann- Ronald
                                          sudoleaundefined
                                          sudolea
                                          Daryl Green
                                          Davide Meloncelli
                                          • Navigation
                                            Nick Dawsonundefined
                                            Nick Dawson
                                          • route wordt door MRA tijdens rijden gewijzigd; routepunten worden overgeslagen
                                            M. Schrijverundefined
                                          • Updated beta! 4.4.0 (403)
                                          • Oukitel RT3 PRO
                                            Paul e9undefined
                                            Paul e9
                                          • Vraag over gebruik tablet
                                            Arjan de Vriesundefined
                                            Arjan de Vries
                                          • MRA and tunnels
                                            Rob Verhoeffundefined
                                          • Herberekenen loopt vast
                                            134
                                          • garmin 1095
