  3. Terrain map not visible?
18 Posts 8 Posters 2.6k Views 1 Watching
  • Frans Halleen Frans Halleen
    Is er ergens een MRA guru/werknemer die hier iets over kan zeggen? Of gewoon fixen?
    En inderdaad, de satteliet en hybrid kaarten van HERE zijn ook niet beschikbaar...
    Jack van Tilburg Offline
    Jack van Tilburg
    @Frans-Halleen
    You can create a Support ticket (click).
    • Nick Carthew Offline
      Problem resolved.
      TJ189 1 Reply Last reply
        Problem resolved.
        TJ189 Offline
        TJ189 Offline
        TJ189
        @Nick-Carthew Here Default only partially showing, a number of other maps not showing at all
        • TJ189 TJ189
          @TJ189 Try again.
          Rob Verhoeff TJ189 2 Replies Last reply
            @TJ189 Try again.
            Rob Verhoeff Offline
            @Nick-Carthew the speed of loading maps is still not OK!
            HERE standard map loads partially...
            After refreshing the screen some other blocks won't show.
              @TJ189 Try again.
              TJ189 Offline
              TJ189 Offline
              TJ189
              @Nick-Carthew Nope,
                The developers are looking at it right now and a fix should only take a few minutes.
                • Robert Bürgisser Offline
                  Robert Bürgisser
                  Thank you for working to solve the problem. Very sympathetic. I've had the problem for about 3 days.
                  • Corjan Meijerink Offline
                    HERE terrain / satellite / hybrid maps are visible as expected.
                    I am looking into the loading issues right now. We are experiencing quite some visitors at this point. Trying to add some more capacity!
                    Rob Verhoeff Herko ter Horst 2 Replies Last reply
                    • Frans Halleen Offline
                      Frans Halleen
                      Maps are visible, thank you for your help
                        @Corjan-Meijerink no more dropouts. Thnx 👍
                          Herko ter Horst Offline
                          @Corjan-Meijerink it's not fixed when I look at it now. The TomTom map also seems to be flaky, especially when zooming first in, then out a single level.
                            #17
                            @Herko-ter-Horst weird... no lag in zooming in or out over here with any map (10:12pm).
                            Edit 10:35pm: it becomes weirder... I started a complete new session in Firefox and then zoom in to the max. The screen builds up pretty quick. Zooming out again and I experience lag in building the map. So @Herko-ter-Horst do has a point!
                              TJ189 Offline
                              TJ189 Offline
                              TJ189
                              Here Default still not responding correctly
                              Jack van Tilburg
                              Jack van Tilburg
                              TJ189
                              TJ189
                              Frans Halleen
                              Frans Halleen
                              Robert Bürgisser
                              Robert Bürgisser
                              • It was not possible to find a correct route to Wheels Through Time
                                Rob Veerman
                                Rob Veerman
                                134
                              • Duur van de route klopt niet
                                28.6k
                              • Gidday from New Zealand.
                                Bull Tahr k 0
                                Bull Tahr k 0
                              • Beeld loopt achter
                                Maarten van de Wijdeven
                              • Traject controle
