  2. Routes & Tracks
  3. How to merge two tracks
tracksmerge
12 Posts 5 Posters 3.8k Views 1 Watching
  • S. Strasserundefined Offline
    S. Strasser
    Is there a easy way to merge two or more tracks
    Jack van Tilburgundefined Nick Carthewundefined Hans van de Ven MR.MRAundefined 3 Replies Last reply
    • S. Strasserundefined S. Strasser
      Jack van Tilburg
      @shinja-strasser
      You can merge route. You can not merge tracks.
        Nick Carthewundefined Offline
        @shinja-strasser As @Jack-van-Tilburg said, you can’t merge tracks but you can convert the tracklogs to routes and then merge them.
        sudoleaundefined 1 Reply Last reply
          @Shinja-Strasser
          https://youtu.be/ickvZkgX7dQ
          Jack van Tilburgundefined sudoleaundefined 2 Replies Last reply
            @Shinja-Strasser
            Jack van Tilburg
            @hans-van-de-ven-mra-master
            @Shinja-Strasser
            'Manual 'Display and merge multiple routes' (click)
              @Shinja-Strasser
              sudoleaundefined Offline
              sudolea
              @hans-van-de-ven-mra-master said in How to merge two tracks:
              @shinja-strasser
              • sudoleaundefined sudolea
                @shinja-strasser
                Jack van Tilburg
                @sudolea
                This one is a MRA support article:
                  sudolea
                  @nick-carthew said in How to merge two tracks:
                  ... which unfortunately doesn't work very well with longer routes (e.g. a route through France from North to South), as these don't retain enough routepoints to keep it equal to the original track...
                  And yes, there are use cases where I've missed this (I could specify, if really needed), despite the adagio "split your routes into smaller chunks".
                    @sudolea said in How to merge two tracks:
                    If route ‘A contains 20 route points and route ‘B contains 20 route points when you merge them the new route will contain 40 route points.
                      sudolea
                      @nick-carthew Then the problem is with the conversion of the individual tracks to the individual routes, as I saw significant differences. The explanation I had found out for myself (maybe not correctly), was the limitation of the number of route points - because, if I remember correctly, I already was confronted in the past with that limitation... Maybe that was not the explanation, but the differences were significant anyhow...
                      I know, the "answer" with differing routes in such cases is to make the routes equal to the original tracks. However, this wasn't feasible in my use case : way to much work for the simple test I wanted to do (i.e. to see how much riding time this long trip would take).
                        @sudolea When you convert a track to a route, a pop up box appears reminding you to check each route point for accuracy.
                          sudolea
                          Yes, but I did mention I didn't have the time for my use case, did I ? I wasn't planning a trip, I just wanted to know how long riding time this route took.
                          Whereby I mean there really are use cases where the possibility to merge tracks is useful. Nothing more (FWIW, I got the information I was after, using BaseCamp).
                          S. Strasser
                          Jack van Tilburg
                          sudoleaundefined
                          sudolea
                          • Hello, i want to make a trip to the Dolomieten (cortina )from Halle 1500(Belgium) in about 3 days. came somebody tell me a nice route or what i must avoid?Thanks
                          • Free Ride Mode - Speed Warnings
                          • Riding mode in routeplanner
                            luc 1aundefined
                            luc 1a
                          • Next+ 1st impressions
                            GT JWRundefined
                          • Shaping points and Via points
                            Herman Veldhuizenundefined
                            1.3k
