  3. MRA Navigation APP
MRA Navigation APP
59 Posts 8 Posters 44.1k Views 3 Watching
  • HABVEN aka MrMRA
    @Kudee
    Can you send me your route?
    hans@myrouteapp.com
    Kudee 1 Reply Last reply
    • HABVEN aka MrMRA
      @Kudee
      Track is there in Basecamp, roads NOT 😠
        @Kudee
        hans@myrouteapp.com
        Kudee
        Kudee
        Kudee
        @Hans-van-de-Ven-MRA-Master said in MRA Navigation APP:
        hans@myrouteapp.com
        Just sent
        • HABVEN aka MrMRA
          Strange, you're route....
          Kudee Reinhard-32 2 Replies Last reply
            Kudee
            Kudee
            Kudee
            Reinstall the Map on your Computer, That is Windows Maschine?
            • HABVEN aka MrMRA
              @Kudee
              Did not work, no roads there
                @Kudee
                Kudee
                Kudee
                Kudee
                @Hans-van-de-Ven-MRA-Master Windows or IOS?
                • HABVEN aka MrMRA
                  Win 10 Prof
                    @Hans-van-de-Ven-MRA-Master Make sure that the detail level is set to the highest and use a appropriate zoom level.
                    Kindly regards
                    Reinhard
                    Montana 700i and Mac
                    • HABVEN aka MrMRA
                      #38
                      Is set on the highest level and max zoom
                        Kudee
                        Kudee
                        Kudee
                        wrote on last edited by Kudee
                        #39
                        @Hans-van-de-Ven-MRA-Master Can you Upload the Files somewhere so other Basecamp Users can check?
                        • Reinhard-32
                          Or set the route to publish and share.
                          Kindly regards
                          Reinhard
                          • HABVEN aka MrMRA
                            The problem is that in Basecamp the road is not there.
                              #42
                              @Hans-van-de-Ven-MRA-Master I can check it at my Win10 PC and my iMac pro but I have problems to find the exact location of the missing or not shown road in the map.
                              Kindly regards
                              Reinhard
                              • Reinhard-32 Reinhard-32
                                Kudee
                                Kudee
                                Kudee
                                @Reinhard-32 https://www.myrouteapp.com/route/open/5364210/mobile#43.58887733921692;17.518429756164554;14///
                                On MY Basecamp the Road ist ok 🙂
                                • Reinhard-32
                                  #44
                                  Thanks for sharing the route. I have open the route in BaseCamp on both machines and found no differences. The gravel road is not there.
                                  Then I checked it at Here maps with the same result: The gravel road is not in the Here / Garmin map.
                                  When you switch off the track then you can see that the gravel road is not there.
                                  HERE Map:
                                  Map in BaseCamp on IMac with visible red track:
                                  Map in BaseCamp on Mac with invisible track:
                                  Kindly regards
                                  Reinhard
                                  • HABVEN aka MrMRA
                                    Same here
                                    • HABVEN aka MrMRA
                                      I think the conclusion is that Garmin provides different maps in different countries.
                                      Reinhard-32 Kudee 2 Replies Last reply
                                        @Hans-van-de-Ven-MRA-Master No Hans, I don‘t think so. Here is the creator of the map and sells them to Garmin. Garmin prepared the map for using at garmin sat navs. When you look at the origin here map then yo can see that the discussed road is not there.
                                        https://wego.here.com/?map=43.59131,17.52787,13,normal
                                        Kindly regards
                                        Reinhard
                                          Kudee
                                          Kudee
                                          Kudee
                                          Friends, I am embarrassed. This road doesn't exist in Basecamp and I didn't realize it. Shame on me. What I did is imported the track into Basecamp and converted it to a route. Looked at it in Bacecamp and it looks like a route.
                                          Now I have loaded the route on my 595, the calculation works and the route can be started.
                                          So again checked the Zümo, I do not have OSM maps installed.
                                          I am now quite confused, thought I understand it after all these years.
                                          Would Garmin now route me on the route even though it does NOT exist on the map?
                                          Again, apologies and thanks to all.
                                          lg Kudee
                                          Translated with www.DeepL.com/Translator (free version)
                                          Kudee
                                          Kudee
                                          Steve Lynch
                                          Steve Lynch
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
                                            162
