  3. MRA Navigation APP
MRA Navigation APP
59 Posts 8 Posters 44.1k Views 3 Watching
  • Kudee
    Kudee
    Kudee
    @Matt-Flaming I have 1.6.10. Not Showing as Beta. Would like to test new Versions if avaiable
    • Steve Lynch
      Steve Lynch
      Steve Lynch
      @Matt-Flaming
      It says Beta so I will treat it as a Beta and always have a backup plan with me, the Tom Tom Rider 550 😁
      The most interesting thing in this release is the ā€œAlways place Waypoints on the Roadā€ option.
      Maybe this has been there for a while but I have just started using MRA Navigation again recently for the last month.
      So in edit mode in MRA Navigation after you have created the first waypoint, all Waypoints you add thereafter are guaranteed to be exactly on the nearest Route Line.
      That may well be quicker than doing it in MRA Planner as no need to fully zoom for each waypoint.
      And if you create a route in MRA Navigation it does then pull into MRA Planner.
      Pretty cool methinks.
      For me I have had only one issue with it where I had a ā€œfigure of 8ā€ route that had Waypoint 2 appearing twice on the route because the route came back through the same Road I started on.
      It was an easy fix to just remove that particular waypoint which wasn’t even Waypoint Number 2 but was actually showing as Waypoint Number 2.
      I know there are users that are having issues with it so I’m just wondering how we as a community can support those users.
      I guess the issues are based on the fact that there are so many different Android variants and the different manufacturers often put there own UI version on it.
      Maybe if Android users declared their Phone make and model then users on the same models could try to re-create issues that others on the same model are having.
      I’m on a Samsung S10 so if any users are having issues on those then I would be happy to try to re-create any issues, share my settings etc etc etc.
      • Steve Lynch
        Steve Lynch
        Steve Lynch
        @Matt-Flaming
        If you want to share the route that crashed I’d be happy to try it my end on the Samsung S10. (Sort of similar)
        • Steve Lynch
          Steve Lynch
          Steve Lynch
          @Matt-Flaming
          Ok fair enough.
          • Steve Lynch Steve Lynch
            If you go back in the Play Store and look at the full description you should see plenty of Beta notices throughout.
            Unless they have another version running in parallel that is not Beta.
            @Steve-Lynch said in MRA Navigation APP:
            Indeed, seems like I am using the beta after all, I never noticed it, it worked without any issues throughout the whole year.
            • Steve Lynch
              Steve Lynch
              Steve Lynch
              @Matt-Flaming
              I suppose the text in my screenshot above confirms what you are saying Matt.
              ā€œFuture updates will include Beta versions.ā€
                @Steve-Lynch, Similarly I used to prepare my Zumo 390 for the "just in case" scenarios. Now I have a CAT S52 navigation/phone running MRA Navigation, I do not see the benefit of the Zumo anymore.
                I am running version 1.6.10 too, but I am not aware of it being a beta, and it does not get mentioned in the app.
                Kudee
                Kudee
                Kudee
                Gravel Roads, Here can't. OSM no Problem
                Even Garmin Basecamp knows this Road. Thats a bit dissapointing for me.
                lg Kudee
                  @Matt-Flaming
                  Ah, so I am not in beta YET, but WILL BE as soon as they release one?
                  • Kudee Kudee
                    lg Kudee
                    @Kudee said in MRA Navigation APP:
                    Yes, I looked it up in MRA and see the same. Also the TomTom map uses that gravel road, without a problem. On the HERE map that road is completely absent, and of course then you can't navigate it. It is a gap in the Here map.
                    I have difficulty in believing that Basecamp DOES show this road on the HERE map. That would implicate that the HERE map used by MRA is NOT equal to the HERE map Garmin uses, unless it is a version difference and that road has been added recently, in which case it would be interesting to know the map versions. Maybe someone from MRA can elaborate on this?
                    Are you sure you are not using OSM maps or some other map in Basecamp?
                    Kudee 1 Reply Last reply
                    • HABVEN aka MrMRA
                        Kudee
                        Kudee
                        Kudee
                        wrote on last edited by Kudee
                        This is Garmin Basecamp
                        • HABVEN aka MrMRA
                          wich version of the ntu card do you use?
                            Kudee
                            Kudee
                            Kudee
                            @Hans-van-de-Ven-MRA-Master
                            • HABVEN aka MrMRA
                              • HABVEN aka MrMRA
                                So there is a defference in NTU maps per country??
                                  Kudee
                                  Kudee
                                  Kudee
                                  #23
                                  Thats verry strange. Just checked it on my secound PC, same. All Roads, no problem.
                                  What is your Zoom Level? Highest?
                                  • Kudee Kudee
                                    @Kudee
                                    yes
                                      @Kudee
                                      yes
                                      Kudee
                                      Kudee
                                      Kudee
                                      @Hans-van-de-Ven-MRA-Master too many mountains is therefore not indicated in Basecamp for Dutch people šŸ˜€ šŸ˜€
                                      • HABVEN aka MrMRA
                                        @Kudee Do you have your zumo connected?
                                          Kudee
                                          Kudee
                                          Kudee
                                          #27
                                          @Hans-van-de-Ven-MRA-Master No. Only Basecamp Map installed.
                                          Kudee
                                          Kudee
                                          Steve Lynch
                                          Steve Lynch
                                          • The menu option ā€œContinue with your last routeā€ is missing
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
                                            162
