  4. Assign a via point/waypoint number
40 Posts 16 Posters 18.6k Views 6 Watching
  • Corrado Miniati
    wrote on last edited by Corrado Miniati
    #21
    "May it would be possible, to get the populated number as editable".
    This is exactly my propose to Corjan.
    BMcG 1 Reply Last reply
    • Corrado Miniati Corrado Miniati
      BMcG
      BMcG
      BMcG
      Hi @Corrado-Miniati-0 to me your method of planning a route is a bit unusual, it is not the regular way routes are planned in MRA hence why your having the pain of reordering your points
      I am not saying your method is wrong it is just not the regular way of using MRA for creating a route
      One suggestion that might ease your pain could be to type the coordinates of your points into a CSV file via a text editor or Excel
      You can then upload these points into MRA as Points of Interest (POI)
      You then start adding route (waypoints) next to each of the POI in the order you wish
      Then you can delete remove the POI's & your left with the route you want
      just a suggestion that may be a little less painful
      BlackView BV7100, Android 12
      • BMcG BMcG
        @Brian-McG that is exactly, what I wanted to type, but I was stuck in a big portion if French fries with Dutch mayonaise and homemade peanutbuttersauce. Or, as we call it in the Netherlands a "patatje oorlog" or fries at war 🙈🤣
        MRA Lifetime Gold
        • Corrado Miniati
          @Brian McG:
          It may be that my planning system is unusual, but I've always found it convenient to plan this way.
          Thanks for your suggestion, too; it's very clever, but even this way involves extra work outside of MRA, and it's probably not faster than moving waypoints from the list directly into MRA.
            @Brian McG:
            BMcG
            BMcG
            BMcG
            @Corrado-Miniati-0 sorry you do not see the advantages of the method I proposed
            I do not think it is extra work,
            currently you type in the coordinates in MRA, in the proposed method you type them in Excel & just import the csv
            so now you are in the same state as you would be with your current method
            with your method you now have to sort the order of all your points
            with the proposed method all you have to do is click next to each of the POI in the order you wish the route to be
            IMO it would be a lot faster & a lot easier than your current method, especially if you have a large number of points
            I hope you try it & see, there are other advantages to having your points captured in a POI list
            • Corrado Miniati
              Thanks so much for your support.
              I tried, but it doesn't work. Could you please show me how to set the coordinates in Excel and what CSV format you choose for saving?
              • Mzokk
                Mzokk
                Mzokk
                Your CSV need to be Long, Lat and a description of the POI.
                Here's one of mine.
                Mzokk 1 Reply Last reply
                • Mzokk Mzokk
                  Here's one of mine.
                  Mzokk
                  Mzokk
                  Mzokk
                  This is what the uploaded POI's look like.
                  • Corrado Miniati
                    This post is deleted!
                    • Corrado Miniati
                      #30
                      I discovered that MRA doesn't display POIs from csv file if they're imported as lat-lon instead of lon-lat.
                      My Google Maps displays them as lat-lon, and in Excel I have to reverse the parameters. Why?
                      However, there is an alternative method, but it would be appreciated if MRA allowed renaming the waypoint positions.
                      BMcG BertM 2 Replies Last reply
                        BMcG
                        BMcG
                        BMcG
                        wrote on last edited by BMcG
                        #31
                        @Corrado-Miniati-0 the easy way to understand the format is to create a map / route in MRA with some POI's
                        then save the route as a CSV
                        you can then inspect the csv & replicate the format
                        when you create your own custom CSV to import your points, import it via the Library tab
                        you will need to zoom into >=10km to see the imported POI's
                        yes the lon-lat v lat-lon is an oddity of MRA, I dont know why, maybe it is a dutch thing 😊
                        the points will be displayed just not in the part of the world you are expecting to find them 😂
                        • Corrado Miniati
                          Thanks, maybe Corjan could check if the lat-lon vs lon-lat theme is a bug
                            It definitely is not a bug 🙂
                            Do I find it logical for a user perspective? No.
                            Will I change it? No. Mainly because everyone using this is now used to that.
                            I do know the origin of these things.
                            Lat / lon is preferred by humans but I don’t know why. Lon / lat is however mathematically the correct order 🙂 Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
                            Guzzist 1 Reply Last reply
                              #34
                              @Corjan-Meijerink said in Assign a via point/waypoint number:
                              ...Lon / Lat is however mathematically the correct order 🙂 Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
                              uhh, I believe it's not 100% correct explained.
                              • The geographical length, also called longitude (international abbreviation long or LON), describes the position east or west of a defined (arbitrarily defined) north-south line, the zero meridian. It's following the vertical earth axis.
                              • The geographical latitude, also called geodetic lat or (international abbreviation Lat. or LAT), describes the position north or south of a defined line round the earth, parallel to the Earth's horizontal equator.
                              But the rest, Corjan - you may know better than me 😉
                              Nothing is impossible ;-)
                              • Edwin_M
                                Edwin_M
                                Edwin_M
                                Also if you search for an address and what to add that to the route is will always be added at the end. So then you need to drag to the correct position.
                                I agree that a shorter way to edit the position of the point in the route would be a good functionality
                                • Corrado Miniati
                                  In my case, but I think for many if not all users, it would be a very significant update.
                                    @Corrado-Miniati-0 said in Assign a via point/waypoint number:
                                    If you look at an exported KML file the lat/lon is reversed when exported, so the display in Google is different as the exported file.
                                    • Corrado Miniati
                                      @Bert, thanks for the explanation.
                                      Unfortunately, the current inconvenience remains.
                                      BertM 1 Reply Last reply
                                        yes, I agree.
                                        • Michele Skipper
                                          Michele Skipper
                                          Michele Skipper
                                          Vi posso assicurare, soprattutto se fai percorsi molto lunghi, che poter rinumerare il wp sarebbe una cosa che renderebbe la programmazione più semplice tantissime volte, è evidente che se ti domandi il perché non ti è mai capitato di doverlo fare, ma ame invece capita sempre ad ogni costruzione di un percorso, quindi mi aggiungo alla lista di coloro che vorrebbero questa cosa nel nuovo planner
                                          JP d
                                          JP d
                                          Edwin_M
                                          Edwin_M
                                          BMcG
                                          BMcG
                                          Mzokk
                                          Mzokk
                                          Kirsten De Weerd
                                          Kirsten De Weerd
                                          Michele Skipper
                                          Michele Skipper
                                          nomko
                                          nomko
                                            21
                                            74
                                            Marten Wiersma
                                            Marten Wiersma
                                          • Trains like Ferries?
                                          • Opstarten app in Android.
                                            Beemerfrankie
                                            Beemerfrankie
