  4. Assign a via point/waypoint number
40 Posts 16 Posters 17.1k Views 6 Watching
    @Lex.Kloet.RX One-nil to you.
    But who knows which cell phones can already be operated with a mouse these days. 😁
    @Peter-Zehentreiter said in Assign a via point/waypoint number:
    They all can... Just add a BT mouse.
    And especially having a mouse on your tablet (or large phone) is working really great for planning πŸ˜‰
      Travellexxie Offline
      @Peter-Zehentreiter I have a Samsung S22 Ultra with pencil, it has somewhat the same function as a mouse and works also very precise. And like @Con-Hennekens writes, you can also add a BT-mouse.
      Welcome in the world of electronics πŸ˜‚ (true there is a lot of electronic stuff I do not know πŸ˜‰ )
      Ducati Monster 1200 met Garmin ZΓΌmo XT
      MRA Lifetime Gold
        @Lex.Kloet.RX What you say is true, but if he wants an extra one, it's fiddly on a cell phone.
        I also move points around from time to time and use this technique.
        JP d Offline
        JP d Offline
        JP d
        @Peter-Zehentreiter on your phone you just use your finger to click on the black line (your route) to add an intermediate waypoint. Maybe he's using the add waypoint potion which then adds it to the end of the route instead of where the petrol station is. Just click on the line 🍻
        • Corrado Miniati 0 Offline
          Corrado Miniati 0
          wrote on last edited by Corrado Miniati 0
          I really appreciate all the feedback and am pleased to see the interest in the topic. I'll try to better explain the origins of my request.
          From my PC on Route Lab, when I start planning a trip, I enter the coordinates of the places I'd like to visit, but without any "geographical" order. I do it randomly, following the information I find online and that I already know.
          Consequently, there are points on the map that don't follow a logical order of the trip because I only do this once I've completed all the planning.
          Only then do I begin to arrange the various points in a logical travel order. So far, the only way I've found is to drag the points one by one to the correct position in the "Waypoint" list with the mouse. However, if the list is very long, not all the points are visible on the screen, and dragging the mouse is time-consuming and not easy. To move a point before or after the visible list, I have to do a sort of back-and-forth with the point always clicked, otherwise the scrolling gets stuck and doesn't flow smoothly.
          It would be much easier to be able to rename the points' placement, because the map immediately shows the logical order of my trip.
          Just as an example, in the map below I've simulated a trip with just a few waypoints. It would already be obvious to me that:
          • waypoint 9 should become waypoint 5
          • waypoint 5 should become waypoint 7
          • waypoint 7 should become waypoint 8
          If you're thinking of an itinerary with dozens and dozens of waypoints, then it's clear that renaming the waypoints would be a very welcome option.
          I hope Corjan considers this possibility.
          Thanks
            Corrado Miniati 0
            Guzzist 1 Reply Last reply
            • Corrado Miniati 0 Corrado Miniati 0
              Guzzist Offline
              Guzzist Offline
              #20
              @Corrado-Miniati-0 I have got your point, because I do planning for journeys similar.
              The system knows about the routepoint numbers and is using it for sorting the items in the list. Also the number is populated in the list item.
              May it would be possible, to get the populated number as editable. I see: manual sorting of a long list will then become quicker.
                Corrado Miniati 0
                #21
                "May it would be possible, to get the populated number as editable".
                This is exactly my propose to Corjan.
                Brian McG 1 Reply Last reply
                  Brian McG Offline
                  Brian McG Offline
                  Hi @Corrado-Miniati-0 to me your method of planning a route is a bit unusual, it is not the regular way routes are planned in MRA hence why your having the pain of reordering your points
                  I am not saying your method is wrong it is just not the regular way of using MRA for creating a route
                  One suggestion that might ease your pain could be to type the coordinates of your points into a CSV file via a text editor or Excel
                  You can then upload these points into MRA as Points of Interest (POI)
                  You then start adding route (waypoints) next to each of the POI in the order you wish
                  Then you can delete remove the POI's & your left with the route you want
                  just a suggestion that may be a little less painful
                  • Brian McG Brian McG
                    @Brian-McG that is exactly, what I wanted to type, but I was stuck in a big portion if French fries with Dutch mayonaise and homemade peanutbuttersauce. Or, as we call it in the Netherlands a "patatje oorlog" or fries at war πŸ™ˆπŸ€£
                    MRA Lifetime Gold
                      Corrado Miniati 0
                      @Brian McG:
                      It may be that my planning system is unusual, but I've always found it convenient to plan this way.
                      Thanks for your suggestion, too; it's very clever, but even this way involves extra work outside of MRA, and it's probably not faster than moving waypoints from the list directly into MRA.
                        @Brian McG:
                        Brian McG Offline
                        Brian McG Offline
                        @Corrado-Miniati-0 sorry you do not see the advantages of the method I proposed
                        I do not think it is extra work,
                        currently you type in the coordinates in MRA, in the proposed method you type them in Excel & just import the csv
                        so now you are in the same state as you would be with your current method
                        with your method you now have to sort the order of all your points
                        with the proposed method all you have to do is click next to each of the POI in the order you wish the route to be
                        IMO it would be a lot faster & a lot easier than your current method, especially if you have a large number of points
                        I hope you try it & see, there are other advantages to having your points captured in a POI list
                          Corrado Miniati 0
                          Thanks so much for your support.
                          I tried, but it doesn't work. Could you please show me how to set the coordinates in Excel and what CSV format you choose for saving?
                          • Mzokk Online
                            Mzokk Online
                            Your CSV need to be Long, Lat and a description of the POI.
                            Here's one of mine.
                            Mzokk 1 Reply Last reply
                            • Mzokk Mzokk
                              Here's one of mine.
                              Mzokk Online
                              Mzokk Online
                              This is what the uploaded POI's look like.
                                Corrado Miniati 0
                                This post is deleted!
                                  Corrado Miniati 0
                                  #30
                                  I discovered that MRA doesn't display POIs from csv file if they're imported as lat-lon instead of lon-lat.
                                  My Google Maps displays them as lat-lon, and in Excel I have to reverse the parameters. Why?
                                  However, there is an alternative method, but it would be appreciated if MRA allowed renaming the waypoint positions.
                                  Brian McG BertM 2 Replies Last reply
                                    Brian McG Offline
                                    Brian McG Offline
                                    #31
                                    @Corrado-Miniati-0 the easy way to understand the format is to create a map / route in MRA with some POI's
                                    then save the route as a CSV
                                    you can then inspect the csv & replicate the format
                                    when you create your own custom CSV to import your points, import it via the Library tab
                                    you will need to zoom into >=10km to see the imported POI's
                                    yes the lon-lat v lat-lon is an oddity of MRA, I dont know why, maybe it is a dutch thing 😊
                                    the points will be displayed just not in the part of the world you are expecting to find them πŸ˜‚
                                      Corrado Miniati 0
                                      Thanks, maybe Corjan could check if the lat-lon vs lon-lat theme is a bug
                                      • Corjan Meijerink Offline
                                        It definitely is not a bug πŸ™‚
                                        Do I find it logical for a user perspective? No.
                                        Will I change it? No. Mainly because everyone using this is now used to that.
                                        I do know the origin of these things.
                                        Lat / lon is preferred by humans but I don’t know why. Lon / lat is however mathematically the correct order πŸ™‚ Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
                                          Guzzist Offline
                                          Guzzist Offline
                                          #34
                                          @Corjan-Meijerink said in Assign a via point/waypoint number:
                                          ...Lon / Lat is however mathematically the correct order πŸ™‚ Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
                                          uhh, I believe it's not 100% correct explained.
                                          • The geographical length, also called longitude (international abbreviation long or LON), describes the position east or west of a defined (arbitrarily defined) north-south line, the zero meridian. It's following the vertical earth axis.
                                          • The geographical latitude, also called geodetic lat or (international abbreviation Lat. or LAT), describes the position north or south of a defined line round the earth, parallel to the Earth's horizontal equator.
                                          But the rest, Corjan - you may know better than me πŸ˜‰
                                          Michele Skipper
                                          Michele Skipper
                                          Edwin_M
                                          Edwin_M
                                          JP d
                                          JP d
                                          Kirsten De Weerd
                                          Kirsten De Weerd
                                          Corrado Miniati 0
                                          Corrado Miniati 0
                                          • Route Breakdown
                                          • The slow death of Zumo...
                                            Bull Tahr
                                            Bull Tahr
                                          • Saludo
                                            682
                                          • MRA Touring Romania Group
                                          • I can't see Road Closures
                                            Lary
                                            Lary
