  4. Here Maps not Recognizing Road is now Open
26 Posts 9 Posters 10.4k Views 5 Watching
  • Brian McG Brian McG
    @Adrian-Avram you can also edit & correct the Here map at https://mapcreator.here.com
    unlike OpenStreetMap where the edit is accepted almost immedialltey on trust, with Here each edit is reviewed before acceptance
    I find simple edits & changes with Here can take a few days to a couple of weeks OR they are not accepted
    if nothing has changed a year after your report then it has probably not been accepted
    Adrian Avram Offline
    Adrian Avram
    #21
    @Brian-McG said in Here Maps not Recognizing Road is now Open:
    As I said .... With HERE, I reported an issue more than one year ago, and nothing changed ...
    Nowadays you can check on Google Maps that a new street was built, if I add it to HERE, but nobody cares even to check and one years passes ?
    So I will stick to supporting and editing on OpenStreetMap !
    Best regards,
    Adrian
    Samsung S24 Ultra and Motorola Thinkphone with Android Auto
    MyRoute-APP (Planner+Navigation, GOLD Lifetime)
    Honda NC750X (2021) with CHIGEE Aio-5 Play
    • Adrian Avram Adrian Avram
      Con Hennekens Offline
      @Adrian-Avram said in Here Maps not Recognizing Road is now Open:
      Totally fine, but not helpful for MRA Navigation.
      I have heard much quicker acceptance of feedback from HERE too, by the way.
        Adrian Avram
        @Con-Hennekens well what can I say ... I tried, but its useless unless they will leave people to change the map and improve it. Here map is much limited than OSM map unfortunately ...
        Best regards,
        Adrian
          @Adrian-Avram, I understand what you are saying, but MRA Navigation happens to use HERE maps, not OSM.
            Adrian Avram
            @Con-Hennekens yes I know ... unfortunately 😬 😁
            Best regards,
            Adrian
            • John S Parry Offline
              @Brian-McG I now understand what you did. I missed where you actually changed the calculation map from HERE to OSM. I had in my head that you were simply changing to the OSM overlay on a HERE calculation map.
              So yes, that method works. 👍 Thanks.
              Kirsten De Weerd
              Kirsten De Weerd
              Adrian Avram
              Adrian Avram
              ErikMatthezing
              ErikMatthezing
              Reinhard-32
              Reinhard-32
              Ron Z
              Ron Z
                Mzokk
                Mzokk
                13.8k
                1.1k
              • Carpuride scherm vast
                1.2k
              • HERE maps updates
              • App probleem scenic route niet mogelijk
                Philip Verbeek
                Philip Verbeek
              • Latest version of the App?
                white.mouse
                white.mouse
              • Camperroutes
                paul69
                paul69
                1.6k
