  4. Here Maps not Recognizing Road is now Open
26 Posts 9 Posters 10.6k Views 5 Watching
  • Brian McG Brian McG
    Hi @John-S-Parry said in Here Maps not Recognizing Road is now Open:
    On Edit: I tried both TomTom and OpenStreetMap views as a workaround. I can place a waypoint in the closed section, but MRA won't create a route line to it.
    Sorry but I have to say it is possible to route along the CA-2 between Cedar Springs & Big Pines with both OpenStreetMap & TomTom selected as the routing options
    TomTom - https://www.myrouteapp.com/en/social/route/12058866?mode=share
    OpenStreetMap - https://www.myrouteapp.com/en/social/route/12053492?mode=share
    The Here option obviously does not route - https://www.myrouteapp.com/en/social/route/12058878?mode=share
    I am very confident that the idea in my first post, using OpenStreetMap or TomTom in offline mode works, as the second image in that post is actually MRA navigating along the CA-2 just outside Cedar Springs & heading towards Big Pines.
    All the red warning triangles are advising that the road in the Here map is not passable
    It is possible you may have another setting MRA that is preventing the routing in your account, if you share your route it may be possible to see why you cannot route along the CA-2
    John S Parry Online
    John S Parry Online
    @Brian-McG said in Here Maps not Recognizing Road is now Open:
    I think the above is where some of the confusion is. I don't use offline mode for route planning. I do almost all my route creation in the online Web Routeplanner. I then save routes as GPX 1.1 files for import into my Zumo XT for actual navigation. So, I still maintain it's not possible to use TomTom or OSM (while online) to route on a closed road. If I'm incorrect, I'm all ears for learning something more.
    I think the skip function mostly works. It's not perfect, but workable.
    Brian McG 1 Reply Last reply
    • John S Parry John S Parry
      Brian McG Offline
      Brian McG Offline
      @John-S-Parry "Offline" mode refers to navigating with the MRA mobile app so it does not apply to your use case
      In my previous post you can see that using TomTom & OpenStreetMap as the routing options they clearly route along the road between Cedar Springs & Big Pines
      If I export those routes as GPX1.1 they will be GPX files containing those routes & tracks following that path
      When you import them into the Zumo & depending on your settings it may re-calculate the route so it detours away from the CA-2 but if you selcect the track it should follow the path from Cedar Springs to Big Pines
      • Kirsten De Weerd Offline
        Kirsten De Weerd
        I tested @Brian-McG's suggestion of exporting the track using the OSM map and he's correct, as can be seen here:
        https://www.gpsvisualizer.com/display/map/20250902125300-05119-map.html
        The red line is the track, the blue line is the route (or rather routing points) that have been exported. Using the Track, the XT should calculate the correct route on its own.
        This however does NOT work if you set one of the shaping points to off-road.
        When exporting, it appears that in the background the route is calculated, ignoring the 'Skip' setting of the waypoint. If I set the 4th shaping point to skip, it draws a straight line in the routing, but when I export it using the OSM-maps, I still get a nicely routed track (which in some cases is not what you cant)
        • John S Parry Online
          John S Parry Online
          @Brian-McG Garmin GPS devices always recalculate when imported. Always. There is no way to turn that off. I intentionally turn off all GPS avoidance settings so that the Garmin calculation algorithms won't be influenced beyond my waypoints.
          I don't know what we're doing different. If I create a new named route to start and immediately go into the OSM and/or TomTom layer, I can't create a route anywhere along the closure. The web MRA Routeplanner simply won't don't it.
          I normally don't deal with tracks in my routing. I create routes with an abundance of waypoints to ensure directional behavior. In the case of using the MRA skip function, the track created along the closed section gets recalculated into the rest of the route.
          How you're getting OSM to route the closed section is still a mystery to me.
            Brian McG Offline
            Brian McG Offline
            @John-S-Parry the routing calculations in MRA are controlled in this drop down
            29c4f3ac-59c7-4646-9a31-1e96047ef2b5-1755462616223-7be96ad9-be99-45cc-99ac-aaa24d9e5de5-image.png
            The map layers are just graphic overlays they just show you where the roads are, they are not responsible for calculating the routing, it is irrelavant what Map Layer you use, they just make the screen look nice
            82728374-0a07-4fc3-8d60-9c50a765d6f9-1755463302362-8f4a81f2-bdf9-43b4-92fe-e760431a048f-image.png
              John S Parry Online
              #20
              @Brian-McG We have a block between each other that I don't know how to reconcile. The "skip" function works for my purposes. I'm OK at this point.
                @Adrian-Avram you can also edit & correct the Here map at https://mapcreator.here.com
                unlike OpenStreetMap where the edit is accepted almost immedialltey on trust, with Here each edit is reviewed before acceptance
                I find simple edits & changes with Here can take a few days to a couple of weeks OR they are not accepted
                if nothing has changed a year after your report then it has probably not been accepted
                Adrian Avram Offline
                #21
                As I said .... With HERE, I reported an issue more than one year ago, and nothing changed ...
                Nowadays you can check on Google Maps that a new street was built, if I add it to HERE, but nobody cares even to check and one years passes ?
                So I will stick to supporting and editing on OpenStreetMap !
                Adrian
                • Adrian Avram Adrian Avram
                  @Adrian-Avram said in Here Maps not Recognizing Road is now Open:
                  Totally fine, but not helpful for MRA Navigation.
                  I have heard much quicker acceptance of feedback from HERE too, by the way.
                    @Con-Hennekens well what can I say ... I tried, but its useless unless they will leave people to change the map and improve it. Here map is much limited than OSM map unfortunately ...
                    Adrian
                      @Adrian-Avram, I understand what you are saying, but MRA Navigation happens to use HERE maps, not OSM.
                        @Con-Hennekens yes I know ... unfortunately 😬 😁
                        Adrian
                          John S Parry Online
                          @Brian-McG I now understand what you did. I missed where you actually changed the calculation map from HERE to OSM. I had in my head that you were simply changing to the OSM overlay on a HERE calculation map.
                          So yes, that method works. 👍 Thanks.
                          ErikMatthezing
                          ErikMatthezing
                          Kirsten De Weerd
                          Kirsten De Weerd
                          Ron Z
                          Ron Z
                          • Transport modes?
                          • Is there a way to put a Home button in the program
                            Mike wiruth
                            Mike wiruth
                            rudi 2h 0
                            rudi 2h 0
                            siebo vd berg
                            siebo vd berg
                            419
                          • Google maps and Streetview
                            Stevedo 6 0
                            Stevedo 6 0
                          • How do i export or 'save as' a file into Garmin Camper 770 - Help
