  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 7.4k Views 7 Watching
  • Guzzistundefined Guzzist
    @Herman-Veldhuizen ...then you are lucky.
    The reasons are:
    • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
    • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
    • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
    It depends on the tunnel operator.
    Herman Veldhuizenundefined Offline
    Herman Veldhuizen
    #21
    @Guzzist the fact that it worked in all tunnels made me think that HERE maybe has made an improvement (i assume a newer version of the sdk is used since I last tried it). The cursor followed the tunnel shape.
    I will soon drive through the tunnel again in which I know MRA was struggling.
    I dont think that I made any changes on my phone to settings to improve the gps accuracy.
    • Garry Davisundefined Offline
      Garry Davis
      Never knew about the beacons in tunnels or activation in settings. Just activated mine in Google maps. Thanks for that.
      • Herman Veldhuizenundefined Offline
        Herman Veldhuizen
        • Herman Veldhuizenundefined Herman Veldhuizen
          i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
          TomOnTourundefined Offline
          TomOnTour
          @Herman-Veldhuizen
          I had exactly the same experience when I was in Norway last year. I also couldn't remember any problems in any oher tunnel I ever used: Neither in the alps, nor in the german tunnels like Elbtunnel.
          Greetings
          Thomas
          MyRoute-APP Navigation Next (V5.2.0 - 474) on DMD T665 Navigation phone and on DMD T781
          using iPad Pro (iPadOS 26.5) and Macbook Air (macOS 26.5.1)
          nomkoundefined
          nomko
          Rob Verhoeffundefined
          Peter Zehentreiterundefined
          Nick Carthewundefined
          Guzzistundefined
          Adrian Avramundefined
          Adrian Avram
          Herman Veldhuizen
          Makroundefined
          Makro
          Guztundefined
          Guzt
          TomOnTourundefined
          TomOnTour
          Tony 13undefined
          Tony 13
          Garry Davis
          • Afstand en tijd tussen routepunten
            Travellexxieundefined
            LennyOundefined
          • Uitspreken adressen en notities
            Huibertusundefined
            Huibertus
            762
          • Karte dreht im Stand bei der Navigation dauernd
            haweboundefined
            hawebo
            455
            John S Parryundefined
            8.1k
          • Embedding daily routes into a whole trip route file - How do I do this?
          • Updated beta! 5.2.1 (486)
            Hubert Thoringundefined
            660
          • Route spoor gpx
